Old 12-03-2005, 06:19 PM   #1
knucklebusta's Avatar
Send a message via Yahoo to knucklebusta
Default XX-4 spur/pinion selection
Any help is appreciated. Noob here.
I have a xx-4, I just bought a GTB 5.5
It has the purple spur in it, which I believe is a 84T. Now with searches in this forum, I've come up with around 20T as what was recommended. However the Novak manual doesn't list a 84T pinion. The closest is a
82 which calls for 16 or 17. Any ideas? I don't want to overheat this motor.
Thanks, Kevin
knucklebusta is offline   Reply With Quote
Old 12-03-2005, 10:27 PM   #2
Trader Rating: 14 (100%+)
You would be best to start off with an 17t pinion with the 82 spur and then work your way up to a 19 tooth pinion. Don't go any higher than that, I don;t have any experience with a brushless, but from what I have read, gearing these are critical, it would be better to undergear (smaller pinion) than to over gear (large pinion). A 20 tooth seems to large, and you probably think to yourself you don't want to wreck anything so quickly, so be safe and stay under the 20 tooth.
o.s. power is offline   Reply With Quote
Old 12-04-2005, 11:37 AM   #3
SlobbaTech's Avatar
With a 10 turn motor I'd gear 7-8 over meaning 17-18 pinion. I don't know how the brushless compares to normal motors for power/gearing but I think you may need to gear them slightly taller......only problem is don't really know if you can consider/gear the brushless the same as a10 turn or more like 13 turn for example. So taking gearing info I gave you for 10 turn take that and call the manufacturer(Novak Electronics #949-8333-8873) and see what they have to say about gearing...takes little more effort to call them but they should know more than anyone else being they make the product.
SlobbaTech is offline   Reply With Quote
Old 12-04-2005, 12:20 PM   #4
AE guy's Avatar
Send a message via AIM to AE guy
I'm a brushless guy too, I can help you out with what will run well and what will overheat. I have a friend with the same system too.
13-15 pinion, and about 82-87 spur gear depending on what you race. That shouldn't overheat and will run well. I have a 9 turn and I need about a 15-16 pinion gear in mine, 16 is the actual I use. I would only concentrate on what won't overheat, that motor is fast enough to push any "reasonable" pinion/spur you throw at it.
AE guy is offline   Reply With Quote
1/10 ep spur and pinion set up? pilipinas Electric On-Road 0 08-22-2008 04:27 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 06:08 AM
Big Pinion / Small Spur - OR- Small Pinion / Big Spur -- Difference? rctoyguy Electric On-Road 7 07-12-2004 04:54 PM
TC3 Spur Gear Selection 48 pitch Cain Electric On-Road 8 05-04-2004 11:24 AM
Spur or Pinion? Mossie Australian Racing 5 01-29-2004 06:46 PM
SEO by vBSEO 3.5.0
