Old 12-13-2005, 09:20 PM   #1
ETRacer's Avatar
Default 777 SP2 setup question
I have a question for all you SP2 drivers.
The upper front arm position mounting.
Book says run "A" and "L"
most of the setup sheets i have looked at are the same. I know you are supposed to get a little better off power turn in by raising the arms.
I want to know if you can run "A" with the "H" or if you have to run "B" with "H"
I just got this buggy together and had her out for the first shake down run and noticed a bit too much off power push on entry.
I am running 4f/6c/2r with 22 deg hubs, long arms, outer hole on ft hub
I know its new, I have been told the push will go away as the diffs break in, but i just want to know if its possible to mix and match locations.
ETRacer is offline   Reply With Quote
Old 12-14-2005, 12:34 PM   #2
Sofast-NT's Avatar
I run the Fioroni A and H blocks together.Full Fioroni blocks.
Diff oil-5k,7k,2k
Shocks-F-50 R-40
Rear-Anti squat-2 degree
Rear-Toe block-3 degree
Sofast-NT is offline   Reply With Quote
tc5 setup question bigemike Electric On-Road 12 05-04-2009 12:45 PM
Setup Question Serpent720 Nitro Off-Road 2 06-21-2008 04:55 PM
Sidewinder Esc Setup Question... Help Associated-08 Electric Off-Road 11 03-31-2008 02:51 PM
T2 '007 setup question(s) Sgrios Electric On-Road 13 10-15-2007 01:27 PM
Question about setup stations aN4rK1 Rookie Zone 4 02-18-2006 04:10 PM
SEO by vBSEO 3.5.0
