    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 08-15-2016, 08:17 AM   #3331
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
What are the carpet gurus running for front wheels? Stock and cut the inside?
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 08-15-2016, 09:00 AM   #3332
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Yessir.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-15-2016, 10:11 AM   #3333
WillS's Avatar
Originally Posted by Cday View Post
Whoa!! You have to buy the lay down conv which is $179 and then buy a different tranny case for another $79?
It would be nice if they made both kits as options. I see more using the dirt transmission than the +3.5.
Old 08-15-2016, 02:50 PM   #3334
Woulvesbaine's Avatar
Phend's 22 3.0 looked great. Makes me want to try the laydown, but the car, near bone stock, is already great on clay.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 08-15-2016, 02:58 PM   #3335
For real.. i wish they had a dirt lay down kit and a +3.5 kit.. $260.. i could buy abother 3.0 almost for the price that the lay down is gonna costs..
Cday is offline   Reply With Quote
Old 08-15-2016, 03:17 PM   #3336
WillS's Avatar
Well to be honest, it is the best laydown car I have driven after I put the dirt transmission in.
Will Smith
Sponsors:
Old 08-15-2016, 03:33 PM   #3337
Does anybody have a link or details on camber link settings (length, height, etc.) for this buggy that would help educate me?
toddmanley is offline   Reply With Quote
Old 08-15-2016, 03:43 PM   #3338
I've been reading a lot and may have missed some things. When you run the Dirt tranny with the lay down chassis do you still use the aluminum hubs in the kit, or do you go back to your stock hubs. Also Dakotas car from yesterday was running the dirt kit and aluminum hubs. Not sure if they were the hubs from the lay down kit. I am also confused as to the camber link layout of the aluminum hub. Franks set up call for 1-A but would the be the back most inner on the aluminum hub considering the layout is different
Rozzy is offline   Reply With Quote
Old 08-15-2016, 04:43 PM   #3339
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
When you run the Dirt tranny with the lay down chassis do you still use the aluminum hubs in the kit, or do you go back to your stock hubs. use the stock hubs
Also Dakotas car from yesterday was running the dirt kit and aluminum hubs. Not sure if they were the hubs from the lay down kit. i assume they were standard TLR334014
I am also confused as to the camber link layout of the aluminum hub. Franks set up call for 1-A but would the be the back most inner on the aluminum hub considering the layout is differentthe aluminum hubs are just the a, b, c, and d holes...the front set are removed
if i am not correct, Frank will chime in...
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 08-15-2016, 05:47 PM   #3340
My aluminum hubs that came in my lay down kit have 6 holes. Hmm
Old 08-15-2016, 06:06 PM   #3341
WillS's Avatar
You can run either hubs. I run the +3 hubs on tracks that have a lot of tight 180s. If I need more traction I go back to the standard hubs in the aluminum version.
Will Smith
Sponsors:
Old 08-15-2016, 09:45 PM   #3342
Anyone have the link to the video Frank made about moding the front end?
LosiMadMan is offline   Reply With Quote
Old 08-16-2016, 12:18 AM   #3343
TLRacing
Frank Root's Avatar
https://www.facebook.com/Team-Losi-R...6594021/videos
When running the dirt tranny case, you'll want to run the "stock height" rear hubs, either molded or aluminum. Dakotah and Ryan ran the aluminum hubs at Nationals with the stock geometry.
With the laydown hubs, I run the middle, back row hole. Technically on that hub, you'd call it B, but on the stock hubs it would be called A.
Old 08-16-2016, 02:57 AM   #3344
Thanks for clearing that up
Old 08-16-2016, 07:44 AM   #3345
brad996's Avatar
Frank I have been looking on the TLR site and i don't see the laydown dirt trans case could you give me the part number
SIRCS, Asylum Xtreme
TLR 22 4.0, TLR 22 3.0 lay down, TLR 22-4 2.0 Yokomo BD8/SV, Yokomo YR10F
brad996 is offline   Reply With Quote
