    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 09-10-2016, 10:29 PM   #3481
ryan432greening's Avatar
Originally Posted by Medicinal Coma View Post
Has anyone tried the new brass front hinge pin block that TLR offers for the standard 3 gear tranny car?
http://www.tlracing.com/Products/Def...odID=TLR334035
I have the exotek, not the TLR part, but it was the single best change I made to get it driveable for me, a low-level guy, in medium to loose dirt outdoors. I haven't seemed to mind the extra weight indoors in stock buggy either. Brass up front and in back helps me be more consistent for now, until I ever get better, smoother and more in tune with my car.
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 09-12-2016, 10:46 AM   #3482
GasserX's Avatar
Originally Posted by Casper View Post
DE makes some. The 22-4 front wheel fits on the 22 12mm front axel. I have been running it for a while now and work great.
Come in a variety of colors as well
http://www.deracing.net/store/index....&category_id=0
Casper, do you use the 2 wheel or 4 wheel rubber front tires on the 22-4 front wheels to your 22 3.0 buggy?
LOSI 8E 4.0
LOSI 22-4 V1.5
LOSI 22 3.0 Dirt Laydown
GasserX is offline   Reply With Quote
Old 09-12-2016, 11:03 AM   #3483
Casper's Avatar
Trader Rating: 33 (100%+)
I put 2wd tires on it for my 22 3.0 buggy
If you compare 2wd to 4wd wheels you will see they are VERY close in width bead to bead from TLR. We have been "stretching" 2wd tires on wider wheels for many, many years.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-12-2016, 11:18 AM   #3484
GasserX's Avatar
Thanks Casper! I will have to try this (22-4 wheels with standard buggy front tires).
I did try simply putting the actual 22-4 front tires on my 22 3.0 and they tamed steering down. I guess this may not be legal to race with.
LOSI 8E 4.0
LOSI 22-4 V1.5
Old 09-12-2016, 11:23 AM   #3485
Applesauce's Avatar
Trader Rating: 14 (100%+)
Looking for pics of fan setups when running 17.5
Applesauce is offline   Reply With Quote
Old 09-12-2016, 03:34 PM   #3486
Team Pink's Avatar
Trader Rating: 20 (100%+)
Are you running laydown or standup? If running laydown the most common fan setup will be putting a fan behind the motor double sided taped to the chassis. If running a stand up car I'd suggest the waterfall from Mo Performance Parts on Shapeways.
http://www.shapeways.com/product/D9U...-fan-brace-low
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 09-12-2016, 05:40 PM   #3487
Applesauce's Avatar
Standup
Old 09-12-2016, 07:35 PM   #3488
I run front 22-4 wheels and holeshots 4wd tires at our outdoor track and they are great, i had to turn down the epa a little from one side so it does not rub at the arm, like 5-10 points of epa.
From what i could find the only rule is 250mm total width of the car...i have not measure my car yet...
ffwd is offline   Reply With Quote
Old 09-12-2016, 07:36 PM   #3489
thecman26's Avatar
Trader Rating: 99 (100%+)
I have seen an "upper tier" sponsored driver running 4wd fronts on his 22 3.0. May have just been an experiment but he was HOOKED up!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 09-14-2016, 03:51 AM   #3490
Default Servo mount
Sorry if this had been covered and I'm sure it was cause I have read somewhere that when using the alloy servo mount some people are mounting the servo to the back of the mount. Why is this done? What does it achieve? And what else needs to be changed to get it to steer properly. Thanks for any answers.
Cub86 is offline   Reply With Quote
Old 09-14-2016, 08:23 AM   #3491
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
It moves weight in the car back. You have to cut a little of the mud guard to clear the servo mounting tabs, and clearance the front bulkhead for the servo arm to clear.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 09-15-2016, 06:38 AM   #3492
Adrian_Spina's Avatar
This was with the 2.0 however I'm sure with some 3D printing prowess one could be made for the 3.0 with ease
https://www.facebook.com/HyperRCGrap...type=3&theater
Proud KEORCA racer - http://www.keilorrc.org.au/
Proudly Sponsored by TLR Australia - OMP - CentralRc
Adrian_Spina is offline   Reply With Quote
Old 09-15-2016, 06:43 AM   #3493
This is off my 22T 2.0 but I did the exact same thing on my 22 3.0
Hollowed out the waterfall, placed a couple spacers under the fan against the waterfall for clearance. Then, since the body is so close to the backside of the fan, I reamed a honeycomb pattern of holes out to help draw air through the fan.
B-Main Racing
Old 09-15-2016, 09:16 PM   #3494
Thanks Frank. But do u need to put the steering ball stud into the front of the servo arm as well to make the link straight still?
Old 09-16-2016, 05:53 AM   #3495
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
yes..
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
