    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree13Likes
Old 12-26-2015, 12:05 AM   #1171
Trader Rating: 21 (100%+)
Originally Posted by psycho02 View Post
Is the pink spring (tlr 5168) a low frequency spring? Can you buy the low frequency springs individually or do you have to buy the whole set?
Lf springs are only available in sets. 5168 is a standard spring.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 12-26-2015, 03:40 AM   #1172
PIHGUAM1's Avatar
Does anyone know which Jconcepts front wing fits on the TLR 3.0?
All of them on their website are for the AE buggys.
Pacific Island Hobbies
Guam's R/C Headquaters
PIHGUAM1 is offline   Reply With Quote
Old 12-26-2015, 07:23 AM   #1173
Trader Rating: 315 (100%+)
B5m narrow.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 12-26-2015, 08:07 AM   #1174
Jpdanger's Avatar
Originally Posted by Jack Bonhomme View Post
I'm getting my kit next week. Anybody know for sure if the TLR 70t spur gear fits this kit? I'm taking the 17.5 gear out of my 2.0 and just want to make sure I can replicate my setup.
You can use an AE spur gear if you trim a little bit off the slipper pads so that they fit in the slot on the gear.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 12-26-2015, 08:08 AM   #1175
Suspended
Trader Rating: 61 (100%+)
AE parts on a TLR car?
See sig.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 12-26-2015, 08:13 AM   #1176
STLNLST's Avatar
B5 narrow
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-26-2015, 08:15 AM   #1177
Jpdanger's Avatar
See sig.
You're right. I did buy the wrong car and then I bought the 3.0. I just happen to have an AE 69T spur gear readily available.
Old 12-26-2015, 08:20 AM   #1178
Broke my rear camber block. Came down hard on 1 rear wheel then tumbled a ways. Lhs wont have the part for a while because of the holidays.
sgtlt is offline   Reply With Quote
Old 12-26-2015, 08:43 AM   #1179
Trader Rating: 67 (100%+)
In the process of building my kit. Maybe I'm just spoiled with my Tekno's and Kyosho's, but the fit on these parts leaves A LOT to be desired. Trying to get a free moving suspension requires filing, reaming, and several assemble/disassemble sequences to get it right.
This is my first Losi, but has this been typical of all of their kits? I have the suspension moving freely, actually really good now--but wow! Quite a bit of work to do so! I know I tried to help one of the kids this week with his at the track when he brought it to me with the front suspension so tight it barely moved.
"Wow he's really fast isn't he????.....Yeah but he's Stupid"
lyork is offline   Reply With Quote
Old 12-26-2015, 08:53 AM   #1180
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
my kit was slightly tight, if your front shoulder screws are not straight, the front end will bind..
myself i would rather it be a little tight, work in and not be sloppy, then have it be all sloppy and what not
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 12-26-2015, 09:09 AM   #1181
The front shoulder screws were the issue on his car last week, we reamed the a-arms and it freed it up quite a bit, but still very, very stiff.
I too would have it be a bit on the snug side and wear in, but that WAS NOT the case with my kit. Of course, 33 years as a CNC programmer makes me wish all things were as precise as possible. I'm simply saying that one cannot expect to assemble this kit without a fair amount of work on the plastic suspension pieces to ensure a properly handling car. A small smooth cut file and the appropriate reamers, along with patience, will yield the results needed.
Old 12-26-2015, 09:24 AM   #1182
Davidka's Avatar
Trader Rating: 76 (100%+)
I found that a practice run or two was all that was needed.
Old 12-26-2015, 09:37 AM   #1183
What is the downside of adding the spacer to the rear axle? I know it creates more forward bite because the dog bone plunged further in, which also helps keep it from falling out. But at the expense of what?
MrLean is offline   Reply With Quote
Old 12-26-2015, 09:40 AM   #1184
Originally Posted by Jason Snyder View Post
Hey Just wanted to say merry christmas to everyone and let you know i just uploaded the 22 3.0 review video!
+ YouTube Video
Jason I always love your reviews. I wish you would have mentioned the adjustability of this car vs its predecessor and competitors though. Things like the battery strap, VLA front arms and the pill inserts for rear toe and anti squat were major reasons I chose to buy this car.
Building it now, hope it drives as good as everyone says!
Old 12-26-2015, 12:05 PM   #1185
Jason Snyder said he broke his too in the vid. Seems like an easy fix for tlr, but i'm sure the aftermarket has thier eyes on this issue.
inpuressa is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
