Old 02-20-2016, 04:46 PM   #61
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
Originally Posted by raceyz View Post
I just picked one of these up, I've noticed that there are some pretty standard spares that are on backorder. This is my first Durango kit, is parts availability an issue with them?
In general I don't get that impression any more than other companies. The hole steering hubs thing though is odd, the fact tower was showing May as restock.
I got her all up and ready for some practice tomorrow:
I added the following items:
- Durango alloy "buttons"
- Tresrey Carbon steering Link
- STRC Front shock tower
- Alloy shock screws to front shocks (waiting on set for rear)
- Quick change shock mount for rear (waiting on inner balls to do the same to front)
- exotek 12mm rear hexes
- B5 12mm front axles
Question: When you run large pinion gears, do you space them a bit "forward" than that lip for the screws?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-21-2016, 03:09 AM   #62
Looks great cain,
I'm excided what you say about driving the F!?
I got here all up and ready for some practice tomorrow:
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 02-21-2016, 08:33 AM   #63
Tech Legend
Cain's Avatar
todays the day, off to do some testing!
Old 02-21-2016, 06:39 PM   #64
Tech Legend
Cain's Avatar
alright I got my first run in and all went well. I did pop a spur gear due to an issue I am still looking into with the motor, however, the car itself was great. Very durable and For stock racing I actually didn't find a need for a baby sized spur gear due to the gearing range.
The carpet setup is money with the MC compound "slicks" I ran. I could also see running this car with the current setup with a treaded tire.
I did try running without the sway bar and I felt that if you needed less rotation, it worked well and added some grip.
I also like how easy it is to remove the spur gear and change it.
All in all, very happy so far.
One tip I can give is that the motor mount allows you to remove the motor fairly easily, but it may not be intuitive on how the mount comes out. Basically once you disengage the screws that lock the mount, you will run the motor all the way to the edge, and then tilt the motor "up". the mount will then come out.
Old 02-22-2016, 08:44 AM   #65
Laker67's Avatar
Trader Rating: 62 (100%+)
Hey Guys! So my 210F made it to my house Friday night, the day before our first big race of the season. I pulled an all nighter and built this and my V5 car so I had them ready for the next morning.
I can honestly say that it was a good decision make this car ready for the race. It had amazing corner speed and seemed a bit more neutral compared to my V3 on the carpet. I used the same shock package as my V3 since I had ZERO tuning time before the races started. I wouldn't say it was perfect but it got me through the day with only a few changes. I'll share more on the first page in the next day or so. Everyone that looked over this car was very impressed with it and all the good looking parts it came with. Overall I'm super happy and can't wait to get her back on the track again!
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 02-22-2016, 09:13 AM   #66
Tech Legend
Cain's Avatar
Looking forward to some pics to see how you mounted up the electronics.
the way the car drove for me with the stock setup, I was pretty happy too here. Durango did a really good job on the setup out of the box. to be honest I can't really think of anything I would change right now, heck, the only thing I have diff is I run a carbon strc front tower and I put one shim under the ball stud. I may go with like the carpet setup and take it out.
For 17.5 gearing with my Viper Black edition motor, I was using a 75T spur gear with a 33T pinion on our track and it felt really good. Viper at about 40 degrees of timing.
I also like the way the car sounds going around the track!
Old 02-22-2016, 05:23 PM   #67
Cain, did this get answered?
If not, can you explain more or picture?
WallyRC is offline   Reply With Quote
Old 02-23-2016, 07:16 AM   #68
Tech Legend
Cain's Avatar
I'll see if I can take a pic. Basically, the screws that are to the "right" side of the motor, closer to the outer edge of the chassis have like a lip around them to the outside. So the pinion if you get to a certain size, it will basically contact this . However, if you run the pinion a bit more away from the motor on the shaft, it will clear it but not be perfectly lined up with the spur.
Old 02-23-2016, 07:33 AM   #69
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Not sure if I want to get a 210F now as are indoor season is only about 6 more weeks or get a DEX8 and then in late fall get the 210F.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-23-2016, 08:59 AM   #70
If you want a DEX8, I've been pondering getting rid of mine. I'm a 1/10 scale guy.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-23-2016, 09:17 AM   #71
Tech Legend
Cain's Avatar
I'll be giving the DEX210F a try in dirt conditions. I know its not ideal, etc. so I have my dex210 reg here just in case. But the way the vehicle felt I am very curious to see how ot goes.
Old 02-23-2016, 10:06 AM   #72
Is it possible to overcome issues that FredSwain describes on the front of this car. I always run emulsion shocks so not sure up travel will be a problem. How about bump steer is there a good fix?
AntH3000 is offline   Reply With Quote
Old 02-23-2016, 11:05 AM   #73
Tech Legend
Cain's Avatar
my impression from what fred said is that if you don't mind running emulsion, uptravel is probably not an issue.
As for bumpsteer, I would think any fix suggested for the other car would be the same here since the front end is the same.
Old 02-23-2016, 11:18 AM   #74
I only run bladder shocks as their dampening properties are more consistent than emulsion. I need room for a bladder. I'm honestly not convinced that you have enough room even without them. Yes, you can remove the bump stops but I personally am against that idea. I run the V1 rear shocks and tower on my 210 as a result.
I use 6mm of shims at the wheel end of the tie rods to fix bump steer. Unfortunately, this causes flex at this location so I may end up getting some Exotek aluminum hubs.
Old 02-23-2016, 11:46 AM   #75
Originally Posted by Doughty View Post
Hi Cain,
the RR hanger uses the narrowest inserts and has stock 3 degrees inboard toe-in.
Its not really designed to tune toe-in from here, that part of the car is actually designed for future geometry options, this is why its not explained in the instruction manual.
having said that, you could use an insert that is less narrow which would give a little more inboard toe-in, however it might make the car a little too wide at the rear depending what rear wheels/tires you are using. but I would not recommend going any more than 1 step wider on the RR hanger insert than stock.
for example stock is "dash dot" with the dash inside.
you could use "dash" insert with the dash inside which would add some inboard toe-in. I calculate it would be approx 3.7 degrees each side.
Adjusting the toe-in in this area of the car isn't a go-to setup option but it is possible. but there could be negatives to doing this as its using the car outside of its intended design.
I hope that helps.
What can we expect, from this future geometry options?
My head starts thinking about it allready!
YZ-10 '94/'95 WCS/
Spectrum DX3R
