    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 08-23-2016, 12:05 AM   #3376
Nice graphic Kev.
Might have to make an update video for 3.0
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 08-23-2016, 07:12 AM   #3377
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
someone smarter than me should get that in the wiki
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 08-23-2016, 08:59 AM   #3378
derekbsmith's Avatar
Trader Rating: 23 (96%+)
emulsion shock inserts on a 22 3.0 and config
1. I was looking at http://site.petitrc.com/setup/losi/TLR_BigBoreTips/
and my question is for option 2, is the last black piece the same as the stock 22 3.0 white cap TLR233006? My current o-ring config is black-black-gray-whitecap. Is this incorrect? What is correct?
2. What part number do I need for the emulsion style shock inserts?
Thank you!
TLR 22 2.0 Tekin RS + D4 17.5T
AE FT b4.1 Castle SW2 + SMC 9.5T
TLR Ten-SCTE '1.5' MMxpro + HW 4000kv
TLR Ten-SCTE '3.0' Tekin Rx8 + 4300kv
TLR 22 3.0 Tekin Rsx + Reedy M3 7.5T
derekbsmith is offline   Reply With Quote
Old 08-23-2016, 10:27 AM   #3379
Originally Posted by Frank Root View Post
Yes
Never seen or heard of this issue.
Well I had never seen this happen either but my left rear hinge pin either broke out or the plastic rear tow block broke causing the pin to come out? Either way I have never seen this before.
Trakjunky is offline   Reply With Quote
Old 08-23-2016, 10:29 AM   #3380
Frank,
Can you post Dakota's suspension setup from the Nats?
BK24 is offline   Reply With Quote
Old 08-23-2016, 10:34 AM   #3381
Guch's Avatar
Default Use the new x-rings
Thank you!
I don't know anyone that still uses the 22 1.0 o-ring set up since TLR came out with the white CNC delrin spacers and new x-rings back with the 22 2.0. I know I bought you the new spacers, x-rings, and shafts for your 22 2.0 so why this post? One does not use the white delrin spacers with the old gray and black o-rings. The new white CNC delrin spacers are only for the new x-rings.
As for emulsion shocks, the spacers have nothing to do with what type of shock you run. Emulsion is a term used for bladderless shocks. The bladder is either modified or removed and replaced with an o-ring to seal the shock cap in an emulsion shock. Just use the o-rings called out in the 22 3.0 manual to run emulsion style. If you want to use bladders then you need to decide if you want vented or non-vented. But looking at most setups I see most running emulsion style.
Guch is offline   Reply With Quote
Old 08-23-2016, 10:34 AM   #3382
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by BK24 View Post
Frank,
Dakotah's setup should be on the site soon, I submitted it to the web team yesterday.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-23-2016, 10:38 AM   #3383
Guch's Avatar
Thanks Frank
Old 08-23-2016, 10:38 AM   #3384
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Got it added....it's just bigger than I anticipated.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-23-2016, 10:44 AM   #3385
Originally Posted by Jason Snyder View Post
Nice graphic Kev.
Jason are you still using your 3.0 as your main 1/10 2wd? i thought you were using the b6 now?
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 08-23-2016, 11:38 AM   #3386
Thanks Frank. The setups for Dakotah and Ryan are both there now.
Frank, do you know the rear spring Dakotah is using? It just says white. Could be KYO white, TLR LF white, AE white, etc...?
Old 08-23-2016, 12:20 PM   #3387
TLRacing
Frank Root's Avatar
The LF box was checked, so TLR LF White
Old 08-23-2016, 05:39 PM   #3388
J@UNE's Avatar
Default New setup
Hi Frank!
Both setup show's servo in the back. Can we acheive this with the stock servo mount or we need the alloy?
Thx
J@UNE is offline   Reply With Quote
Old 08-23-2016, 09:07 PM   #3389
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by [email protected] View Post
Hi Frank!
Thx
Need the alloy. I would recommend them regardless.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-23-2016, 11:07 PM   #3390
Question - with the dirt transmission what differences would I expect to see if I run the 1) HRC front pivot block or 2) front LRC pivot block?
I haven't done the testing yet but wanted to see if anybody had previous experience.
toddmanley is offline   Reply With Quote
