Like Tree11Likes
Old 02-29-2016, 10:30 AM   #136
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
man I need my car!!!
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-01-2016, 11:17 AM   #137
MikeR's Avatar
Trader Rating: 15 (100%+)
Dex410 goodies!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-01-2016, 11:37 AM   #138
Wow, those parts look nice, i do like those two piece servo mount!
Great work mike
Originally Posted by MikeR View Post
Dex410 goodies!
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 03-01-2016, 03:31 PM   #139
PIHGUAM1's Avatar
Any plans for a battery hold down from Exotek?
PIHGUAM1 is offline   Reply With Quote
Old 03-01-2016, 03:56 PM   #140
Pittster's Avatar
The servo Mount would be excellent in the v5 if running shorty battery and rear motor,but unsure it would save any time if all electronics were in the foward motor position.
Do like the Steering bell cranks will be keen to grab them.
Good to see Exotek leading the way on hop ups for the TD line up
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 03-01-2016, 05:39 PM   #141
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Laker67 View Post
Also, no fluids, tools, and wheels in the kit.
This is doodoo. A kit should include EVERYTHING required to build it in its entirety, less tires. While diff fluids will vary depending on each person's needs, there is a general viscosity that will be in the vicinity of what is required. Given this is now the 5th revision we all know 7k/3k is a great general starting point for this drivetrain. The center diff oil would be dependent on what is selected for the front and rear diffs to allow the best all-around performance.
Wheels? C'mon... really??!?? They cost them cents to produce. That's just wrong.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 03-02-2016, 09:46 AM   #142
Tech Legend
Cain's Avatar
Looks like managed to swing a DEX410V5 that just started getting built for $350 shipped priority if all goes right! May even see it saturday. Even has some upgrades on it.
Excited!
Old 03-03-2016, 01:18 PM   #143
richmtb01's Avatar
I've started my build and have one major issue so far....Maybe this was covered some where and I missed it. After assembling the servo in the servo plate, the ackerman bar narrowly cleared the top of the servo (I'm running a Futaba aluminum canned servo). Once I bolted the front clip to the chassis, it now gets caught on the servo. Any word on this?
AKA
The RCNetwork on YouTube
richmtb01 is offline   Reply With Quote
Old 03-03-2016, 01:31 PM   #144
richmtb01's Avatar
There are also several nitpicking issues with the build so far:
1. Manual is small - Not sure if the V4 was like this, but exploded pics on a half sheet of paper is bad!
2. Parts came off the trees during shipping - most notably, the front hub carriers were both off the tree and in the manual, they say they're different part numbers. No R/L marked on the part and they look identical, so I had to guess
3. No fluids, or wheels, which is a bummer
4. I hate the P2/P3 bags - They are stock full of trees - what happened to bag one, step one?
5. The owners manual starts with the front clip, which you would assume was bag 1....not so. Seems like the bags were labeled, then the manual was adjusted to a different order of assembly
6. Picking out the rear hingepin inserts seemed like translating mandarin. The pic in the tiny manual was complicated - just tell me what the stock set up part number is.
7. Plastic part trees had two license plate model numbers, with different numbers, some had one number on one side and a different number on the back.
8. Only had one issue where parts were missing....found them in the next numbered bag. crisis averted.
9. Seems like there's a lot of additional parts, that might not even goto the V5 - like the extra smaller rear hub carriers?
I'm about half way through, just installed the battery strap and headed to mount the motor. Parts seem decent and the build quality is good
AKA
Old 03-03-2016, 03:14 PM   #145
MikeR's Avatar
Hi Rich,
If using a standard 20mm thick servo then there should be a 1mm gap between the servo and the steering plate, if all was installed correctly. Make sure the servo is bolted down flat against the chassis.
Old 03-04-2016, 07:13 AM   #146
Tech Legend
Cain's Avatar
richmtb01: what did you find for the solution to the issue and what servo are you using exactly? I am looking to use this:
Futaba S9372SV servo
http://www3.towerhobbies.com/cgi-bin...&I=LXFSGA&P=ML
Dimensions:
SPECIFICATIONS
Torque: 280 oz/in (20.1kg)
Speed: 0.07 sec/60 @ 6V
Dimensions: 1.6 x .83 x 1.46" (40.5 x 21 x 37.2mm)
Weight: 2.47 oz (70 g)
in your and anyone elses opinion, will this be a problem? and if so, what solution options are there short of a different servo?
Old 03-04-2016, 09:33 AM   #147
Shawn_S's Avatar
Trader Rating: 18 (100%+)
Radiopost signature series in mine,(41.5x20.7x37.9mm) fits with a bit of clearance. In my old DESC410R (same parts) I ended up filing down the underside of the ackerman plate to get enough clearance. I think that was a JR 9100S.
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 03-04-2016, 11:56 AM   #148
Tech Legend
Cain's Avatar
good stuff thanks!
Old 03-04-2016, 03:33 PM   #149
Laker67's Avatar
Trader Rating: 61 (100%+)
Hey Guys, I updated the first post with a couple of things. I'm not done with it, but I've been slammed at work and this is the most I have been able to gather for now. I'll get more up asap.
Cain, I added the front wheel width measurements we have talked about. Its not done yet either but its all I could do when building my buddies kit last night.
Thanks to my sponsors: Maclan Racing, Addiction RC, Exotek, Jconcepts, Futaba, and Trakpower
Brian Jenkins
Local track: Addiction RC in Ogden, UT - AddictionRC.net
Laker67 is offline   Reply With Quote
Old 03-04-2016, 05:21 PM   #150
Tech Legend
Cain's Avatar
great, comparing it to roar specs it looks like its still good to go.
Ordering the Exotek Locker based on your suggestion
