    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-04-2017, 02:21 PM   #4051
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by shark2288 View Post
do any of the team guys run the carpet conversion on high bite clay or do they just run the dirt version no matter.
Also, how do you do the front pivot mod, or is it just better to get the hrc front pivot
I just posted a link to the video in my last post.
We run the dirt version on clay, and the standard version on carpet. Not a lot of crossing beyond that.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 01-04-2017, 03:33 PM   #4052
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by MNiceGuy View Post
You bring up a good point. I habitually use 12awg but for stock racing is that really necessary? Would there be any disadvantage to going 14awg?
None that I am aware of.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-04-2017, 07:26 PM   #4053
I replaced the shock shafts and the xrings and im still getting so much pressure in my shocks that when i take the screw out oil squirts out and they are 100% rebound. I bled them extra this time and it still does it. It happens after i run it. Any ideas?
Cday is offline   Reply With Quote
Old 01-04-2017, 07:43 PM   #4054
Davidka's Avatar
Trader Rating: 75 (100%+)
I just looked this up. Basically, 1ft of 12g wire has. 002ohm resistance, 1ft of 14g has. 003ohm. I recall noticiing a difference whenI rewired my old Novak T1s' (brushed, pre high-frequency tech) with a 14g 3-wire setup from the stock 16g 4-wire. I don't know it that kind of change would have the same effect on a modenr BL system. I suppose everything counts for something.
Old 01-04-2017, 08:29 PM   #4055
hollywood3705's Avatar
As long as the motor wires do not get hot it's for weight savings. Going from 12 to 14 will not get the wires even warm. Only disadvantage you would have is if the go from 12 to say 20 or 24awg.
Amain.com / Protek / VRP / The Ohio R/C Factory / The Bearded Wonder
hollywood3705 is offline   Reply With Quote
Old 01-04-2017, 10:40 PM   #4056
It's kind of annoying to buy the "carpet" laydown when it was the only laydown. A few weeks later, Poof. Here's a dirt laydown that costs less and you don't have to spend $80 more on a gear box to get it right on clay. Rant over, still love it.
TimmE is offline   Reply With Quote
Old 01-05-2017, 09:08 AM   #4057
Has anyone figured out how to get the brass 30g rear pivot to fit the laydown?
Jdhjelley is offline   Reply With Quote
Old 01-05-2017, 09:52 AM   #4058
TLRacing
Frank Root's Avatar
Are you building the shocks at the track?
Old 01-05-2017, 09:54 AM   #4059
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
This ^. I always see people that build shocks at home, in their garage and then show up to the track. Temperature, pressure, etc... changes everything.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-05-2017, 11:55 AM   #4060
Yes at the track most of the time but a few times from home but it seems like it doesnt matter. Theres another having the same problem and he builds his shocks at the track only but after we run we have full rebound. The only things that arent new on my shocks are the body, the plastic guides and the cap/screw.
Old 01-05-2017, 12:37 PM   #4061
MNiceGuy's Avatar
Originally Posted by tlr224 View Post
If Losi would just come out with a carpet version of 22 for around 350 like everyone else instead of approx 320 for kit and 180 for lay down tranny. And I am a loyal Losi supporter. But that doesn't make any sense at all to me.
The conversion is expensive mainly due to the chassis and gearbox. The chassis is priced about where you would expect but that gearbox cost is VERY high compared to other configurations. We all know this is mainly because each laydown case is machined Delrin vs molded plastic.
I think the reason these cases are continuing to be machined is because there is something more substantial coming in the 22 buggy world and I think it will be here sooner than later. TLR isn't tooling up to mold the cases because I think a new car is going to make them irrelevant.
Why else would they insist on machining gear boxes which puts the cost of a laydown car into the stratosphere; especially when the general consensus seems to be the laydown cars are superior on med-high to very-high traction surfaces?
22 3.0 Laydown | 22T 2.0 | 22T 3.0 | 22-4 2.0 | XXX-T MF1 | XX4
MNiceGuy is offline   Reply With Quote
Old 01-05-2017, 02:51 PM   #4062
Just received my HD slipper springs in the mail. The red spacer included with them, does anyone know what it is for? Is it a replacement for the spacer already installed on the lay shaft behind the slipper plates? If so I guess you don't really need a new one? Just kind of confused why that was included with the new slipper spring.
Thank you for any replies......
Medicinal Coma is offline   Reply With Quote
Old 01-05-2017, 03:44 PM   #4063
TLRacing
Frank Root's Avatar
Build them just like this video, then let me know if that helps.
https://www.facebook.com/16771357659...6055177093183/
Old 01-05-2017, 04:19 PM   #4064
johnny44's Avatar
Will these fit and work correctly with the 3.0?
**Can't post links yet** Found on A Main
lunsford-super-duty-tlr-22-2.0-titanium-turnbuckle-kit-w-ball-cups-6
johnny44 is offline   Reply With Quote
Old 01-05-2017, 07:30 PM   #4065
I hope you're right! I've decided to just holdout an wait to see what TLR's next thing will be for carpet and high-bite dirt.
DJPod is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
_AMA_
