    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 11-28-2015, 05:17 PM   #511
Trader Rating: 121 (99%+)
Lhs got theirs in today. Got plans for Tonight but going to be building tomorrow.
skoalisbad4me is offline   Reply With Quote
Old 11-28-2015, 05:39 PM   #512
vito's Avatar
hows the bulid
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 11-28-2015, 07:38 PM   #513
Mdawson1962's Avatar
Originally Posted by TitanBurns View Post
In anticipation of the new car I have rebuilt the kit a few more times in my head. I noticed int he online manual there are no mention of servo spacers? Is there a chart somewhere to save me time measuring lol... or if some-one already has one built with a savox 1257 lmk if you had to use any spacers.. thanks in advance
I put mine in without spacers , had to remove the cap head screw and replace with a button head screw because the cap head hit steering ran car today no problems
Mdawson1962 is offline   Reply With Quote
Old 11-29-2015, 09:46 AM   #514
chevydc44's Avatar
Trader Rating: 31 (100%+)
Are the kits available? If so where can I purchase one?
chevydc44 is offline   Reply With Quote
Old 11-29-2015, 09:55 AM   #515
bcablig's Avatar
Trader Rating: 97 (100%+)
Was the car designed around a full size servo or a "Low Profile" servo, as far as weight distribution.
Better yet, what's the servo of choice?
bcablig is offline   Reply With Quote
Old 11-29-2015, 12:06 PM   #516
trutledge83's Avatar
Doe anyone know if horizon is shipping the kits?
I placed mine on preorder on Nov 5th and I haven't heard anything!
Any news? Anyone received one from horizon?
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 11-29-2015, 12:12 PM   #517
vito's Avatar
my shop order it on last monday be here wensday or trursday
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 11-29-2015, 12:26 PM   #518
This question may have been answered in this thread already, but does anyone know if this kit come with the 2.2 or the 2.4" wheels?
If your not first your last! Shake N bake!
FPMX772 is offline   Reply With Quote
Old 11-29-2015, 12:30 PM   #519
Kit comes with 2.2 wheels. 1 set white, 1 set yellow
sgtlt is offline   Reply With Quote
Old 11-29-2015, 12:42 PM   #520
Ok thanks for the info...Trying to buy all the goodies prior to receiving the kit
Old 11-29-2015, 01:16 PM   #521
svndayNZ's Avatar
Trader Rating: 20 (100%+)
I ran on a notoriously low grip track this weekend. I kept the stock set up. I'm running Hobbywings V10 8.5 with a V3.1 speedy - 0 Boost but 10 deg turbo.
The car was super slippery with Proline Suburbs on the rear end, you'd lightly touch the power and you were swapping ends.
Keen to hear thoughts on a dialled low grip set up!
svndayNZ is offline   Reply With Quote
Old 11-29-2015, 01:33 PM   #522
Picked my kit up yesterday, got home got the front end done then the power went out due to ice storm, still out. Just my luck.
Old 11-29-2015, 01:35 PM   #523
Gonz13's Avatar
+1. MM cars are typically best for higher grip tracks. Perhaps set-ups for this car to perform best on low grip should br skewed towards making them handle like a RM?
Gonz13 is offline   Reply With Quote
Old 11-29-2015, 01:35 PM   #524
I am no set up expert but maybe start with some tires with small pin tread ?
Old 11-29-2015, 01:58 PM   #525
I called horizon on Friday the sales rep told me that they haven't shipped them yet that they would go out early next week. So hopefully he is right
fantomdude is offline   Reply With Quote
