    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-08-2016, 06:19 AM   #1456
onadcr74's Avatar
Guys, I just wanted to take a minute and thank Frank Root and you all for all the help with this new car. Last night, we went to practice and my car was just still not right. I even went as far as to replace some components in the steering wheel in my radio as the wheel was slightly wobbly (I've used this radio A LOT and just happen to have some new parts laying around just for this) and I think this did help but the main thing that it was, and I am totally embarrassed at the fact, was front tires. For some reason, I got stuck on using this one set of front tires and never even paid any attention to them or thought about making a change, until last night. Sometimes, you know the answer, but it's hiding right under your nose! Made the swap and oh what a difference! I actually picked up 2.3 seconds average per lap by doing this and am very close to being in step with everyone elses' lap times. Now to get those times even lower. Thanks again to everyone, I think I can take it from here, I think, lol!
"Car was dialed, to bad it was the wrong number."
onadcr74 is offline   Reply With Quote
Old 01-08-2016, 06:39 AM   #1457
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Glad you found it! When someone asks me to take a look at their car, the first thing I look at is the tires, and I feel the foam. This is too often the one thing overlooked even though it is probably the most important
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-08-2016, 08:15 AM   #1458
Questions?? TLR 22 3.0 with 13.5T Motor
Any one running with a 13.5T motor?
I was wondering what gearing could be used. I know the manual specifies the 70 spur with a 25 pinion, but that would require going with the old slipper pads.
It seems that it would be possible to use the 76 spur with a 27 pinion, since it would have a similar external drive ratio (70/25 = 2.800 vs. 76/27 = 2.815).
Any thoughts?
DJPod is offline   Reply With Quote
Old 01-08-2016, 08:37 AM   #1459
TLRacing
Frank Root's Avatar
Any thoughts?
Would be the same gearing, motor placement would be the only difference. We usually try to gear to keep the motor closer to the diff gear, but you'll probably be fine with the 76 spur.
Old 01-08-2016, 12:46 PM   #1460
What are you guys doing with your antenna? If you're not running an antenna tube through the body, how/where do you secure the antenna?
Callaway is offline   Reply With Quote
Old 01-08-2016, 01:25 PM   #1461
I use the heavy duty velcro and put it on the side of my receiver, then weave the wire back and forth through the velcro to hold it to the receiver.
chris arnold is offline   Reply With Quote
Old 01-08-2016, 01:53 PM   #1462
Davidka's Avatar
Trader Rating: 75 (100%+)
I melt a 90* bend in my antenna tubes so that the antenna stays under the body.
Old 01-08-2016, 02:03 PM   #1463
Me too.
greener74 is offline   Reply With Quote
Old 01-08-2016, 02:58 PM   #1464
Casper's Avatar
Trader Rating: 33 (100%+)
Using spektrum receiver I just coil it up on top of the receiver and leave it there. No range issues at all. of course if you use a coax antenna you can't do this.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-08-2016, 03:35 PM   #1465
If you do that, doesn't that give you a different power curve. Even though the ratio is almost the same?
135mikefox is offline   Reply With Quote
Old 01-08-2016, 04:44 PM   #1466
So I've been running this buggy for the past 2-weeks w/ 17.5t on indoor high bite using slicks. This thing has been on point. I decided to drop a 7.5t into this bad boy today and WOW! It's just as easy to drive mod as it is stock. It did however develop a bit of a push, my guess is because I set this car up for stock racing and not mod. Not a big issue tho, just need to tinker with the set up a bit and she will be on point again. I have ran this buggy and the B5M both in mod and this thing straight out the box just destroys the B5m in so many ways. Good job TLR!
If your not first your last! Shake N bake!
FPMX772 is offline   Reply With Quote
Old 01-08-2016, 05:05 PM   #1467
Jack Bonhomme's Avatar
The antenna fits within the body cabin. Mine is around 2" tall standing straight up. The body is wide enough to house the antenna within the window area without sticking out of the body itself. It just rubs a little bit on the side of the window. The remaining antenna wire is coiled near the receiver.
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 01-08-2016, 05:15 PM   #1468
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
i wrap my antenna around a hex wrench... then slide shrink tube over it like in the picture and servo tape it to the side of the rx.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 01-08-2016, 05:27 PM   #1469
rcgod's Avatar
Trader Rating: 27 (100%+)
Just scaled my car with pucks, shorty, slipper eliminator and ti turnbuckles.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-08-2016, 06:06 PM   #1470
this is a stupid question, and not specific to this buggy, but how come the wing is clear? i see it on a lot of buggies where the wing is unpainted. Is there a reason for this?
rekim is offline   Reply With Quote
