    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree13Likes
Old 01-09-2017, 03:10 PM   #4111
johnny44's Avatar
Originally Posted by Frank Root View Post
The X-Factory conversion is work the $... car definitely performs better. Lands noticably better too, I think partly since it braces things up a bit.
Once I get back to work and stop spending so much money, lol. I'll be getting the LD kit and both front and rear X-factory setups.
johnny44 is offline   Reply With Quote
Old 01-09-2017, 05:25 PM   #4112
Stanton's Avatar
Originally Posted by Callaway View Post
Duo the lightweight bodies from the original laydown kit have a problem with paint peeling off the inside? I've never had that problem before, but it's peeling like crazy. I also used Spaz Stix instead of the paint I normally use, so there's two variables in there. Unless I forgot to wash the body, I'm thinking the lightweight body is the problem.
Mine peeled like crazy and I never have that problem. Painted another JC Silencer and not one little chip. That is really weird that the lexan would do that as I paint tons of body without this issue.
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 01-09-2017, 05:34 PM   #4113
tony montana's Avatar
Trader Rating: 65 (100%+)
When will the xfactory kit be back in stock? I really think it's gonna help the 3.0 a bunch. I have driven b6's and xray's with the shocks on the front of the rear arm and I really prefer it.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 01-09-2017, 05:39 PM   #4114
Stanton's Avatar
You can sign up on Amain and they will email you, but I see no date.
Old 01-09-2017, 06:05 PM   #4115
Trader Rating: 24 (100%+)
You can order direct from Xfactory. They are constantly posting on Facebook about shipping out all their orders and the status of their backlog. That seems to be the quickest way to get their popular products.
AMessy is offline   Reply With Quote
Old 01-09-2017, 06:53 PM   #4116
Thanks just made my order at xfactory
Old 01-09-2017, 07:13 PM   #4117
What's the front X factory setup. I only saw the rear tower brace on their site.
shark2288 is offline   Reply With Quote
Old 01-09-2017, 07:40 PM   #4118
I wonder if it's just the flex of the body causing problems unless the paint is both adhered really well and applied really thin. I did just get an S2 body in, and I'm not using Spaz Stix. Back to trusty Duratrax for me!
Callaway is offline   Reply With Quote
Old 01-09-2017, 07:45 PM   #4119
This is what I asked for for Christmas... I got other, more expensive things, but I was really hoping to get this brace!
I wonder if most of the benefit is really from the stiffened tower, and if the shocks on the front have a little less or more subtle impact. I like what TLR was trying to do with the shock tower, but it's obviously compromised the stiffness. I'm thinking it jumps better with the brace mostly because you're eliminating undamped flex of the tower, thus letting the shocks totally control the landing with no snap back from the tower.
Just thoughts! I need to get one on order.
Old 01-10-2017, 03:02 AM   #4120
Default X-factory set up
With the xfactory kit getting the shocks to the front of the arm. My question is what set up is the best for this or is it the case that any set up sheet will work and the shocks in front will make it better again?
Cub86 is offline   Reply With Quote
Old 01-10-2017, 06:51 AM   #4121
derekbsmith's Avatar
Trader Rating: 23 (96%+)
the 22 3.0 now has a gear differential? no more ball diff? wow...: ) very cool!
http://www.tlracing.com/Products/Def...odID=TLR332067
TLR 22 2.0 Tekin RS + D4 17.5T
AE FT b4.1 Castle SW2 + SMC 9.5T
TLR Ten-SCTE '1.5' MMxpro + HW 4000kv
TLR Ten-SCTE '3.0' Tekin Rx8 + 4300kv
TLR 22 3.0 Tekin Rsx + Reedy M3 7.5T
derekbsmith is offline   Reply With Quote
Old 01-10-2017, 08:55 AM   #4122
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Still a ball diff of course, the gear diff is an option for really high bite and carpet/astro tracks.
Remove 2mm of stroke and start there.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-10-2017, 10:07 AM   #4123
The X-Factory conversion is worth the $... car definitely performs better. Lands noticeably better too, I think partly since it braces things up a bit.
Maybe it's worth TLRings time to make a correct official one.....
LosiMadMan is offline   Reply With Quote
Old 01-10-2017, 10:23 AM   #4124
Dang I thought I paid a lot for my Serpent diff.... I'd rather buy TLR stuff anyways.
Old 01-10-2017, 10:24 AM   #4125
MNiceGuy's Avatar
Originally Posted by DG Designs View Post
I don't quite get the need for the second tower. Couldn't you just use a longer shock mount?
The carbon tower brace is definitely needed. The X-Factory rear kit moves the upper shock mounts 8mm+ forward of the TLR tower which puts some extra leverage on the tower itself. A friend attempted to use a spare TLR tower as a brace in his homebrew version of the X-Factory kit and ended up with so much flex the dogbones started popping out.
I've painted a few of the laydown bodies with my standard process and found no difference in the result when compared to other bodies I painted around the same time.
I use original, plain Dawn dish soap with hot water to wash each body before paint. Sometimes if I'm feeling especially ambitious I will follow-up with a wipe with 91% isopropyl alcohol.
For paint I am using Faskolor and Createx thinned in some cases with 4011 reducer.
I got mine direct from X-Factory but I did experience about a week delay between the order and the item shipping. Not a big deal but in the world of Amain/Horizon/etc. shipping same day it's worth knowing ahead of time.
22 3.0 Laydown | 22T 2.0 | 22T 3.0 | 22-4 2.0 | XXX-T MF1 | XX4
MNiceGuy is offline   Reply With Quote
