    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 10-01-2016, 02:49 AM   #3556
Finaly pulled the trigger. Bought my first 2wd off road buggy. It's the 22 3.0 Can't wait for the mail man to deliver...
Used to race the short course class only. But i was always attracted to the 2wd class. So now i finally join this class as well.
Will continue reading these forums and absorb all info available.
Hamster71 is offline   Reply With Quote
Old 10-01-2016, 07:34 AM   #3557
Davidka's Avatar
Trader Rating: 76 (100%+)
Matt, is your motor or motor plate touching the chassis? That'd turn the chassis plate into a big ol' resonator.
Old 10-01-2016, 08:34 AM   #3558
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Matt M. View Post
2 questions for Frank,
1, what effect does running the spindle shims like dakotah does have on the handling
2, my dirt laydown is loud. i mean really loud...i hae cleaned and greased the gears, it has done it since i got it, i have changed the sour gear and the pinion gear, i expect some noise with the metal on metal gears, but this squeel is something, my car is noticably louder than other cars at the track.
Ideas??
as always, thank you
The aluminum idle gear is the culprit. I'd like to see a plastic one. I have also notice when tightening down the tranny case screws it puts a little drag on the drive train. just snug on the screws to allow it to spin free. this might help to quite things down a bit.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 10-01-2016, 10:04 AM   #3559
Are TLR and Exotek the only companies that offer laydowns? And what to look for before buying a used 3.0? TIA
Rc.Car.Vids is offline   Reply With Quote
Old 10-01-2016, 11:00 AM   #3560
I think its a machining issue...when I ran the regular laydown we never had the noise compared to the new "dirt laydown" transmission. Either way it's a great car and I can deal with a little noise for the WIN!
Sm1983 is offline   Reply With Quote
Old 10-01-2016, 08:09 PM   #3561
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Ideas??
Raising the hubs up front will give you more on power steering.
K_King is offline   Reply With Quote
Old 10-01-2016, 09:31 PM   #3562
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i am doing that now...cause i noticed that also...mine is really noticeable...matt maiers car is not as loud..
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 10-01-2016, 09:31 PM   #3563
Administrator
Matt M.'s Avatar
thank you sir....this is what i am looking for..
Old 10-01-2016, 09:34 PM   #3564
Administrator
Matt M.'s Avatar
ill check...it sounds like to tight of gear mesh...
it drives me nuts...lol
Old 10-02-2016, 09:32 AM   #3565
Question: I am going to do the laydown conversion with the dirt case. I was looking at the instructions and they show a gear differential being used. Is the ball diff compatible? And if a ball diff is compatible would my MIP pucks system still work?
Chad_R40 is offline   Reply With Quote
Old 10-02-2016, 10:19 AM   #3566
Administrator
Matt M.'s Avatar
the ball dif is compatable, as are the correct version of the mip pucks
Old 10-02-2016, 10:33 AM   #3567
That's another thing I'm worried about. I bought the pucks system last season and they were labeled 2.0/3.0 bit now I see they have a 3.0 only version and the out drives look different then mine...
Old 10-02-2016, 11:38 AM   #3568
Trader Rating: 21 (100%+)
The outdrives are the same. The bones are different so you can run standard TLR axles and they are longer to sit further in the outdrive. Just make sure you run the spacer on the axle with yours.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 10-02-2016, 02:49 PM   #3569
Trader Rating: 15 (100%+)
Frank or anyone, with the dirt laydown conversion, are most people running the brass front block or aluminum hubs?
dbracn is offline   Reply With Quote
Old 10-02-2016, 05:22 PM   #3570
K_King's Avatar
Here's my current setup.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
stuka73
