If "stock" were a spec class, what parts would you specify?
Spec classes seem to be more common in on-road racing, where a control tire is often used at minimum, but there are controlled motor and chassis classes as well. "17.5" class is in trouble, with these ever-more-powerful batteries, lighter motors, and custom chassis parts eating up the budgets of stock racers.
If your club turned 17.5 into a "spec" class, where some components were restricted to specific brands/models, would you race it? Which components would you want controlled?
Some things that could be restricted: motor, ESC (blinky, or specific model), battery, tires and traction compound, chassis, etc..
Tires. Spec one that works ok(not great) and lasts long. The added power from people buying the very best becomes a non issue.
Keep in mind, this is racing. A person with a larger wallet will do better than their skill level. There is nothing you can do to change this.
Add 500 to 1,000 grams.
That takes care of spending a mint on the car and might encourage some people to break out older cars and full size batteries.
Tires, meh.
There's always stuff people will do at home that can't be tech'd.
Motor and batteries will always have to be tech'd.
Tires, meh.
Adding weight will just eat tires and the older cars were lighter (my XXX w/ full size Lipo was 1500g).
There's not much you can do to rubber that isn't immediately apparent by smell. If your tires smell funny, they stay in mod class..
You want to add 500-1000 grams but mention doing that to spend less money. Adding all that weight will contribute to more broken parts. It will also add stress to the motor, speedo, battery, tires, bearings, gears, and just about every single other piece on a buggy. A full size battery doesn't fit in either buggy I have. The last club race I was at the winner didn't have Pucks, cut gears, slipper eliminator, or ceramic bearings.
I guess it has been a month or so since people have had a thread saying how doomed 17.5 racing is.
Blake
Blake
My YZ-2 sits at 1526 right now. If I take out the full size servo and replace it with a low profile one there goes ten grams. The SMC oversize cap for a stock Justock cap reduces the weight by eleven grams. Putting the aluminum suspension hangers back on over the steel ones shaves off another eleven grams. I'm under 1500 when its out of the box.
When I ran my Cubed in Stock it was at 1513 with aluminum CVD's and a Speedy's eliminator and cut gears.
One buggy I spent money to make it heavier and the other I spent money to let the motor spool up faster.
This belief that it requires loads of money to compete in stock racing is baffling. It only takes a 17.5 and a speedo in blinky.
Just for laughs. Please explain how I can add 500-1000 grams onto my buggy.
Blake
Blake
spec tires (optimum tread pattern but one compound harder than optimum for longevity), no traction additive allowed, spec motor and esc (blinky).
if the stock/blinky/17.5 class is for a purpose, I believe it should be in attempt to have a somewhat level playing field for those that have little experience in the hobby to build their skills while trying to control the cost.
And sure you can wash your tires- with water. Why would you need anything else?
Blake
Blake
Maybe 1000 is a bit much. I agree.
I have 2 RB6's at 1600 and I've put on 300 at my local dry slick track to get it to hook.
I guess I just envision a stock class from the early 90's. Beginners and cheap cars. Start in stock and work your way up to mod.
All different types of cars.
I just got back into the hobby 1 year ago after a 21 year lay off and I really see that the grass roots, backyard burner, shade tree mechanic crowd is non-existant.
I see them every now and then. Giving it a go. Then they get overwhelmed with all the technology and give up.
What about rear motor only?
My son and I ran spec slash class when we got into it. That was a crazy good time. Cheap. Easy to tech.
$55 for suspension hangers and the oversize cap is spend, spend, spend? Shall I ask if your buggies are as they came in the box?
Blake
Blake
Spec Tires, Tire Sauce.
