    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 12-24-2015, 10:47 PM   #1156
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Jason Snyder View Post
Hey Just wanted to say merry christmas to everyone and let you know i just uploaded the 22 3.0 review video!
+ YouTube Video
Nice review. As always keep up the great work.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-25-2015, 12:11 AM   #1157
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Casper View Post
I did a little gear diff testing since I have them I liked a 2 gear (take out 2 spider gears) and 20K fluid. Need to do some ball to gear testing but this setup felt pretty good going around the track and lap times were there.
Wow Casper, that's what I have in my 3.0 now but with 4 gears. 20 k felt like a snug gear diff and is working well.
I had to use the axle spacers though, I was hearing random gnarly sounds and saw that the bones were almost coming out at 29mm stroke shock setting.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 12-25-2015, 01:36 AM   #1158
tsair's Avatar
Frank, was the slipper spring updated for the 3.0? The part number looks the same, but I've heard some people say it is stiffer for the 3.0.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-25-2015, 10:39 AM   #1159
mo
mo's Avatar
Mounted up a JC Silencer for the RB6 today on my TLR 22 3.0. Fits well and is higher up in the back so you don't have to cut a hole in the body if you use my fan mount brace.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 12-25-2015, 11:29 AM   #1160
RedBMaster's Avatar
Originally Posted by Davidka View Post
How well does that fit? I like the look of the Finnisher.
It fits OK, the body flares out a bit much on the sides. I'm waiting on the official s2 bodies to drop, talking to JC it should be within the next week or two
RedBMaster is offline   Reply With Quote
Old 12-25-2015, 12:53 PM   #1161
Trader Rating: 315 (100%+)
Everybody has there preferences but the stock body is awesome.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 12-25-2015, 03:06 PM   #1162
If you find that your shorty packs have a tight fit, here's a small tip. I added 1mm washers between the waterfall and chassis that's held down by the two screws. Raising this will prevent the batt holder from bowing a lot, and also allowed me to slide the batt all the way back.
inpuressa is offline   Reply With Quote
Old 12-25-2015, 03:35 PM   #1163
shadowracer24's Avatar
Did this with mine as well. Saw that the cover was bowing so much it was actually flexing the rear of the chassis. Something you might want to check.
shadowracer24 is offline   Reply With Quote
Old 12-25-2015, 03:54 PM   #1164
Jack Bonhomme's Avatar
I'm getting my kit next week. Anybody know for sure if the TLR 70t spur gear fits this kit? I'm taking the 17.5 gear out of my 2.0 and just want to make sure I can replicate my setup.
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 12-25-2015, 03:58 PM   #1165
Davidka's Avatar
Trader Rating: 76 (100%+)
Yes but you must use the old style friction pads with the 70t. The pads included in the kit don't work.
Old 12-25-2015, 06:52 PM   #1166
Is the pink spring (tlr 5168) a low frequency spring? Can you buy the low frequency springs individually or do you have to buy the whole set?
psycho02 is offline   Reply With Quote
Old 12-25-2015, 07:36 PM   #1167
Gonz13's Avatar
Last time i checked you can do both- get a whole set OR get them in pairs. The set works out better in terms of value for money.
Gonz13 is offline   Reply With Quote
Old 12-25-2015, 08:18 PM   #1168
Davidka's Avatar
I don't believe the LF springs are available in pairs. Not in the US anyway.
Old 12-25-2015, 08:37 PM   #1169
Thanks, I knew about the pads. Next topic, I haven't seen any pics of an antenna mount on the chassis. Is there still a mount on the plastic side guards like on previous 22's? I like to run a short antenna tube on my vehicles.
Old 12-25-2015, 09:12 PM   #1170
Davidka's Avatar
Antenna mount is still in the sideguards.
The old slipper pads are compatible with the kits slipper plates.
