INTECH Racing ER-12M 2.0 - Mid Motor 2wd Buggy
#61
#62
My new ER-12M 2.0 Lite is Dialed!
Took TQ by 7 seconds in the very first race with 205 entries.
This buggy is so much better then all the ER-12 versions before.
#63
Way to go GH. I'll see it first hand May20. Was the tq at ur home track FZRC
#64
#66
#67
I figured out a shock tip last week. If you use the tapered pistons, put a 3x0.1mm shim on the shaft before the piston to take up the slop between the e-clips. Otherwise the pistons will click as it moves up and down a little on the shock shaft.
Also I am now using 2x1.6 pitons with 550/400cts oils. Middle tower/outer arm for the front; and 1 out tower/middle arms for the rear. Avid red front and yellow rear springs are much softer then the stock springs also.
23mm/22mm ride height.
#68
Had a good performance with ER-12M 2.0 again!
#69
Tech Legend
for intech who right now is your top driver and what events will they be attending in the near future?
Is Intech actively looking to draw in top drivers to promote the vehicle, or, are they going the durango style model of not having a top flight racing team?
If doing the durango model, what benefits will the regular hobbiest see in reality?
I ask this last one in particular as right now if someone asked me what i am seeing as a benefit with durangos new model on not having a full on race team, I couldn't really comment that I see any benefit. It may actually be a negative as the cars aren't getting the recognition probably as much as before unfortunately.
#71
i have minimal play at that point
#72
The RTR weight depends on the servo/esc/battery/motor/wing/tires/wheels used. But mine is 1527g with Lunsford titanium turnbuckles and ball studs and direct drive with the 3-gear gearbox and MIP alum pucks and a 4000mah battery. With a 3200mah small battery, it is 1487g and under weight.
#74
