Like Tree11Likes
Old 11-21-2016, 08:50 AM   #421
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
I think the lunsford ones are better, but not a whole bunch better for the current cups versus the original ones that the dex210 had problems with.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-21-2016, 08:56 AM   #422
JRSlash's Avatar
ok, thanks. I will be adding the Lunsford more for the bling bling...LOL. But at least there will be a slight improvement in performance and weight. Money not completely wasted I guess. I will post some pictures once I get them on.
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
PR Racing SB401
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
Bellgate Distributor (www.bellgatedistributor.com), PR Racing USA
JRSlash is offline   Reply With Quote
Old 11-25-2016, 02:21 PM   #423
Tech Legend
Cain's Avatar
Amain has the dex410v5 for 349.99
Old 11-26-2016, 09:05 PM   #424
Trader Rating: 16 (100%+)
Send a message via AIM to Fuzzchop
Default multi axle
I got the longer rear shafts but how does this work is it just put more dogbone into diff i dont see how it makes car wider instructions vague as hell.
Fuzzchop is offline   Reply With Quote
Old 11-26-2016, 10:52 PM   #425
Hi, it does not change the rear width at all, its just different, where the angle of the dogbone begins. With the longer bones, you need to use the more outer hole on the axle, so the point were the pin of the dogbone touches the diff, should be almost the same.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-26-2016, 10:55 PM   #426
ekt
ekt's Avatar
The axle has multiple holes to suit the different length driveshafts.
It's not designed to make the car wider.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 11-28-2016, 06:09 PM   #427
so why would you want to change length ?
Old 11-28-2016, 11:08 PM   #428
Hi Fuzzchop,
In the description on the TD Website you can see, that the different mounting positions does change steering, so a deeper mounting point in the axle, gives you more on power steering, for that you'll need the longer 62.5 mm drive shafts and if you Mount the drive shaft in the most outer hole from the axle, you will need the shorter 57.5 mm drive shaft, kit Standard is the middle mounting and 60.0 mm shaft.
when you scroll down, you can find the "multi-axle" description:
http://www.team-durango.com/race-cars/dex410v5/
hope that helps?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 12-03-2016, 02:58 AM   #429
frankf's Avatar
When using a shorty pack with both the battery and motor in the rear whats the difference whether the motor is on the right or left?
frankf is offline   Reply With Quote
Old 12-03-2016, 07:10 PM   #430
Tech Legend
Cain's Avatar
I think the rotation of the motor may affect something relative to the chassis. Exactly what i don't know.
Ran today first leg of our point series and ended up taking 1st (probably should have been second as leader broke) but the after changing the shock settings was on point even though I was running a 13.5 motor against a sea of 10.5s . I could see they had a tad more pop than I did but the Maclan 13.5 held its own quite well. I may buy the higher torque rotor to try out on that motor. I was also running it in strictly blinky mode as I would like to see us do a spec class eventually.
https://www.facebook.com/RCUndergrou...7768116339896/
After changing to different shock shafts car worked great, pretty durable too.
Old 12-07-2016, 12:05 PM   #431
Has anyone had issues with AKA front wheels and the 12mm hex's? The AKA's are just too big and rotate and strip out on both the stock plastic hex as well as the Exotec upgraded aluminum hex's.
The TLR front wheels by comparison fit like a glove and aren't oversized?
New Team Durango DEX410V5 Thread-image1.jpg   New Team Durango DEX410V5 Thread-image2.jpg
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 12-07-2016, 01:05 PM   #432
Tech Legend
Cain's Avatar
I'll see if I have any AKA wheels here and give it a look. I use JConcepts wheels no issues here.
Anyone got pics of fan setups for the motor you guys are using?
Old 12-07-2016, 01:15 PM   #433
JRSlash's Avatar
All my wheels for this buggy except one set are AKA and I have no issues. The other set is an xray set of front wheels. All of them are 12mm hex.
PR Racing SB401
Old 12-08-2016, 11:57 AM   #434
Hi everyone,
I just want to ask, if someone knows, to witch brand Travis Amezcua (Peanut) switched, or what he is doing now?
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 12-08-2016, 11:59 AM   #435
Hey Cain,
Congratulation to that result, well done!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
egalsim
