Like Tree11Likes
Old 01-23-2016, 05:30 AM   #31
bigbenmbx7t's Avatar
Originally Posted by ekt View Post
The kit page and manual says it does.
that's a nice upgrade, gonnna be a sweet ride. might have to have one.
bigbenmbx7t is offline   Reply With Quote
Old 01-23-2016, 08:57 AM   #32
Laker67's Avatar
Trader Rating: 61 (100%+)
I guess I should have looked a little harder before answering the question. Yikes, foot in mouth. It's nice they include that arm in the kit now.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 01-24-2016, 09:29 PM   #33
ASH93A's Avatar
Originally Posted by micholix View Post
I think, its the 2 way slipper, like the v4, but you have to be carefully, as the v5 does use those drive shaft blades on the center drive shafts, like the tc cars use, so may the slot for the drive shaft pin is different in diameter?
Certainly this link suggests that is the same as the V4 two slipper..and it is a option part for the V5
http://www.team-durango.com/part-inf...artNo=TD210008
But isn't the center diff unit housing wider than the V4, so not sure how the 2 way slipper would fit in, if that makes any sense?
ASH93A is offline   Reply With Quote
Old 01-24-2016, 10:15 PM   #34
From the pictures the motor mounts are set a lot different, the slipper center diff is gonna be nice for carpet.
Old 01-24-2016, 11:32 PM   #35
The two-way slipper could fit directly, actually i dont know the messurements from those drive shaft plates, it was just a guess, as it looks like wider, than the drive shaft pins itselve.
For the slipper/centre diff mount, yes, it is wider, but if you look at the picture of the blank chassis on the kit page, you can see, that there are mounting holes inbetween the standard motor mount posission, so i guess, you can mount it closer to each other, may you'll need a longer centre drive shaft too!?
We will see exactly after the first shipments...
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 01-25-2016, 01:57 AM   #36
ASH93A's Avatar
Yep, I see what you mean. So maybe would need to use the center drive shafts from the V4 as well when using the 2 way slipper?
Old 01-25-2016, 08:12 AM   #37
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
for you guys with V4s, how has durango's aluminum quality been for you. toying with getting this.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 01-25-2016, 08:44 AM   #38
Trader Rating: 21 (100%+)
I've been running Durango since the 1st car....no issues
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 01-25-2016, 12:35 PM   #39
Laker67's Avatar
All the aluminum parts have been great! Never any issues with any of my cars.
Brian Jenkins
Old 01-25-2016, 12:42 PM   #40
Tech Legend
Cain's Avatar
good stuff then. will keep a close eye on it. At the upper end of my price range and i don't usually buy new, but this could buck that trend.
Old 01-25-2016, 04:29 PM   #41
jhautz's Avatar
Trader Rating: 85 (100%+)
What breaks on this buggy. Looking for a list of recommended spares. To order with the kit.
jhautz is offline   Reply With Quote
Old 01-25-2016, 05:01 PM   #42
hacker's Avatar
Trader Rating: 140 (100%+)
it's not out yet!!!
hacker is offline   Reply With Quote
Old 01-25-2016, 05:26 PM   #43
jhautz's Avatar
Seriously....
The V1, V2, V3 and V4 have all been out for a long time. It's the same base car with some updates. I'm sure there is a pretty well known short list of wear or likely breakage items.
Old 01-25-2016, 06:28 PM   #44
yz167's Avatar
Trader Rating: 23 (100%+)
I have had my v3 for a couple of years and have broken a couple of front arms and one rear arm. That's all I have broke except a rear drive shaft last week but that was my fault and I wouldn't worry about having a spare.
B6D / SC10.2 / SC8E
8ight EU / 22T 2.0
D413 / SC6
yz167 is offline   Reply With Quote
Old 01-25-2016, 06:33 PM   #45
Laker67's Avatar
Seriously....
the only similarities between the older versions and the V5 is the front steering rack forward. It does share the rear arms and hubs with the 2wd cars. I plan on getting the following: front bulkhead, spindles, and arms, inner front hinge pins, rear inner hinge pins, rear arms, and hubs. In the past year and a half the only thing I've broken on my v4 car has been a front tower (didn't prep correctly), three front arms, and two spindles. Of the three arm breaks only one was my fault. It's a solid car. But those things I mentioned above are just precautionary, hate to be out a whole race day if some thing random happens.
Brian Jenkins
