    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 09-16-2016, 07:44 AM   #3496
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Matt M. View Post
yes..
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 09-17-2016, 09:20 AM   #3497
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Originally Posted by Frank Root View Post
the same could be said for the rear oil thicker than the front....32.5 front, 35 rear.....car is much better...
thanks Frank...
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 09-17-2016, 01:13 PM   #3498
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Dialed
http://www.tlracing.com/Products/Default.aspx?ProdID=TLR231057
K_King is offline   Reply With Quote
Old 09-17-2016, 02:38 PM   #3499
TLRacing
Frank Root's Avatar
Originally Posted by K_King View Post
http://www.tlracing.com/Products/Def...odID=TLR231057
Old 09-17-2016, 06:20 PM   #3500
Fabulous's Avatar
Trader Rating: 42 (100%+)
OK, Please explain? What changed verses TLR231037? Is this for the laydown conversion?
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 09-17-2016, 07:43 PM   #3501
Administrator
Matt M.'s Avatar
my guess is they are stiffer, and you use them to reduce flex
Old 09-17-2016, 08:46 PM   #3502
TLRacing
Frank Root's Avatar
These are stiffer, and provide more consistence. The fit both the standard 22 3.0 and the laydown conversion. The team runs them exclusively.
Old 09-18-2016, 02:43 AM   #3503
Are there still fitment issues when building the most current version of this kit?
djtang88 is offline   Reply With Quote
Old 09-18-2016, 04:27 AM   #3504
tony montana's Avatar
Trader Rating: 65 (100%+)
I didn't have any.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 09-18-2016, 04:34 AM   #3505
Frank or anyone else. First race with the car yesterday. Local track got a complete make over. We were running slicks prior, now we're running dirt webs/ electrons. Prior on a couple of test days the car was pretty decent. I really struggled yesterday. I still made the A but it was a handful. Basically the car lacked traction and was really unpredictable. I would say traction is medium at best. Running 3 gear stand up. Basically stock setup up except I moved the rear hubs forward. Any suggestions would be great. I know the track will come around as far as traction, but it's gonna be a couple of months and I need to get my car hooked in the mean time.
Old 09-18-2016, 08:33 AM   #3506
K_King's Avatar
I've built 3 cars and haven't had any fitment issues at all.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
Old 09-18-2016, 09:10 AM   #3507
I myself am struggling with the same issue with my dirt Laydown I tried several different tires and was still loose running 10.5 on a new clay track. Slipper is loosened up. May try snugging up the diff a bit
QUOTE=tony montana;14674318]Frank or anyone else. First race with the car yesterday. Local track got a complete make over. We were running slicks prior, now we're running dirt webs/ electrons. Prior on a couple of test days the car was pretty decent. I really struggled yesterday. I still made the A but it was a handful. Basically the car lacked traction and was really unpredictable. I would say traction is medium at best. Running 3 gear stand up. Basically stock setup up except I moved the rear hubs forward. Any suggestions would be great. I know the track will come around as far as traction, but it's gonna be a couple of months and I need to get my car hooked in the mean time.[/QUOTE]
Rozzy is offline   Reply With Quote
Old 09-18-2016, 09:43 AM   #3508
Trader Rating: 132 (100%+)
Default Dirt laydown
Hey guys. When using the dirt laydown, do I use the stock rear hubs?
skyline1015 is offline   Reply With Quote
Old 09-18-2016, 01:14 PM   #3509
Administrator
Matt M.'s Avatar
yes
Old 09-18-2016, 01:22 PM   #3510
K_King's Avatar
[/QUOTE]
What setup?
