Traxxas Slash 4×4 Sidewinder 3 problems
So after installing a Sidewinder 3 motor and ESC into my Slash 4×4 the grub screw on the pinion keeps coming put and the pinion slides around on the shaft. Could it be because the Sidewinder has a 3mm shaft instead of the stock 5mm? Help is greatly appreciated and needed!
Yes, the Sidewinder combo is available in 3mm and 5mm shaft sizes. You'll need to use a 3mm pinion, or use Robinson Racing #1200 reducing bushing. Note...The 4x4 uses a 32P pinion, so you can't use a Slash 2wd pinion, which is 48P.
Alright thank you! I'm going to order a 15t pinion soon!
