Setup Station Reccomendation
Looking into getting a setup station. What's good for 1/10 buggy?
I'd probably be ordering from Amazon so hopefully nothing that is too hard to find.
Suggestions and opinions welcome.
The set also includes the Hudy Setup Book for Offroad.
http://www.hudy.net/xhudy/products/p...1&kategoria=64
Also get the Hudy Chassis Droop Gauge Support Blocks 20mm for 1/8 - LW(2) to use under the car to get repeatable measuring results.
http://www.hudy.net/xhudy/products/p...2&kategoria=64
Bent
I've looked at these setup stations as well. Can someone enlighten me as to why spend $150-200 on these things instead of parts or tires? I get that they help set up camber and toe-in/toe-out, but other than that? I'm not being negative here, just confused. I also would like to hear why you guys think a setup station is a good thing. Rather than just saying "I like brand X" could you maybe go a little more into detail?
Try measuring your camber with your camber gauge, rotate the wheel a 1/4 of a revolution and then measure again……..unfortunately your result will vary with this method.
With the setup station and 20mm support blocks you know you will get repeatable and reliable results each and every time
It's all about how serious you are about your racing……..for an occasional club racer it might be better spending the money on tires and track fees…..but for a serious racer with ambitions of improving every part of his or hers racing campaign it can be crucial
We use the Hudy setup stations for 1/10 buggy, 1/8 buggy, 1/10 touring car and 1/12 track.
Bent
Hudy is the best by far. I have the integy one, it works great but there's a little slop in it. Once you figure out how to compensate for that it's great. The toe isthe only place it's really apparent.
Any setup station makes life 10x easier! Use to take me a hr to completely setup a car from scratch, now it's 15-20 min tops.
I've owned the hudy and maybe I got a defective one but it seemed it was only good for setting accurate toe. I sold it for a loss and picked up a set of the de setup wheels. And a camber gauge works just fine at a fraction of the cost. Just set toe by eye and sub trim now
Hudy Universal Exclusive Set-Up System For 1/10 Off-Road Cars #108905
Bent
Bent
http://www.amazon.com/Universal-Excl...rds=Hudy+setup
Can I use this for 1/10 off-road?
I really wanted to use Amazon because I have quite a few credits there and a gift card credit as well. They only have this Hudy system:
To answer your specific question, the link you posted from Amazon is for the 1/10th scale onroad version, not the offroad version. Looks like the differences between the two is the manual that comes with it (onroad vs. offroad set up guide) and the acrylic top measuring plate is different, specific for onroad vs. offroad vehicles.
I'd recommend not getting the onroad version if you are planning on using it for offroad vehicles. But if you are in a pinch you could get the onroad version and buy the offroad top plate http://www.hudy.net/xhudy/products/p...&kategoria=381 and probably be just fine.
I am also considering getting the DE Racing setup system to use at the track in a pinch as well. http://www.deracing.net/store/index....product_id=474
Hope this helps!
I have been looking into getting a setup station myself. It is the only thing I lack to have that perfect setup. The integy one seemed to be a pretty fair deal because of the adapter system. It especially appeals to me because I would be using it for 1/10 SC and 2wd buggy now, but definitely plan on adding an 1/8 buggy by the summer if I am still taking it seriously. Would the integy system work on all 3 of these vehicles, and where exactly is the slop at? Or is it worth it to buy 2 separate hudy systems to perfect my setup?
I actually only use 2 adapters and that's bc my tekno has a larger hub size. Everything else I use 4mm which is standard nowadays in 1/10. It works on just about any car, just need the adapters to screw on.
Before when I was into onroad I have different sets of Hudy setup systems for different types of cars, so when I made the leap to 1/8 ebuggies I wanted to get one but there was no stock of the Hudy set anywhere so i got a set of Arrowmax. When using the setup system, one thing i notice is that camber setting seems to be off ie on the system it showed -2 degree with the tires on looks like positive camber, and by the use of a camber gauge i found the wheels were off at least by 2 degrees difference. No matter how I try the difference still there. To alleviate any doubt I also ordered a Hudy set, and the same difference persisted. I asked around the track and the consensus is that no one uses setup system at my track because they too experienced the same like I do, and they recommended wheel disc with camber gauge, and thus i have been using these ever since.
Never ever heard of a "defective" setup station for the last decade and almost every serious racer at the biggest offroad races use on and 99% of the onroad racers do.
You HAVE to use blocks under to get the correct ride height when measuring.
If not you will always chase repeatable results.
The setup station when used with the correct blocks will ALWAYS give you the same correct measurement.
Your camber gauge and setup wheels will not.
Been using setup systems for the last decade for all the classes we run (1/10 buggy, 1/8 buggy, 1/10 Touring car and 1/12 track) and never use a camber gauge anymore.
We always get repeatable accurate measurements each and every time.
For the serious racer the setup system is a very desirable tool for good reasons.
Bent
