    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 11-07-2016, 09:22 AM   #3736
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Woulvesbaine View Post
Frank, thanks as always for the quick response (great factory support)!
Has anyone tried running the rear shocks in the front of the tower, for instance with the X-factory tower? I notice the rb6.6 and AE b6d users are doing this for clay.
I'd like to give this a try on the 22 3.0, but would like to know what it would do and if anyone has any experience doing this.
I had tried it way back when on my dex210 (v1) and found the car rotated slightly better. (Don't get me started on this car).
No idea if that would carry over here though.
I haven't flipped them myself.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-07-2016, 11:07 AM   #3737
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i moved my shocks prior to the AE race, and got an XFactory kit while at the race. the kit is the way to go,
i felt that my car carried more corner speed, had more onpower steering, it rotated more...really like it...especially in stock..
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 11-07-2016, 08:53 PM   #3738
Trader Rating: 36 (100%+)
Originally Posted by Frank Root View Post
You'll need the aluminum diff hubs, molded outdrives and the driveshaft bones, all together.
TLR232056
and
TLR232058 or TLR232059
$329.99, sames as the original price of the 22 3.0.
Frank,
Judging from this post the lightweight diff parts only work with the new bones and that they won't work in a 22t?
nitrousdave is offline   Reply With Quote
Old 11-08-2016, 08:41 AM   #3739
MNiceGuy's Avatar
For the original laydown (+3.5) conversion, should the rear pivots be changed to HRC as recommended for the front?
22 3.0 Laydown | 22T 2.0 | 22T 3.0 | 22-4 2.0 | XXX-T MF1 | XX4
MNiceGuy is offline   Reply With Quote
Old 11-08-2016, 09:07 AM   #3740
TLRacing
Frank Root's Avatar
Originally Posted by nitrousdave View Post
Frank,
Correct, the diff will not work for the 22T and SCT at this time.
I wouldn't change to HRC in the rear.
Old 11-09-2016, 11:06 AM   #3741
gokarter64's Avatar
Hey frank. Have you guys put any thought into doing a new rear shock tower and arms to support moving the shocks forward? (I was thinking about something similar to the jconcepts rear bulkhead/tower for the c4.2) Also having a mount on the new tower for a rear rollbar would be a welcomed addition. Only one clay indoor track remains up here in the northwest, the rest have gone to carpet/turf
gokarter64 is offline   Reply With Quote
Old 11-10-2016, 03:32 PM   #3742
X-factory rc makes one $30
Goodgame is offline   Reply With Quote
Old 11-13-2016, 06:24 AM   #3743
Trader Rating: 17 (100%+)
Why on the losi laydown kit. People aren't running the alum rear hubs supplied by the kit. Little info help please??
Rcforlife13 is online now   Reply With Quote
Old 11-13-2016, 06:35 AM   #3744
Sure people are running them. I am on my carpet buggy. I also have the dirt laydown for next time I hit the clay. The dirt laydown transmission is meant to use the stock hubs. It all has to do with what ride height you are intending to run.
Callaway is offline   Reply With Quote
Old 11-13-2016, 06:47 AM   #3745
Thanks. Yeah I'm running on clay.
Old 11-13-2016, 09:45 AM   #3746
Just switched brands to a 22 3.0. Are there any hex conversions out there that will let me run the wheels I have instead of trying to unglue everything and put on tlr wheels?
Jakeracer81 is offline   Reply With Quote
Old 11-13-2016, 02:26 PM   #3747
brad996's Avatar
What Car did you have before the Losi? Any Rear wheel should fit fine. Fronts are a little different story most 12mm wheels will bolt up but your offset will be different. Losi fronts have zero offset. Associated wheels for example make the car about 9mm to wide. Im not sure about the other brands.
SIRCS, Asylum Xtreme
TLR 22 4.0, TLR 22 3.0 lay down, TLR 22-4 2.0 Yokomo BD8/SV, Yokomo YR10F
brad996 is offline   Reply With Quote
Old 11-14-2016, 09:40 AM   #3748
almost about to pull the trigger and pre-order the Spec Racer...Im new one track that is clay and one that is carpet, is the option laydown transmission necessary on carpet or will the box setup be competitive on carpet? This is my first 2wd buggy for racing. Thanks.
FreeBandz is offline   Reply With Quote
Old 11-15-2016, 08:37 AM   #3749
Trader Rating: 62 (100%+)
The box set-up will work great on carpet, then down the road after you hone your skills you may want to try a laydown set-up.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 11-15-2016, 09:37 AM   #3750
so being that this will be my first actual racing kit buggy, should I just save money and go for the 22 3.0 vs the Spec-R? Since I am new to racing, im not sure the weight savings would give me that much of an advantage because im still trying to learn how to drive fast! LOL
