    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-05-2017, 07:56 PM   #4066
Originally Posted by johnny44 View Post
Will these fit and work correctly with the 3.0?
**Can't post links yet** Found on A Main
lunsford-super-duty-tlr-22-2.0-titanium-turnbuckle-kit-w-ball-cups-6
I am using Lunsford titanium turnbuckles on my 3.0. The part number is LNS36009. They are in stock at AMain right now, they work great.
StadiumRC is offline   Reply With Quote
Old 01-05-2017, 08:52 PM   #4067
Frank,
What happened to the Gen II Rear Hub Set (TLR234075)?
Originally, I thought they were supposed to come with both standard and +3mm axle composite bodies.
I was considering pre-ordering when I noticed the +3 bodies mysteriously disappeared from the product image?
(a google image search on the part number still shows both)https://www.google.com/search?q=TLR2..._AUIBygD&dpr=3
I was hoping to get the Gen II Hub set and use the +3mm axle composite hubs for my carpet 22 3.0. Please advise. Thanks
DJPod is offline   Reply With Quote
Old 01-06-2017, 07:57 AM   #4068
johnny44's Avatar
I saw the lunsford TB's on AMain, but I'm wanting the ballcups with it. I've broken two tlr ballcups just trying to take them off the ballstuds.
johnny44 is offline   Reply With Quote
Old 01-06-2017, 09:11 AM   #4069
Trader Rating: 14 (100%+)
Anyone put the Exotek laydown in an SR yet?
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 01-06-2017, 09:47 AM   #4070
Davidka's Avatar
Trader Rating: 75 (100%+)
The 2.0 kits and 3.0 kits are slightly different. 3.0 uses all the same length (55mm, I think), and the 2.0 kit uses something like 2 x 56mm, 4 x 57mm. It should still work, but there may be adjustment combinations at the short end of the range that don't.
Old 01-06-2017, 10:13 AM   #4071
johnny44's Avatar
Thank You Davidka.
After further research found that they are indeed different length TB's. I will just get the lunsford TB's and see if I can find other ballcups than the TLR ones.
I have read that the TLR ballcups are a pain to get on and off. In my experience they seem to be fairly brittle?
Old 01-06-2017, 10:15 AM   #4072
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by DJPod View Post
Frank,
We had a fit issue with the +3mm, and couldn't hold up the standard hubs since they come with the SCT 3.0... so we revised the replacement part and price. +3mm hubs will be out in the first part of 2017, but not exact date yet.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-06-2017, 10:28 AM   #4073
Thank You Davidka.
I actually really like the TLR ball cups, I have removed mine a few times without any issues. I have a set of pliers that I modified (so the pliers don't tear up the cups) and I grab and twist up on the cup and they come right off.
Old 01-07-2017, 10:32 AM   #4074
F N CUDA's Avatar
Trader Rating: 31 (100%+)
My shock shaft pliers do this job too.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-07-2017, 11:00 AM   #4075
I modify my ballcups by punching a 2.5 or 3 mm hole in them. That way I can move ball studs or change shims without taking the cups off.
Callaway is offline   Reply With Quote
Old 01-07-2017, 12:59 PM   #4076
johnny44's Avatar
I was using regular pliers and a microfiber towel to avoid grinding up the ballcups. I'll try my shock shaft pliers.
Brilliant^^ I may give this a shot!
Thanks fellas
Old 01-07-2017, 01:02 PM   #4077
Davidka's Avatar
I haven't ever had any real trouble with any of the newer TLR ball cups. The old white ones (XXX era) used to pop off a little too easily sometimes.
Old 01-07-2017, 07:18 PM   #4078
LBR_Frank's Avatar
Question for y'all experts
I have the 3.0 SR and am 20g under weight. Some am looking for smart hop ups, Aluminum bits that may help performance or chassis stiffness so I can add functional weight.
Car runs awesome right now so changing anything makes me paranoid I'll lose that driving sweetness,lol. But gotta make weight.
TLR 22 3.0 Spec-Racer (Album)
17.5 Tekin Gen 3
Tekin RS Gen 2
Spektrum S6240
LBR_Frank is offline   Reply With Quote
Old 01-07-2017, 07:19 PM   #4079
Thanks for the info.
Good to see quality control at work!
Looking forward to those +3mm composite hubs.
Old 01-07-2017, 07:52 PM   #4080
Davidka's Avatar
No need to over think it. Slap 3 (7gm/ea.) pieces of stick on weight where they won't change anything and run it! Spend the $$ on some tires.
