    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 11-27-2015, 05:37 PM   #496
Thanks everyone for the tips.
Just getting back into RC i have a Losi XXXSCB, mini 8ight and LST XXL2-E, son has a Traxxas 2WD Stampede.
Have been having some fun at the Knox RC track and noticed everyone is driving 1/10 buggy, hence the reason for buying the TLR 22 3.0.
As for stock or mod I'm unsure, my son is only 10 y/o and i would class myself as an OK driver so would probably start with stock, is that what you guys would recommend?
Regards Rob.
aussiedriver is offline   Reply With Quote
Old 11-27-2015, 06:34 PM   #497
68pontiac's Avatar
Originally Posted by aussiedriver View Post
I would class myself as an OK driver so would probably start with stock, is that what you guys would recommend?
Regards Rob.
Definitely stock. 17.5 motors are getting faster all the time and the buggies and tracks are getting better just as quickly. At least at my local track the stock buggies are just as fast if not faster than mod buggies because the powerband is more controllable and it's easier to put the power down without losing control.
However, having said that I'm not a big fan of stock motors. I don't like the narrower powerband of stock motors and prefer having "extra" power when I need it. If I don't get a corner just right and don't have enough momentum to hit the next double I like having a mod motor to give me the extra grunt that I missed out on. Stock isn't for everybody - it takes a lot of skill to keep momentum and corner speed high to keep the "slow" motor moving the car at fast enough speeds.
My personal recommendation is to stick with stock motors and work on making sure you can run a race without crashing and dialing in a good setup. When you feel confident in your abilities you can then add some modified power and see how well it works out for you. Think of it this way: most racecar drivers don't learn how to race by starting in a formula-1 car, they probably started in a go-kart.
68pontiac is offline   Reply With Quote
Old 11-27-2015, 06:49 PM   #498
motorcitymatt's Avatar
Originally Posted by Jpdanger View Post
Matt, I always enjoy reading your write-ups as they are very informative and thorough.
Thanks JP. I try to pass along info and experiences when I can here. I have learned so much from others on this site. It is a great resource and community.
Did you get rid of your KF2?
I'll PM you about that, it is a little off-topic for this thread.
And I forgot to mention in an earlier post that I completely agree with TLR's decision to not include aluminum clamp-on hexes in the rear. On other kits I have built that use plastic hexes, they have a tendency to fall off the axle and next thing you know you are looking for the pin that slid out too. Also, the plastic hexes of other kits have often made it difficult to get the wheels on without lining things up just right. The plastic hexes in this kit have neither of those problems. They stay put on the axles and the wheels go right on with little fuss. I can honestly say I will not be buying clamp-on aluminum hexes.
Schumacher Cougar KC, Tekno EB410
Larry's Performance R/C's in Shelby Twp, MI
DiscountRCStore.com (The best online hobby shop)
motorcitymatt is offline   Reply With Quote
Old 11-28-2015, 09:13 AM   #499
trutledge83's Avatar
MIDDLE OF DEC!!!!!
NOOOOOOOOO!!!!
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 11-28-2015, 09:38 AM   #500
gprcmx312's Avatar
Just to be sure. The front wheels from the 2.0 will not fit the 3.0. I know this was discussed earlier but I am slightly confused what part of the wheels is different. I don't want to sell all my sets of wheels from my 2.0 and then find out I could have used them on the new car.
gprcmx312 is offline   Reply With Quote
Old 11-28-2015, 10:06 AM   #501
In anticipation of the new car I have rebuilt the kit a few more times in my head. I noticed int he online manual there are no mention of servo spacers? Is there a chart somewhere to save me time measuring lol... or if some-one already has one built with a savox 1257 lmk if you had to use any spacers.. thanks in advance
TitanBurns is offline   Reply With Quote
Old 11-28-2015, 10:47 AM   #502
vito's Avatar
is the body pre cut
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 11-28-2015, 11:22 AM   #503
SCRAFAN's Avatar
2.0 wheels will not fit, they are 10mm hex and the 3.0 are 12mm. you can put the 2.0 axels on your 3.0 and use the wheels.
Shortcoursehobbies.com, Losi
SCRAFAN is offline   Reply With Quote
Old 11-28-2015, 11:51 AM   #504
Woulvesbaine's Avatar
Frank let me drive his car the other day at OCRC. TLR did an excellent job with this car. It has tons of steering yet feels planted. I prefer it to the B5 cars that I have driven.
I suspect this will become the car to beat. Good job, TLR.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 11-28-2015, 12:23 PM   #505
My kit just arrived at the LHS, going to pick it up after work and get started on the build.
sgtlt is offline   Reply With Quote
Old 11-28-2015, 12:40 PM   #506
Davidka's Avatar
Trader Rating: 76 (100%+)
Originally Posted by trutledge83 View Post
MIDDLE OF DEC!!!!!
NOOOOOOOOO!!!!
Bear in mind, that is an estimate if you place a new order, now. If you have a backorder in place already, you will almost definitely get your kit sooner. You can call Amain or live chat and they can give you a better idea.
Old 11-28-2015, 12:52 PM   #507
gprcmx312's Avatar
Thank you for the clarification.
Old 11-28-2015, 01:36 PM   #508
vito's Avatar
my look like trusday or wesnday hope it a good build what the wheel yellow
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 11-28-2015, 02:43 PM   #509
The car comes with a set of yellow and white wheels
fantomdude is offline   Reply With Quote
Old 11-28-2015, 02:46 PM   #510
brian cox's Avatar
Trader Rating: 58 (100%+)
is the body pre cut
Yes it is
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
