TLR 22 3.0 Race Kit Thread!
#3796
I had the same problem with my no lay down 22 3.0... couldn't get much below 24mm ride height out of the rear with the stiffer springs for carpet. I finally ended up removing the rear shock collars completely and let them ride on the shock caps. This set the rear ride height around 17-18 mm and no more traction rolling!
I know the other option is to use the lay down kit which is designed for carpet and low ride height, but I am not so keen on the price.
Also for the front, I moved the spindles all the way up (2 mm upper spacer and no lower spacer) and also made the HRC mod to the front pivot and used the stiffer TLR front blue springs which are slightly shorter than the softer springs.
I can't afford the lay down kit right now.
#3797
Are you sure those shock retainers on the front aren't AE or some other brand? They look kinda pinched on the bottom in the last pic. They should slide on and off smoothly without a spring.
#3798
Few ideas:
1.) Check that the nut securing the top shock bodies mounts (both front & rear) aren't binding and the shock bodies are free moving (has some play) and the bottom as well.
2.) Are the o-ring over compressed by the bottom shock caps during initial assembly causing excessive siction (snugged down tighter than necessary?)
3.) You may have to re-bleed the shock to zero rebound again perhaps at the track. (they could build pressure back up after the first time, I.e. shaft pushes back out far)
Let us know if that helped or was it.
#3799
Try the spring cups from the kit. I believe those are too tall, giving you extra ride height. Also I agree with the others about making sure your shocks move freely on the top, make sure nothing is binding. If you remove the screw on the bottom of the shock holding it to the arm, the shock should swing freely on the top shaft.
#3800
By the way, I know the laydown kit is a little expensive. I put it off for a while too, but it really is the way to go for carpet. It makes a huge difference in how easy it is to drive. Turned me from a mid-pack guy to qualifying 2nd and finishing 3rd the first time out with it. Out of a field of 14 with 9 racers all at 19 laps, only me and the TQ hit 20 laps.
#3802
I know but I just missed 2 months of work "bad heart" so I'm broke.
I'm about 1.5 seconds off of the guys with the laydown. If I can get it lower and have less traction roll I can push it harder.
#3803
I'm currently running a b6 lay down car with a ball diff on a hard packed indoor track with med-high bite depending on how much the track is wet. I recently won a 22 3.0 in a raffle and curious how it might do at the track as is without the lay down conversion.
#3804
There is no binding.
#3806
the talk about getting the ride height lower on a stand up gear buggy.... from the pics it looks like you have the tall +4 mm spring cups installed front and back and that could be one problem, plus TLR LF springs are a little taller then say a Yokomo Yatabe arena spring or an Avid spring. Plus you should raise your front spindle up to 2 mm on top and that will help with the ride height. I have a laydown and a stand up buggy and both I can get at 19mm with no problem with the correct springs and spring cups.
#3807
I will have to go check this when I get home, but I'm pretty sure I'm right.
I'm often wrong though...
#3809
I need to go home and measure the cups but the +4mm is the inside of the cup not the area that the spring rests on.This keeps the spring from popping out of the cup.
https://www.amainhobbies.com/team-lo...233021/p475090
#3810
+4mm cup spaces the spring up, the cup itself is 4mm taller...it's not measuring the part that the spring rides on.
Alright then
