Old 04-11-2016, 02:51 PM   #211
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Good stuff.. man you got to take vids lol.
I bet you guys would fall asleep running stock
So anyone got any more tips on there dex210Fs? I'll probably start my rebuild for outdoor dirt here soon, go slow and all since its probably not till june for anything official, but maybe may for practice.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 04-11-2016, 03:49 PM   #212
Laker67's Avatar
Trader Rating: 63 (100%+)
I don't know if you have had this problem yet or not Cain, but on big jumps I've found the rear wing mounts to be brittle if you endo real hard. I've broken a couple of sets on my V5 car, so what I did to strengthen the mounts was to coat it with some JB weld 2 part epoxy. I found some 4400 PSI yield strength stuff and coated the mounts on my V5, it seemed to fix the problem. I took some pretty hard hits off the big triple and didn't have any issues with breakage. When I got home I did the same thing to my 210F, so we'll see how they do when I get it back on the track.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 04-11-2016, 05:55 PM   #213
Tech Legend
Cain's Avatar
Cool, take some pics when you get the chance.
I haven't gone butt down on jumps and what I am jumping isn't monster either so will have to see how it goes outdoors.
Old 04-11-2016, 10:39 PM   #214
bdyche's Avatar
Send a message via ICQ to bdyche Send a message via AIM to bdyche Send a message via Yahoo to bdyche
Originally Posted by Just2much19 View Post
Anyone only using two gears in the diff? If so can you explain any difference you've notice? I am guessing this is done to decrease drag on the drive train but correct me if I'm wrong.
This weekend I ran 2 gears in the diff - at first with the composite gears, but I blew them up after just 2 runs. Switched to the metal gears from my spare 2wd diff and it ran great all weekend! I tested it as a way to get away with thicker oil (for consistency throughout the run) while reducing how hard it grabs on corner exit. It did really well until A2 and A3 when the track got a little bit dusty, then it wanted to continue to turn on corner exit. Not undriveable, but I would have been faster had I adjusted it. Hard to make that adjustment with all 3 cars in the AAA mains, though!
Also is everyone using the 7000cst in the diff?
20K based on Travis Amezcua's recommendation, though I ran the car on clay.
Tacoma RC Raceway /// Mike's RC World (RIP) /// Skagit River Raceway /// DieHard RC
Kyosho America /// Maclan Racing /// Xpert RC /// AKA /// Pro-Match Racing /// Stuck On Racing (SOR)
Maclan Racing Northwest Region Team Manager
bdyche is offline   Reply With Quote
Old 04-11-2016, 10:54 PM   #215
bdyche's Avatar
Sorry for the low quality attachment, but here's where I ended up after my first weekend on clay at Tacoma RC Raceway. I managed to make the 2wd modified A club racing on Friday night and again at round 5 of the Northwest Indoor Series. The car is much better on the clay than I had expected, and certainly less tire-dependent than my Redworkshop B5M. I think it would be better with 25K in the rear diff OR going down to 15K with all 4 diff gears, and lengthening the wheelbase at the rear hubs would help slow down the rotation (at the expense of some forward bite), as well as going up to AE 37.5 wt oil in the rear shocks. This car would do wheelies on command all weekend, so I certainly didn't have to chase traction.
EDIT:
I did have a couple of minor issues this weekend, but nothing I would consider a quality or design problem. I chose to run just 2 planetary gears in the diff, but during the 3rd run they exploded. After rebuilding the differential with metal cross pins and gears it ran fine the rest of the weekend. The plastic rear hexes also rounded out quickly, so I replaced them with Exotek 5.7mm hexes.
During practice on Friday I landed a jump horribly wrong and hit a retaining wall hard on the left front, but all that happened was the camber link popped off. Nothing else broke all weekend!
Old 04-12-2016, 11:14 AM   #216
Tech Legend
Cain's Avatar
congrats!
In your opinion, as the traction gets lower, am I correct to first look into dropping diff oil versus going from say 4 gear to 2 gear? (say you start with 4 gear).
And what do you recommend as a starting setup for your gear diff for conditions between low to medium in traction? (example: 4 gear 10K)
Great info again!
Old 04-12-2016, 06:03 PM   #217
bdyche's Avatar
Originally Posted by Cain View Post
congrats!
Great info again!
Thank you, it was a nice surprise to take a car that shouldn't work and have my best showing ever at that track!
I haven't messed with the gear diff enough to really say with confidence what should be done 100% of the time, but I was diffing out with 20K and 2 gears at about the 3:30 mark in all 3 mains. In lower traction conditions a thinner diff oil should be better (it is in 1/8 and 1/10 4wd), and maybe a 4 gear setup will help with the consistency over the 2 gear. My DEX210V3 has a gear diff with 7K and all 4 gears and it was absolutely dialed, so I am going to try 4 gears and 10K in the F and see how that is.
I don't want to speak gospel as this was my first weekend with the car, just sharing what I have learned so far, so take it with a grain of salt. To start with I think 10K and 4 gears may work best for modified, 7K with 4 gears for stock. My theory is that the increased load from a bigger motor both under acceleration and braking may heat the oil more and cause it to be thinner as the run goes on, and the 4 gear will help maintain the consistency. The other option may be to start with a thicker oil (10K or 15K) and warm up the diffs like we do with 4wd and 1/8. I think I'm going to buy another differential to be able to rapidly change it out (6 screws!) and try more things.
Old 04-13-2016, 07:05 AM   #218
Tech Legend
Cain's Avatar
good stuff thanks for the info!
I think I'll start with 4 gear as well. It will be stock class running here.
The great thing agreed is the quick diff change for sure! I may do the same and pickup a spare diff to do a quick change as well.
Old 04-13-2016, 11:48 AM   #219
Great stuff guys. Making me really want a 210F!!
WallyRC is offline   Reply With Quote
Old 04-13-2016, 01:12 PM   #220
Tech Legend
Cain's Avatar
yeah its a good car for sure in the last few races I had. I am looking forward to seeing what it does outdoors.
Old 04-13-2016, 09:54 PM   #221
Can't wait to hear what you think. We run on indoor dirt/clay.
Old 04-14-2016, 10:15 AM   #222
Tech Legend
Cain's Avatar
yeah its step pin time here lol
I am hoping to with the weather getting better to hear more on when they want to setup some time for track work and I can come out and run.
Plan to start the rebuild process of my vehicles this weekend.
Old 04-19-2016, 03:52 PM   #223
Tech Legend
Cain's Avatar
cool vid of the dex210F here:
+ YouTube Video
Old 04-28-2016, 12:51 PM   #224
Tech Legend
Cain's Avatar
yeah guys just checking in to see how everyone is doing with their vehicles?
Word from Laker67, assuming I recall correctly the wing mounts are the same from the dex410v5, we could see some exotek goodness there in June sometime.
Old 04-29-2016, 01:16 AM   #225
rcjunky1's Avatar
lol, home town hero getting youtube famous :P it a quick car to say the least. I'm still trying to find one for a deal I like
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
