    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 09-18-2016, 02:30 PM   #3511
Dirt laydown uses stock hubs or aluminum equivalent not the +3
Rozzy is offline   Reply With Quote
Old 09-18-2016, 02:34 PM   #3512
I am using Dakota's laydown set up from the nationals
Old 09-18-2016, 02:54 PM   #3513
Originally Posted by tony montana View Post
Frank or anyone else. First race with the car yesterday. Local track got a complete make over. We were running slicks prior, now we're running dirt webs/ electrons. Prior on a couple of test days the car was pretty decent. I really struggled yesterday. I still made the A but it was a handful. Basically the car lacked traction and was really unpredictable. I would say traction is medium at best. Running 3 gear stand up. Basically stock setup up except I moved the rear hubs forward. Any suggestions would be great. I know the track will come around as far as traction, but it's gonna be a couple of months and I need to get my car hooked in the mean time.
Possibly give the 4 gear tranny a try. It sounds like I run on a similar surface to you. When I changed to the 4 gear I noticed a big increase in rear grip.
ChrisUU is offline   Reply With Quote
Old 09-18-2016, 03:47 PM   #3514
Trader Rating: 15 (100%+)
Is this a clay indoor track, outdoor? Where is your battery? You can move your battery back and also add some weight to the back of the car as another option to permanently going with the 4 gear.
TLR 22 3.0 - Laydown & 3-Gear 17.5 Stock
TLR SCTE 3.0
*Support SDRC - San Diego, CA*
powerjames is offline   Reply With Quote
Old 09-18-2016, 08:48 PM   #3515
HotRod127's Avatar
Can anyone show me a pic of how the servo is mounted back like some of the setups say. Thanks
Kyosho RB6.6/ Kyosho ZX6.6/ Kyosho RT6/ Kyosho America- Peak Racing Products- Team Orion- AKA- JTP- 92zerodesigns
HotRod127 is offline   Reply With Quote
Old 09-18-2016, 09:19 PM   #3516
when running the laydown conversion, what would the effects be if you were to put in the hrc rear pivot blocks ?
perch whisperer is offline   Reply With Quote
Old 09-19-2016, 09:51 AM   #3517
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
With indoor clay tracks, tires are so much of the equation. Did you break yours in, sand them, and get enough sauce in them?
Setup wise, what are you running? Have you tried a setup with 1.6/1.7 and the white rear springs?
Takes out some bone plunge. Lands a little worse, but can squat more on throttle.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 09-20-2016, 09:33 AM   #3518
I'm coming back to 1/10 scale racing in the next month from doing 1/8 nitro. What would I need to get for 22 3.0 new kit to make it race ready quickly? Ex.. lay down kit, lay down tranny, springs, pistons, etc.
The tracks around here are high bite and one is loose to medium bite
mrcdub01 is offline   Reply With Quote
Old 09-20-2016, 10:24 AM   #3519
thecman26's Avatar
Trader Rating: 99 (100%+)
Nothing! It's really good right out of the box!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 09-20-2016, 12:01 PM   #3520
Ok, cause I see some guys talking about the lay down conversion. What's the advantages?
Old 09-20-2016, 01:02 PM   #3521
TLRacing
Frank Root's Avatar
Advantages - More corner speed, easier to drive on higher grip tracks, especially carpet and astro.
Disadvantages - cost, and harder to drive on loose to medium dirt tracks.
Old 09-20-2016, 02:23 PM   #3522
Which way should I go then. The tracks I will be running on are medium to high bite and 2 are high bite clay that use slicks sometimes.
If I buy a new 22 3.0 kit, what else should I purchase to be successful on these 3 tracks without having to buy 2 car kits?
Old 09-20-2016, 02:27 PM   #3523
Would Dakota's setup work on every type of track conditions? Sorry for all the questions, I just want to get this purchase right the first time out.
Old 09-20-2016, 02:59 PM   #3524
IMO, I would just run it box stock and see what adjustments you need to make and then go from there.
I know ZERO about your skill level, however coming from 1/8th scale, you may find that the out of the box setup will work for you for the time being. Until you know for certain you can benefit from the laydown transmission. If you are JUST learning your car, you may have no need for all of that additional cost. At least upfront.
Rabidtrout is offline   Reply With Quote
Old 09-20-2016, 03:35 PM   #3525
TLRacing
Frank Root's Avatar
It REALLY depends on a lot of factors, most of which have to do with you. You can always add the laydown later if/when you feel like you need it.
