    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 08-11-2016, 06:18 PM   #3316
Woulvesbaine's Avatar
Originally Posted by Frank Root View Post
I've played with the springs a bit. Right now, I have an AE white front spring, with a TLR LF white rear. Sometimes, I run the AE Green rear. I don't like the Kyosho springs as much as those in the rear. I know some guys like the Kyosho gold front springs, but every time I try it, it kills the front end and I don't have enough steering - for me at least.
#Full Disclosure
Frank, thanks as always for the quick response.
Is your setup that you posted otherwise unchanged (for standup tranny)?
Or have you fiddled with it all? If so, I'd love to see the latest as I'm sure others would.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 08-11-2016, 07:34 PM   #3317
woods05 is offline   Reply With Quote
Old 08-13-2016, 09:36 AM   #3318
Default Dirt laydown
Can the dirt laydown trans kit be made to work with the stock chassis like the exotek one does i have tried to find this answer and cant?
Jspires688 is offline   Reply With Quote
Old 08-13-2016, 09:08 PM   #3319
Has anyone had the chance to try this new piece out yet? Also would you figure it is designed more towards the lay down kit?
http://www.tlracing.com/Products/Def...odID=TLR334035
Medicinal Coma is offline   Reply With Quote
Old 08-13-2016, 09:23 PM   #3320
thecman26's Avatar
Trader Rating: 99 (100%+)
Frank has answered it about every page for the last 7 or 8 pages, no it won't work with the stock chassis, that's why there's a specific chassis for the lay down tranny.
http://www.horizonhobby.com/TLR33800...FQGsaQodB-sP9A
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-14-2016, 10:33 AM   #3321
Should add that to the first page of posts.
On another note, played around with setup and for OCRC, I'm using Kyosho gild front and TLR LF white springs rear. 1.6x2 front, 1.7x2 rear. My oil is not where it should be, but I suspect I'll end up at 32.5 all around. Currently it's 32.5 f, 35 r.
Old 08-14-2016, 11:37 AM   #3322
Default Laydown conversion
I guess i should be a little more speciffic my question wasnt for frank i was aski g if anyone had tried to drill the holes to make the dirt laydown work with the stock chassis like the exotek one does i think it seems silly to buy the full laydown conversion just to use only the chassis and then have to buy another trans i guess i will buy exotek
Old 08-14-2016, 12:05 PM   #3323
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
The chassis flex is completely different. Now the delrin case also makes for a different handling. We can agree that the price makes it hard to buy the kit but when you price out everything, you get a great deal.
Contains:
  • delrin case with adapter
  • idler gear
  • motor plate
  • aluminum hubs
  • chassis
  • carbon battery brace
  • lightweight laydown body
I might be missing stuff but seriously I didnt want to spend it but after spending it I found it worth its price tag. I would like to see a dual purpose chassis and molded cases but I am not sure how it will affect performance in the end. I honestly prefer the dirt transmission case over the +3.5 case for dirt/clay.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 08-14-2016, 12:44 PM   #3324
Jack Bonhomme's Avatar
I noticed that new part, the +35g Brass Hinge Pin Plate. Is it used for the standard tranny or the laydown one? What about the laydown dirt gearbox?
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 08-14-2016, 01:53 PM   #3325
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
all the above...
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 08-14-2016, 05:10 PM   #3326
Team Pink's Avatar
Trader Rating: 20 (100%+)
Essentially yes I guess you could drill the holes to make it work, however running the complete package offered by TLR gives the complete package. I will say doing the complete conversion makes a lot more sense dollar wise like WillS has stated. Just buying a transmission case and idler you are looking at around 100 bucks. For what you get with the conversion; I think it's worth it.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 08-14-2016, 05:39 PM   #3327
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
It only fits the standard chassis/gear box. Sorry.
The tranny case to rear tower and motor plate to chassis mount are also needed, and only available in laydown conversion.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-14-2016, 08:17 PM   #3328
Originally Posted by WillS View Post
...I honestly prefer the dirt transmission case over the +3.5 case for dirt/clay.
What's the part number for the dirt transmission case?
-Thanks, Todd
toddmanley is offline   Reply With Quote
Old 08-14-2016, 08:37 PM   #3329
WillS's Avatar
-Thanks, Todd
TLR332063 I believe.
Will Smith
Sponsors:
Old 08-15-2016, 07:05 AM   #3330
Whoa!! You have to buy the lay down conv which is $179 and then buy a different tranny case for another $79?
Cday is offline   Reply With Quote
