New Team Durango DEX210F Thread
#136
With the 50mm shaft in, how close to the top of the shock body is it When fully compressed? If it has 2mm plus you should be fine. If your not using bladders like Fred. There is room for the 44mm in front.
#137
Tech Legend
Here is a vid of the DEX210F at the last race, my driving was a bit subpar but you get the idea
+ YouTube Video | |
#139
I was messing with my V3 shocks last night and they have the 21.5 mm front shock bodies, same as the 210F. Fully compressed with the bump stop in I was about 1.5mm from being even with the top of the shock body. Given that I believe there is space between the top of the shock cap and the shock body when its fully threaded on I'm sure the 44mm shock shaft shouldn't be an issue. Same goes for the 52mm shock shaft to the 50mm. Fully compressed with the bump stop in it was about the same as the front shocks but I'd have to measure it since I wasn't paying close attention. I would honestly be more concerned with the droop instead of the up travel. Adding an extra 2mm to the length can make the car really twitchy and hard to drive.
When I ran the F with my V3 shocks on it made the care really unstable coming out of high speed corners and made it unpredictable through tight corners. After the race I built the F's shocks and it made the car come alive. Even with a base setup it was much easier to drive then it was before. But this is all personal experience, not gospel.
#141
Tech Legend
As it sits right now though, i don't think anyone is reporting issues with the rear shocks, right?
I took out the broken shock end from my DEX410V5 shock end, exact same place as the dex210F.
#142
Hi Cain,
I've watched the video of the carpet race, nice run!
Have you also tried some european typical carpet tires too, like schumacher mini pins for the rear and schumacher low profile staggers for the front?
Would be interesting, what you say, if you try this one, compared to them you use normaly?
#143
Tech Legend
Hi Cain,
#144
The 210V3 front shock shafts are definitely a problem. I have broken about 5 fronts and no rears this far. All of them were minor pipe scrubs or contact that should not have broken them at the threads like that. I will try the above mentioned upgrade, thank you to whoever posted that!
#145
Tech Legend
make sure everyone is calling hobbico about this. When I called the tech said that was the first he had heard of anything about it.
I also shot Travis an email and he is going to forward that along, but as the saying goes, the squeaky wheel gets the grease so lets get the grease going here.
Can you guys take some pics of what you are seeing for breakage, I'll take pictures of what I got here.
More so than the shafts is the damage it does to the shock eyelet so you have to dremel to get them out, if you can.
Anyone know of an alternative to the stock shock eyelets. Looking for something cheaper that will work with the stock cups.
#146
http://www.dialedhobbies.com/er-12m-2-0-parts/intech-er-12-shock-ends-4-detail.html
Cain,
Check this website out. Don't know if they are the same. But the Intech12m is a mid motor buggy that looks like a copy of the dex210 with some differences. For $4.49, might be worth a try.
Just stumbled upon this.
Wally
Cain,
Wally
#147
make sure everyone is calling hobbico about this. When I called the tech said that was the first he had of anything about it.
Paste this link and see what you think. Seems to be 210 clone. Might be the same?!?!
#149
Cain: Have you weighed your 210f in race trim ? I may have missed that post if you have. My 210v2 weighed 1580 ready to race stock class . My 22 3.0 is lite at 1540.
#150
Tech Legend
I haven't done that. I basically just have 4 wheel scales so if logic is correct I would just total up what they say. I'll see if I can give that a go today and I'll post what I find.
Mind you, I run the strc graphite front tower which may be heavier. You can probably shave a good a mount of weight too using lunsford turnbuckles as if I recall correctly on my DEX210V2 that has the Plan b chassis, i went lunsfords and it had some nice weight savings.
I'd be curious what it could weigh if someone made a graphite chassis.
