Senton 6s recommendations?
Got my Senton last year during Tower's B/Friday special, and was unable to run till recently due to crappy weather, kids, wife, and college (busy in general).
Anyways, this thing is s.l.o.w. with its stock gearing on 4s, and could deferentially use a few more teeth. Suggestions? Would also like a good 6s recommendation or should another I purchase another Venom 3S 4000mAh 20C?
Seems like that would not be high enough rating for this system, but worried about buying sight unseen/fitted, and end up with too large battery for its tray.
Another issue is its shocks came in under filled and drag around. Would like a good recommendation for general bashing. Hard to find the time to rebuild components lately and don't want to tear it down multiple times to test different weights.
Also, may-as-well add any recommendations for diff fluid weights.
Otherwise, its a great truck and tough as hell! Just needs some fine tuning and more oomph.
I only have a Slash to compare, but my Senton is ok fast on 4S with stock pinion. My LiPo is a 100C. Perhaps 20C is bit low. I'm not expert. I'll be trying the 16 pinion soon for bit more speed.
I'll end up getting (2) 3S batteries when I want to try 6S power, but probably 50C minimum.
For oil weights,I'd recommend to download the free Durango DESC10 manual, as they're very similar trucks. Could be good starting points.
