    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 11-03-2016, 12:04 PM   #3721
Trader Rating: 16 (100%+)
Frank Root did a live video on Facebook earlier. Full details on the car and projected pricing info. https://www.facebook.com/16771357659...1211338577567/
MX304 is offline   Reply With Quote
Old 11-03-2016, 12:12 PM   #3722
Originally Posted by FreeBandz View Post
projected price? can anyone speculate?
http://www.horizonhobby.com/product/...kit-p-tlr03010
JerryRigged is offline   Reply With Quote
Old 11-03-2016, 01:47 PM   #3723
How much would all the light wieght bits cost off the new car to put into the original?
offroader47 is offline   Reply With Quote
Old 11-03-2016, 02:38 PM   #3724
Trader Rating: 25 (96%+)
I was curious too... based on what I gather it's roughly $240:
$22 Direct Drive System (SR)
$25 Ultra Lightweight Body (SR)
$12 Front Aluminum Axles (SR)
$15 Narrow Gear Set (SR)
$7 Diff Nut Spec Racer (SR)
$38 CVA Complete Set (SR)
$24 Outdrive + Diff Hub Set (SR)
$10 Lexan Gear Cover (SR)
$17 Lightweight Motor Plate (SR)
$68 Lightweight Chassis (SR)
billdelong is offline   Reply With Quote
Old 11-03-2016, 03:58 PM   #3725
Applesauce's Avatar
Trader Rating: 14 (100%+)
Will the laydown dirt trans bolt up to the light weight chassis?
Applesauce is offline   Reply With Quote
Old 11-03-2016, 04:03 PM   #3726
Chr1s's Avatar
Based on the picture it will not. As is does not have the required holes
Chr1s is offline   Reply With Quote
Old 11-03-2016, 10:03 PM   #3727
Oasis's Avatar
Trader Rating: 36 (100%+)
Originally Posted by JerryRigged View Post
A main has them listed at $330..back ordered
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 11-04-2016, 06:38 PM   #3728
KalEl63's Avatar
Mostly like a no to this question but can you buy the battery brass weight that is in the laydown kit separately?
Also do the ally rear hubs (TLR334014) weigh more than the plastic kit hub?
Cheers
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 11-04-2016, 06:48 PM   #3729
Trader Rating: 22 (100%+)
Why does it not have a Laydown?
Coke in a can is offline   Reply With Quote
Old 11-04-2016, 06:56 PM   #3730
Davidka's Avatar
Trader Rating: 75 (100%+)
Laydown is for very high grip. The stand up transmission works just about everywhere.
Old 11-05-2016, 05:05 AM   #3731
Trader Rating: 21 (100%+)
Cheers
No you can not buy the weight separate and yes the aluminum hubs are going to weigh more
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 11-05-2016, 09:20 AM   #3732
Default Body
Have the exotek laydown installed, and stock body is super tight fit, hitting/resting on the trans itself. What body is fitting best with exotek laydown?
killshot01 is offline   Reply With Quote
Old 11-05-2016, 12:06 PM   #3733
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Woulvesbaine View Post
Frank Root: Can you order the new stock spec lightened outdrives separately?
You'll need the aluminum diff hubs, molded outdrives and the driveshaft bones, all together.
TLR232056
and
TLR232058 or TLR232059
$329.99, sames as the original price of the 22 3.0.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 11-05-2016, 07:21 PM   #3734
losicorey's Avatar
Jconcepts s2 body fits nice
losicorey is offline   Reply With Quote
Old 11-07-2016, 12:22 AM   #3735
Woulvesbaine's Avatar
Frank, thanks as always for the quick response (great factory support)!
Has anyone tried running the rear shocks in the front of the tower, for instance with the X-factory tower? I notice the rb6.6 and AE b6d users are doing this for clay.
I'd like to give this a try on the 22 3.0, but would like to know what it would do and if anyone has any experience doing this.
I had tried it way back when on my dex210 (v1) and found the car rotated slightly better. (Don't get me started on this car).
No idea if that would carry over here though.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
