    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree13Likes
Old 11-06-2015, 08:11 AM   #91
Frank, first off thanks for being active and helping/informing. Can't wait to get my hands on this beast. Couple questions...will my 22 2.0 aluminum rear hubs work on the 3.0? And will my jconcepts Ti front axles work on the 3.0? Also will setup sheets be released same time as kit or soon after? Thanks much
killshot01 is offline   Reply With Quote
Old 11-06-2015, 08:50 AM   #92
Motorman007's Avatar
Trader Rating: 78 (100%+)
http://www.circusrc.com/2015/11/unde...el/#more-32740
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 11-06-2015, 09:09 AM   #93
Trader Rating: 22 (96%+)
i got a chance to see this car in action last night at coyote hobbies raceway in victorville. all i can say is that the car impressed me. was going to buy a b5m lite tomorrow for redy race prep and i decided to hold off to buy this instead, much higher quality of parts and a far better design from an engineering stand point. ive been in the hobby for 4 years now and always ran AE, but this car has changed that
dezertranger96 is offline   Reply With Quote
Old 11-06-2015, 09:17 AM   #94
Trader Rating: 23 (100%+)
Originally Posted by stelio279 View Post
I love all the obviously well thought out engineering. For a non-elite club racer like me, I'm more impressed with attention to things like designing for maintenance, durability, simplicity, interchangeability of components... Really appeals to my mechanical engineering side. The rear roll-center adjustement is a brilliant example.
I'm curious to understand why a shorter front arm would be better in someconditions... The rest of the geometry beign the same, you would intuitively think that a wider front track would always be more stable, no? Why not always design to max ROAR width front and rear?
In the manual a page was included highlighting what the VLA changes do, and why you would want them!
Sponsors- Team Losi Racing, Pro-Line, Orion, Nitrotane, Horizon Hobbies, Avid
electrickid is offline   Reply With Quote
Old 11-06-2015, 09:38 AM   #95
countdown to Jconcepts releases a unecessary carbon fiber battery strap and claim its the only reason mayfield wins races.......5....4....3...
fjelltorsk is offline   Reply With Quote
Old 11-06-2015, 09:43 AM   #96
Any chanc of a gear diff option?
Dave Hoare
Sponsors: Visa....
SuperDaveNT is offline   Reply With Quote
Old 11-06-2015, 09:44 AM   #97
Do the wheels match the IFMAR 2016 offset spec?
"Speak only if it improves upon the silence."
http://goo.gl/MFfbzr - My ever-updating comprehensive spring rate chart
Bracket is offline   Reply With Quote
Old 11-06-2015, 09:51 AM   #98
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Frank Root View Post
JC Johnson has a 22 3.0 and will be at Tacoma RC on Monday and Tuesday running so you can check it out
Thanks Frank, unfortunately I only get to go on the weekends. And quite frankly, JC Johnson can make a box stock slash with outdoor tires look good. He's a beast with every car I have seen him drive. He's a quality guy to have on your team. Excited to see him run the 3.0.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-06-2015, 10:17 AM   #99
I believe Frank said earlier that this was the reason why they changed the hex, so I would say yes.
Old 11-06-2015, 10:18 AM   #100
Casper's Avatar
Trader Rating: 34 (100%+)
Already an option.
http://www.losi.com/Products/Feature...rodId=LOSA2954
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-06-2015, 10:23 AM   #101
Suspended
Trader Rating: 61 (100%+)
AE fan boy checking in.
I want this car.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 11-06-2015, 10:28 AM   #102
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
VLA doesn't change track width, only the outer suspension pivot point, which affects the geometry and handling.
Yes, alum rear hubs will work.
Yes, they will fit, but we will not have 10mm wheels forever, a limited supply then you'll need to switch to 12mm. We already have 12mm aluminum front axles on their way with the cars.
Probably before it ships, that's the goal.
Not sure that rule is going to go through. It would make several manufacturers design new front suspensions for the wheel off-set. None of the manufacturers are happy about it, and this may not come to fruition.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-06-2015, 11:41 AM   #103
RedBMaster's Avatar
We focused on performance and durability. Aluminum hexes add a lot of cost and NO performance or durability gain. If anything, the molded hexes are lighter than clamping hexes and reduce rotating mass which will increase performance.
I also added a bit to the first post, so be sure to check that out!
Ah, makes sense. Thanks man!
RedBMaster is offline   Reply With Quote
Old 11-06-2015, 12:46 PM   #104
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Troll much
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-06-2015, 01:08 PM   #105
TLRacing
Frank Root's Avatar
Originally Posted by racer1812 View Post
Troll much
