    Hide Wikipost
Old 06-17-2016, 07:39 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 8IGHT-E 4.0 Kit Thread!
Last edit by: Kraig
Welcome to the 8IGHT-E 4.0 Wiki
USEFUL LINKS
Overview
Manual
Pictures
Parts
Print Wikipost
Like Tree20Likes
Old 07-20-2017, 06:31 PM   #1051
joNathanW's Avatar
@Capelracer: I'm wondering the same. Would love to buy some tuning for it, but I can't even find any part numbers.
Another thing: are you guys running a fan motor? Most people at my local track do it with their Agamas and JQs, and I actually have one from the old 8ight 3.0 (electric conversion) which I drove with an Agama A215E body but I just can't mount it on my motor without the body interfering with it. Is there a fan/mount that is thin enough to make it fit?
Would love to use my old one, since it was clearly too expensive for laying around.
Maybe you have some tips for me
joNathanW is offline   Reply With Quote
Old 07-21-2017, 05:45 AM   #1052
cHAmpa's Avatar
The parts list and part numbers for the kit are on the TLR website: Team Losi Racing
The new body, chassis, clutch and rear pivot brace are for the nitro version, however the rest of the tuning parts you can use on the e-buggy.
Have not hear plans on whether they are going to release a 4.0 ebuggy chassis... figured it would be out by now.
cHAmpa is offline   Reply With Quote
Old 07-21-2017, 04:18 PM   #1053
I noticed the springs in kit have colored dots on them. Green on the fronts & silver on the rears. What does that represent in ratings?
DreDay256 is offline   Reply With Quote
Old 07-21-2017, 05:25 PM   #1054
Can't wait to try my new 3mm M2C chassis! If it's anything like the nitro chassis, it's gonna be awesome!
Capelracer and BiLL77 like this.
Big thanks to my sponsors: Novarossi Direct, JConcepts, M2C Racing, Dialed Rc Hobbies
fbrk8r is offline   Reply With Quote
Old 07-22-2017, 05:11 PM   #1055
Fader12's Avatar
What benefits do you think you will see with that chassis? Just curious if it's worth getting once my current chassis is toast.
Fader12 is offline   Reply With Quote
Old 07-22-2017, 05:13 PM   #1056
Fader12's Avatar
Originally Posted by cHAmpa View Post
With the new clamp nut, you use the same spring but you want to make sure you install the nut flush with the chassis.
Ok thanks. That's what I ended up doing and will see how that works.
Old 07-22-2017, 09:57 PM   #1057
From what I read it's supposed to allow more flex.
Old 07-23-2017, 09:28 AM   #1058
It is 1mm thinner to create more chassis flex. On the nitro car, this created more grip and more corner speed while making it much easier to drive.
BiLL77 likes this.
Old 07-28-2017, 08:45 PM   #1059
Fader12's Avatar
Good to hear...Will put this on my wish list!
Old 07-31-2017, 04:56 AM   #1060
Capelracer's Avatar
Does the new LRC offset adjustable rear pivot brace from the nitro tuning kit work on the E buggy??
Capelracer is offline   Reply With Quote
Old 08-01-2017, 01:15 PM   #1061
tkge's Avatar
Trader Rating: 97 (100%+)
Anyone have any 2.0mm front and rear sway bars they would like to get rid of? I don't want to buy two separate sway bar kits for just these two. PM me if so. Thanks.
Tim Dunn
Tekno | Pro-Line | Maclan | DialedRCHobbies
tkge is offline   Reply With Quote
Old 08-05-2017, 04:43 PM   #1062
greenracing's Avatar
Originally Posted by maddog9 View Post
For anyone who likes to run full droop on their buggies you may notice the spindle carrier touches the arm and can result in the spindle carrier cracking as shown in the last picture. The reason we run full droop is that we feel it gives the car more grip/traction on lower traction outdoor tracks.
So back to the issue. First off you will want to use a silver sharpie and trace where the caster block is touching the arm. Next take the spindle and carrier off of the arm. You will take a drum style dremel and dremel out the area at a 45 degree angle to the arm. Test fit, if the carrier is still touching take a little more material off. Put the carrier back on the arm and you should see space between the carrier and arm as pictured.
Hope this helps! I will be headed down to PNB this weekend, see you guys there!
When you run full droop you remove the droop screws front and back?
greenracing is offline   Reply With Quote
Old 08-06-2017, 04:24 PM   #1063
yup take the droop screws out for full droop, the only downside is the shock bottoms seem to pull off the shafts very easy.
BiLL77 is offline   Reply With Quote
Old 08-17-2017, 07:43 AM   #1064
Default Wing Mount
Hey Frank,
I ordered the 8IGHT 4.0 Gen II Wing Mount kit at the beginning of July. It was on backorder until end of July. No biggie. Still haven't received it tho. I checked & now it says late August. Whats up with the push back? Do you think it'll get pushed back again?
Old 08-19-2017, 08:35 AM   #1065
when will this chassis be available and what the cost of it ?
mavdriver is offline   Reply With Quote
