Like Tree11Likes
Old 02-04-2016, 02:26 AM   #61
bigbenmbx7t's Avatar
Originally Posted by Cain View Post
for you guys with V4s, how has durango's aluminum quality been for you. toying with getting this.
Aluminum has been great, carbon front towers are the only part I've broken I felt like I shouldn't have. Plastics are better for me as we run on carpet with zero padding strait to concrete.
bigbenmbx7t is offline   Reply With Quote
Old 02-04-2016, 07:24 AM   #62
Doughty's Avatar
Originally Posted by PIHGUAM1 View Post
Im running on carpet outdoors. When it is bone dry, there is lots of grip. When there is moisture it gets slippery. Track conditions change frequently. We have a saying here "If you don't like the weather, wait 10 minutes and it will change."
We need to have 3 sets of tires due to the changing conditions. There is not enough time to change set up. So tuning needs to be somewhat neutral.
I'll give your suggestion a try first. Especially seeing how I have more saddle packs then shorties. ;-)
I have run my car on low-medium grip dirt outdoors, high grip astroturf outdoors and low grip astroturf outdoors (wet) with very small adjustments to setup.
I run with the saddle config, batteries forward with the kit setup for high grip (minus front rollbar which is personal preference)
for low grip astro I changed to inside hole for the shocks on the arm.
for dirt I changed the rear camber link to be lower and a thicker rear rollbar.
I'm not saying the shorty config wont work, but the saddle pack config has certainly worked is all conditions with very small adjustments to the setup. the car really is THAT good!
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 02-04-2016, 02:33 PM   #63
PIHGUAM1's Avatar
Yea I was looking at your set up sheets and only see minor changes.
I figured the car must be well balanced and works really well or this guy is really lazy and drives really good. :-)
So how is it on bumpy surfaces? Though our track is covered with carpet, the surface is not smooth underneath. It is definitely off road, not an on road track with some ramps.
PIHGUAM1 is offline   Reply With Quote
Old 02-10-2016, 09:28 AM   #64
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
curious as well on handling in bumpy conditions.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 02-10-2016, 09:43 AM   #65
Yes, me too!
What interrests me very much is, as the front and rear shock shafts are shorter, than on the previus 410's, how about max droop at the v5!?
At the front shock tower, TD went back to the original one and the rear is completly new, may lower, too?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 02-14-2016, 02:29 PM   #66
Hey guys, very interested in this car, one thing I'm not sure about though, what's up with the slipper gear diff setup? I run a tekno sct that has a full on center gear diff with no slipper and would want the same in a 4x4 buggy. Reading through this thread has me confused to what the options are and the info on Durango's site doesn't answer my ? either. Confirmation on this from some of you owners out there would be great. I appreciate it and tia.
mikeinsocal is offline   Reply With Quote
Old 02-15-2016, 01:39 AM   #67
fast-ho-cars's Avatar
car shows in stock now on towerhobbies
http://www3.towerhobbies.com/cgi-bin...&I=LXDUHU&P=SM
with 014R2 coupon code $60 off = $339 shipped free
fast-ho-cars is offline   Reply With Quote
Old 02-15-2016, 02:20 AM   #68
ekt
ekt's Avatar
From what I've been able to gather while not having the kit, the Exotek slipper eliminator will remove the slipper action.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-15-2016, 06:56 AM   #69
psl
The Exotek product works great. It locks down the slipper.
Durango DESC 410v2 4wd SC
Durango DEX 210 Exotek MM
Durango DEX 410v5
Kyosho SC6
Radiopost
psl is offline   Reply With Quote
Old 02-15-2016, 10:06 AM   #70
So will that lock in the front and only give you adjustment with the different weight fluid to the rear?
Old 02-15-2016, 11:19 AM   #71
I do not understand that exotek thing!?
Cant i lock the slipper just by srewing down the slipper nut as much i can, so this would not be needed, or do i understand that wrong!?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 02-15-2016, 11:35 AM   #72
Tech Legend
Cain's Avatar
wrong car, this is the one you want:
http://www3.towerhobbies.com/cgi-bin...&I=LXFRFU&P=ML
$389.99 with that coupon
Old 02-15-2016, 03:52 PM   #73
ekt
ekt's Avatar
It removes the slipper action, making it just a standard diff.
It was designed for the old DESC410. When the spring was fully tightened, some people were still reporting slip. It might not be needed for the buggy due to less weight.
Leo Lorenzen
Old 02-15-2016, 05:07 PM   #74
Shawn_S's Avatar
Trader Rating: 18 (100%+)
Got the shipping notification for mine! Can't wait, my first wheeler!
Well that, and a big 550 4-pole spinning 4 SCT tires.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 02-15-2016, 07:45 PM   #75
psl
When you tightened the nut fully down it did slip once and a while and caused a few problems. Once I put the diff locker on it never slipped.
