Buying Advice
Buying Advice
Hi guys,
I'm looking for some advice and recommendations as I'm relatively new to the RC world. I'm after a 1/8 scale vehicle for bashing. I own/have owned an MT4-G3 (w. MAX8 and 4270SL 2200kv in it) in the past as well as an HPI Bullet ST Flux.
I like the MT4-G3 but its almost too monster truck'ish for me. I'm a huge fan of the buggy style but the low ground-clearance is a concern. In terms of look i'm a fan of the HPI Vorza but again the clearance is a concern. I really don't like the typical truggy look either which makes it very difficult for me to find something.
My priorities are:
- Has to be durable and relatively easy to fix; i'm not a tool wizard
- Has to be able to run on 6S
- Has to do at least 50mph
- Must be able to perform both off-road and on-road with obvious drawbacks (i'm not expecting a master of all; probably 70% off-road, 30% on-road)
- Must have decent parts support
- Doesn't have to be RTR
- Waterproof (if RTR)
- Budget: $1000
looking forward to some suggestions!
thanks a lot!
My priorities are:
- Budget: $1000
thanks a lot!
Hi guys,
My priorities are:
- Budget: $1000
thanks a lot!
My priorities are:
- Budget: $1000
thanks a lot!
Get a tekno eb48 but i don't own one yet so I can't tell you any stats
I have the Vorza. Does good on the surfaces I run on. Pavement,baseball field sand, grass. It's becoming an old vehicle. Heavy compared to a couple other buggies. Probably never run at a track so weight not a issue to me.
The recent Arrma vehicles seem to be interesting. Typhoon looks interesting. And they seem to have gotten past the early ESC issue. Never seem one run though.
I'm getting a tekno EB48.3 to race but from what I read in the fourms it is a super durable buggy. So you could bash it and then if you decide you want to race you can race it.
Arrma Kraton or Talion sounds like the truck for you.
From your description it sounds like you're looking for a truggy. You basically described your MT4. If you don't like your MT4 because it's too monster truckish then just get some different tires/body for it. You say you want ground clearance so that basically rules out all 1/8 buggies. You don't want a true monster truck. The only thing left is truggies. Someone else already mentioned the Kraton which is basically the same thing as your MT4 only it's waterproof with different tires, body, and a wing instead of a wheelie bar.
thanks for the input. I haven't looked at Arrma so far at all, so this is great...that Kraton looks like it could do some damage...how is the performance of these things stock (6S)?
I saw that there is a truggy version of the EB48, the ET48, which looks pretty good as well.
I also came across the Losi XXL2-E...it might be again too much monster truck but damn that thing looks sexy i got to say...
Tech Legend
ET48 works well, however if you run truggy sized motors you can run into space issues available for the esc of anything but a Tekin RX8 Gen 2 if running sensored mode as the sensor ports get too close to the esc. Sensorless its fine, and, maybe with the mamba monster x it would be a non issue based on how the port comes out, but don't know.
Also, ET48 bodies unless they changed them are not durable at all, like garbage I hate to say it.
But it can take some serious power for sure.
IMO, you have one of, if not, the best out of the box MT's built in the past few years. The MT4-G3 checks all of those boxes. It is the LEAST monster trucky of all the MT's due to it's chassis layout and center diff.
The Arrma will probably be less durable than what you have now. Have you considered making a few changes to the MT4 to take the MT look away? A lower stance with a softer suspension, different wheels and tires, and a new body would make a world of difference looks wise. You might spend $100-$150 doing that, leaving you with a ton of budget left to try a second rig like a buggy or something.
I personally intend on buying a used rig at some point in the near future, the MT4 is at the top of my list. They look to be great trucks
I have an MT4 I'll sell ya cheap! The parts are scattered all over the Internet in the U.S. You break a few things on it and you have to scour the net and place multiple orders to get everything you need. Ever since TT changed distributors the parts support for the MT4 has sucked. It's a good truck but not great. The only reason it gained so much popularity is because it used to be the only RTR 1/8 scale capable of 6s on the market. The Brushless ERevo and Savage flux were available but for 2 to 3 hundred dollars more. The Arrma Kraton and Talion are priced cheaper than the MT4 and have similar performance and durability. They also seem to be gaining in popularity and are supported all over the net. My local Hobbytown even has a few of them on display.
Regarding the Arrma durability, because i dont know for sure. This is why i took them off my list;
Did they get get their random ESC failures figured out?
Premature servo failure?
Hinge pins still of concern?
Shock ends breakage?
Wing Mounts still have a high failure rate?
Rear shock towers bending?
Diff failure on 6s?
steering hubs?
unshielded bearings?
So far as i know, an MT4 would have me on the hook for;
doubling the shock towers
bracing the top of the shock towers to prevent chassis warp
Put oil in the center diff to keep the front tires from diffing out.
spare parts dealers are hard to come by.
I may very well take you up on that offer soon. Im getting finished with another quick project and then im off to the races on the new rig.
Diff failure on 6s?
steering hubs?
Diff failure on 6s?
steering hubs?
