Like Tree11Likes
Old 09-28-2016, 08:21 PM   #391
Anyone found a replacement aluminum servo horn (25T) for this thing? I stripped out the plastic stock one last week and ordered up an Exotec along with a TLR and neither would work with the stock linkage. The stock linkage doesn't allow enough angle to mount to either of the horns.
I ended up using the Exotec with a 4mm ballstud I had lying around and it seems to function perfectly except i'm concerned i'm at the limit of the angle the stock linkage will work.
Anyone found a suitable stock replacement?
New Team Durango DEX410V5 Thread-image1.jpg   New Team Durango DEX410V5 Thread-image2.jpg
B64D | B6 | T5M | EB48.4 | Talion | EMB-TGH | Sakura Advance
daedalus is offline   Reply With Quote
Old 09-28-2016, 09:04 PM   #392
ekt
ekt's Avatar
Racers Edge clamping servo horns are the best fit, from what I've found, they have limited offset which suits the 410 https://www.amainhobbies.com/search?...pro+servo+horn
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 09-28-2016, 09:51 PM   #393
Thank you!
Old 09-28-2016, 11:58 PM   #394
Pittster's Avatar
I use the TD 1/8 alloy servo horn and it fits well and the offset ends up being like this
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 09-29-2016, 10:19 AM   #395
JRSlash's Avatar
I use a TLR 22-4 aluminum servo horn. Works for me.
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
PR Racing SB401
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
Bellgate Distributor (www.bellgatedistributor.com), PR Racing USA
JRSlash is offline   Reply With Quote
Old 09-29-2016, 12:42 PM   #396
Weird that's exactly what i got. I think my servo is so long that it's pushing it further forward than normal which is causing more of an issue than normal.
Old 10-04-2016, 02:38 PM   #397
rcjunky1's Avatar
just add a few spacers
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 10-23-2016, 02:01 PM   #398
Please clarifying me what the durango two way slipper is used for.
Its better to use the two way slipper for astro/carpet or for low traction ?
on my dex410v5 I am using diff with slipper in the centre.
Any advice are appreciated
lynx75 is offline   Reply With Quote
Old 10-23-2016, 05:09 PM   #399
Put the Exotek aluminum hex bits on the car to replace the junk plastic ones and have run hundreds of trouble free laps. However, this past week my car was having a front wheel nut back off and shed a wheel during laps on 4 separate occasions.
And I torque those wheels down as tight as possible without having the hex start to rotate in the wheel. Any suggestions on how to prevent this?
Using AKA wheels and durango steel nuts. Never had this issue before and i can't seem to cure it.
Old 10-23-2016, 05:45 PM   #400
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
personally I lock the slipper on carpet or use the Mkune style slipper pads as they don't fade.
Have you tried some blue loctite?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 10-23-2016, 10:01 PM   #401
ekt
ekt's Avatar
I would say the 2-way slipper is more suited to carpet/astro.
Check your bearings and that there is no binding in the axle.
Leo Lorenzen
Old 10-24-2016, 04:01 AM   #402
Hi cain
i'm new to the dex410v5
Got a an advance experience in the 1/8 electric scale but since about 9 yrs a quit the 1/10 scale .. now i'm back to it .
I think this model tops among rivals.
Please, advise with the best esc/motor combo along with a direct fit servo .
I'm a basher but uses racing models for this ...
i need your advises & follow up here heavily..
Batman4ever is offline   Reply With Quote
Old 10-24-2016, 08:29 AM   #403
Tech Legend
Cain's Avatar
For ESC I personally use the hobbywing V3.1 ESC and it works well. For motor that will depend on your power needs, at this time I use an 8.5T. You may want to check at your local track to see what is common as well as what you are comfortable with speed wise. I am entertaining picking up a 13.5 or the indoor racing here.
As for a direct fit servo, if I recall correctly I am using the savox SC1258TG servo. The only servos you really have to watch for are those with fatter dimensions than the servo I mentioned as they won't fit correctly and can space the servo horn in an odd angle. I tried to get one of futabas newer high power servos to fit but it was just too fat.
Old 10-24-2016, 10:49 AM   #404
appreciated cain
a while back one guy from germany advised me with the lrp worksteam victor modified x20 combo 4.5t ..any thoughts ? He said it's the best out there
i'm thinking of tuning timing fir the uptimum acceleration possible
Old 10-24-2016, 11:09 AM   #405
Originally Posted by Batman4ever View Post
appreciated cain
Just my opinion but the only place you could really only use that kind of power would be on a very very large outdoor 1:8 track....and even then. I'm running the LRP X20 6.5 on a 1:8 track and it's a bullet. Properly geared for the track 5.5-6.5 is all you need. Hell, most of the guys I know would probably have lower lap times running a 10.5...........
Alan_r is online now   Reply With Quote
