    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 07-31-2016, 04:42 PM   #3301
Trader Rating: 21 (100%+)
Originally Posted by powerjames View Post
I found the same thing with the Orion. It appears to be a just a hair larger than the other batteries - ProTek 4250 I run.
I space my waterfall up 1mm and also shaved some of the front battery compartment so my battery would slide in easier.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 07-31-2016, 07:15 PM   #3302
Hey guys. Really struggling with getting the buggy to steer at the moment. I'm struggling with both off power steering and on power steering. I'm running kit setup with my battery spaced 10mm of the waterfall. We run on medium grip clay.
Iv got a front and rear low frequency spring set on the way to help tune with.
Any suggestions in how to get more steering.
Would be greatly appreciated.
ChrisUU is offline   Reply With Quote
Old 07-31-2016, 09:19 PM   #3303
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Try this setup, and use the LF silver front spring and LR White rear spring.
http://www.tlracing.com/ProdInfo/Fil...2016-01-24.pdf
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-31-2016, 10:24 PM   #3304
Trader Rating: 27 (100%+)
Maybe counter intuitive but long arm helped me a bunch with steering. I would definitely try it. I am running white Kyo all way around. But about to stiffen rear.
Also I found moving battery forward second foam thickness in TLR Kit helped and didn't hurt bite off.
Nothing Beats the Kit Setup
jjdoyle is offline   Reply With Quote
Old 07-31-2016, 11:42 PM   #3305
Thanks frank. I'll definitely give that setup a try when my springs arrive.
I haven't tested the long Arm, but I will this week.
The car still generates a ton of rear grip so I could probably still go further forward with the battery.
Old 08-01-2016, 01:01 PM   #3306
Trader Rating: 62 (100%+)
Yeah the Orion batteries have to be snapped in place. If you have a ton of rear grip, move your battery all the way forward and try 2.5* rear toe.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 08-01-2016, 05:48 PM   #3307
tony montana's Avatar
Trader Rating: 65 (100%+)
Anyone have the part number for the popular yokomo green rear spring
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 08-01-2016, 06:37 PM   #3308
Woulvesbaine's Avatar
Here you go, bud.
https://www.amainhobbies.com/yokomo-...-a1200/p417650
Let us know how you like it.
The Losi LF set is also great to have for the rear. I like having the Losi Pink, White and Yellow handy for medium grip like clay.
Kyosho Gold are also in that area. I ended up with one setup that was very similar to what Frank posted but with Kyosho Gold all the way around 1.6x2 piston front, 1.7x2 rear; 32.5 front, 35 rear.
I'd start with Frank's setup though if you're on clay and then start playing with springs, etc. That's why it's nice having the Losi LF set around to fine tune.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 08-01-2016, 07:45 PM   #3309
Fabulous's Avatar
Trader Rating: 42 (100%+)
Frank, Any plans for a laydown plastic idler gear and a molded gear case?
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 08-06-2016, 08:13 PM   #3310
gokarter64's Avatar
Originally Posted by Woulvesbaine View Post
Has anyone made or tried a CF chassis for this car? I like the aluminum on it, but just curious. Seems like it could be a tuning option, or weight saving option for stock.
Yes, and i love mine. It has quite a bit of flex but on a mid to high grip track its superb.
The chassis are made by RC10nick and he sells them from his facebook page. It uses an exotek kickup plate from the old exo22 conversion on the 2.0
gokarter64 is offline   Reply With Quote
Old 08-07-2016, 04:19 AM   #3311
Anyone have links to maifield's or evans cars in laydown? Wanna see how they are doing their wiring
Old 08-09-2016, 10:54 PM   #3312
It's been a while since I have been able to get to the track. I know there's a lot of locals on here. What's the hot setup for OCRC 17.5?
cjcoffroad is offline   Reply With Quote
Old 08-09-2016, 11:30 PM   #3313
Start with what Frank Root posted a few posts above (see the link).
I've observed several variations:
Some people are running AE White Spring front, AE Green Spring rear (maybe that's what Frank's setup shows per spring weight; not sure, but you can check spring rates on the wall at OCRC in the shop).
I know someone running Kyosho Gold F/R; 1.6x2 F/R, and 32.5, 30 F/R. She looks very fast.
I am running Kyosho Gold F/R; 1.6x2 F, 1.7x2 R, 30 F, 32.5 R. Very easy to drive.
Frank, ever try anything similar to the above and any thoughts?
Anyway, there are several people running this car at OCRC and most if not all will be glad to help you setup your car or give you their thoughts but start with what Frank posted so you'll have a good starting point when you arrive.
Old 08-11-2016, 11:07 AM   #3314
TLRacing
Frank Root's Avatar
I've played with the springs a bit. Right now, I have an AE white front spring, with a TLR LF white rear. Sometimes, I run the AE Green rear. I don't like the Kyosho springs as much as those in the rear. I know some guys like the Kyosho gold front springs, but every time I try it, it kills the front end and I don't have enough steering - for me at least.
#Full Disclosure
Old 08-11-2016, 05:12 PM   #3315
Trader Rating: 32 (100%+)
Wrong thread sorry
raved007 is offline   Reply With Quote
