    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-13-2015, 11:12 AM   #991
Originally Posted by greener74 View Post
Here it is with some dirt on it.
What tires are those?
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 12-13-2015, 12:03 PM   #992
tony montana's Avatar
Trader Rating: 65 (100%+)
Just comifining the wheels that come with the kit are 2.2 correct
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 12-13-2015, 12:25 PM   #993
Dustin's Avatar
Trader Rating: 113 (100%+)
Yes they are.
Dustin Thompson
HB Racing
AKA Racing
Dustin is offline   Reply With Quote
Old 12-13-2015, 01:42 PM   #994
HotRod127's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Jspires688 View Post
I ran my 3.0 for the first time last night traction was abnormaly high last night for my local track. But coming from associated and kyosho t the 3.0 i really liked the buggy it done lots of stuff really good but running the kit setup i had a horriable on power push. I moved the batterey all the way foward, changed to black ae front springs and changed the front inner ballstuds to 1mm and still never got it totally fixed dont really know where to go next?
i had the same deal going on last night and i tried a little more front droop and it seemed to help big time
Kyosho RB6.6/ Kyosho ZX6.6/ Kyosho RT6/ Kyosho America- Peak Racing Products- Team Orion- AKA- JTP- 92zerodesigns
HotRod127 is offline   Reply With Quote
Old 12-13-2015, 02:10 PM   #995
I thought about that after the race on my way home but it was a little to late then. Others have told me i should have tried the opposite and put mor limiters in the front shocks so im not sure what the answer is but i will keep searching. Thanks for the reply
Jspires688 is offline   Reply With Quote
Old 12-13-2015, 03:35 PM   #996
Guch's Avatar
Default Nice wire/layout job
aematt and Hotrod127 did a really nice wire jobs on there buggies.
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 12-13-2015, 03:59 PM   #997
Front aka 3 rib, rear duratrax shotguns. C3 super soft.
greener74 is offline   Reply With Quote
Old 12-13-2015, 04:00 PM   #998
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
yesterday was my first race with my 3.0. i have driven the original 22, and the 2.0 in both rm and mm versions. i was never comforatable with the 2.0mm the car was awesome in rm however.
this car is flat out awesome. i raced it at trackside in milw. and started with the setup given to me by jp richards, and i ran in 17.5 class.
i will say this, to anyone on the fence, this car is wonderful. i could drive the car hard without fear of the car doing something strange. i always drove the 2.0mm scared, and would make mistakes due to being to cautious. not with this car.
very good job frank and tlr.
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 12-13-2015, 07:22 PM   #999
dski's Avatar
I believe if you increase front droop so the front shocks are longer you would make the car push more on power as it would transfer more weight to the rear (exaggerated by moving the battery forward as there is more weight up front to transfer)
so yes, you would want to try more limiters.
dski is offline   Reply With Quote
Old 12-13-2015, 09:32 PM   #1000
Trader Rating: 8 (90%+)
Thats what i thought but was getting horrible on power push. Then some of the fast guys at the track came by and told me that i had too little droop, so i removed the limiters, had alot more droop and it helped!! I was so confused... Still am. I don't understand setups at all... Zilch. Its so complicated.
juicy74 is offline   Reply With Quote
Old 12-13-2015, 09:34 PM   #1001
tsair's Avatar
Yah, that's weird. Maybe the car wheelies so much the front wheels are coming off the ground a bit with the shorter droop?
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-14-2015, 12:26 AM   #1002
That did cross my mind but coming out of 180s, the slightest input of power would result in going wide so that kind of power wouldn't result in a wheelie. Maybe I should go harder on the rear shocks to limit the weight transfer?
Old 12-14-2015, 01:02 AM   #1003
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Just checking in, seems that all is pretty much well, and no major outstanding questions. I will be out of the office testing all week, then I'll be out for Christmas week on vacation. I may check in periodically, but don't wait too long for a reply from me. One of the other fine gentlemen on here will get you sorted out
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 12-14-2015, 01:10 AM   #1004
Got my car out for the first time today, drives really good, moving the battery forward about a fingers length away from the waterfall was really the only adjustment i made.
Running the car in 17.5, weight is at 1565, geared 32/72 with the schelle slipper.
Kas10Racing is offline   Reply With Quote
Old 12-14-2015, 05:34 AM   #1005
bcablig's Avatar
Trader Rating: 97 (100%+)
If traction is that high, couldn't you try a little less rear toe?
bcablig is offline   Reply With Quote
