    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree13Likes
Old 11-05-2015, 09:40 PM   #76
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Hey Frank,
How is the stock set up? Is it ready for hard packed and turf or average out door track?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 11-05-2015, 09:53 PM   #77
Trader Rating: 52 (100%+)
Can't wait to get mine
RB5SP is offline   Reply With Quote
Old 11-05-2015, 11:22 PM   #78
It's been almost fifteen years since I have owned a Losi vehicle, this will be my first TLR. Definitely like what I see in this chassis layout and design, hoping it drives as good as it looks.
Fasttrak is offline   Reply With Quote
Old 11-05-2015, 11:27 PM   #79
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by BlackStarRacing View Post
Hey Frank,
Med-High Grip indoor clay.
From what I've heard from team drivers today.... better...
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-06-2015, 01:05 AM   #80
RedBMaster's Avatar
Car looks amazing! Why does it come with plastic hexes tho?
RedBMaster is offline   Reply With Quote
Old 11-06-2015, 01:21 AM   #81
TLRacing
Frank Root's Avatar
We focused on performance and durability. Aluminum hexes add a lot of cost and NO performance or durability gain. If anything, the molded hexes are lighter than clamping hexes and reduce rotating mass which will increase performance.
I also added a bit to the first post, so be sure to check that out!
Old 11-06-2015, 01:41 AM   #82
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
Looks good. Wish the ball cups had holes for a driver though. The AE ball cups (updated ones that don't bind) are awesome.
RC*PHREAK is offline   Reply With Quote
Old 11-06-2015, 05:34 AM   #83
Euge's Avatar
Nice job on the video as always, Frank. Very polished and you communicate the new features very effectively. I'm going to pre-order a kit today.
My favorite part of the video is at 17:17 when you say "We've gone transverse!"
Originally Posted by Frank Root View Post
Euge is offline   Reply With Quote
Old 11-06-2015, 05:47 AM   #84
Trader Rating: 20 (100%+)
Got to love haters and trolls!!
Randy
RandyJones is offline   Reply With Quote
Old 11-06-2015, 06:24 AM   #85
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Car looks great Frank!
RCBuddha is offline   Reply With Quote
Old 11-06-2015, 06:24 AM   #86
jgroenhof's Avatar
I simply punch holes in mine using my tire/leather punch.
http://www.petitrc.com/setup/losi/TLR2959_Uses/3.jpg
jgroenhof is offline   Reply With Quote
Old 11-06-2015, 07:13 AM   #87
Nice tip !
https://www.facebook.com/kyrcrc/
slowsrc is offline   Reply With Quote
Old 11-06-2015, 07:59 AM   #88
I love all the obviously well thought out engineering. For a non-elite club racer like me, I'm more impressed with attention to things like designing for maintenance, durability, simplicity, interchangeability of components... Really appeals to my mechanical engineering side. The rear roll-center adjustement is a brilliant example.
I'm curious to understand why a shorter front arm would be better in someconditions... The rest of the geometry beign the same, you would intuitively think that a wider front track would always be more stable, no? Why not always design to max ROAR width front and rear?
stelio279 is offline   Reply With Quote
Old 11-06-2015, 08:07 AM   #89
johnnyshore's Avatar
Trader Rating: 72 (100%+)
Agreed 110%...pop'em off a couple times for adjustments/repairs, and they almost always start failing during a race. Seems that TLR cars are about the only ones at my local track popping off ball cups anymore.
Car looks good other than the cups.
John Schroer
Check out Shamrock R/C Raceway
Minnesota's only outdoor astroturf off-road track!
https://www.facebook.com/ShamrockRC/
johnnyshore is offline   Reply With Quote
Old 11-06-2015, 08:07 AM   #90
Davidka's Avatar
Trader Rating: 76 (100%+)
VLA does not alter the track width at the wheels, only the pivot to pivot length of the arm.
