1/10 2wd starter setup
First off I'd like to give a little apology to some very helpful people for replying to my 1/8 servo discussion. I have talked to more people, and thought more, and I may stick with 1/10 2wd as my next race setup. However, your time wasn't wasted, I still gained some good knowledge! lol. Anyway, I need help with a 1/10 buggy setup. I'm confused on how beginning racers buy servos, because without knowing what decent specs to look for, I don't want to buy a servo with specs that aren't good for its purpose, without buying a ton and wasting my money. Anyway, I'm looking for servos for a 1/10. That is my blind spot so to speak. As for motor and electronics, I know that some run sensorless but people say having sensors setups just provides more reliable and consistent power output. That sounds very intelligent and correct in my eyes. So I am going to look for a sensored ESC/motor combo, but if you have immediate suggestions that'd be great. Last thing, a good kit(I think the associated is the best) and 2s batteries for this and my slash 4x4. Thanks, and my apologies for being a newb lol.
Best 2wd buggy
Wondering about some good 2wd buggy kits. I've seen associateds rc10b5m
X factory
Losi 22
Team C
And others.
What's usually the best kit for racing. I don't have experience, time, or money, to try tons of different diff oils and shock oils, so a kit with a good stock setup makes a difference for me, as I'll probably use the factory recommendation.
X factory
Losi 22
Team C
And others.
the xray xb2, its terrific. The yokomo yz2 is quite good too. i like the xb2 much more though.
also, I have had the losi 22 3.0 and b4.1 ft, none of them compare to the quality of the ones above
Check your local track/shop and get your feedback there. See what is supported the most.
I don't think there is no best 2wd Buggy for racing really it comes down to what you like handling wise and afford and support online and your track . There all competitive chassis layouts now.
But best value is the B5M CE or the Lite for sure. Especially support at the track and aftermarket parts. Losi 22 3.0 a little more expensive but its good from what ive seen the layour is somewhat similar to the B5M .
If i only got what my LHS had, i would be stuck with traxxas brushed motors and dromidas.
i just dont agree with "following" what your LHS says you should buy because of this mindset
There will be a steep learning curve if you are not ready to do some tuning specifically to the suspension.
I have the Savox 1258 servo in my B5M C.E. and I'm very happy with both!
B5M CE and you have a great platform with a ton of available setup options.
I was thinking about starting there. What's the difference between Lite, CE and all the other options? Plus I'm going to build this in July so I want it to last from July to probably July 2017
The CE is being discontinued and will likely be sold out soon. Expecting some new version of the kit soon so it might be worth it to wait a bit before buying.
I can say if you are looking for practice and maybe light competition and you don't have a huge budget, the combo I used for motor and ESC worked great. I used a standard Hobbywing Justock sensored ESC to start.
http://www.amainhobbies.com/rc-cars-...112000/p464566
Went with a Sling Shot motor as well
http://www.amainhobbies.com/rc-cars-...p-8000/p360110
I've used that motor in a stadium truck and a buggy and it has a lot of punch for the money and to be honest, it competes very well with pricier motors at two of the tracks I run at. And, if you learn the timing and upgrade to a more powerful ESC later, it gives you even more power.
As far as ESC's go, everyone has their favorite. I go cheaper with Savox and have never had an issue with their products.
The Lite has a lighter chassis and some other lightweight goodies. The CE is the same, but with the original heavier (but more rigid chassis) but also includes a bunch of extras. You get 3 and 4 gear transmissions. B5 and B5M suspension arms and shock towers. Titanium and steel turnbuckles. Steel and aluminum front axles. Plastic and aluminum rear hexes. Etc. . . Edit: Also the better Kashima coated "Fox" shocks.
Then lite
Then factory team
Or something? Idk
