    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 06-19-2016, 09:49 PM   #3091
jt409's Avatar
My local track just went to astroterph, what gear diff do I use in my 22 3.0, also what mods do you guys recommend obviously the laydown transmission what else. It's a very smooth track with average sized jumps.
Mackinaker
jt409 is offline   Reply With Quote
Old 06-20-2016, 10:51 AM   #3092
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by thumper_pa View Post
Well I've never owned a losi I was and still kinda die hard AE guy first real rc as a kid was gold pan. Anyways after some reading and looking I decided I wanted my first losi to be a TLR 22 3.0 buggy and I'm itching to get it I'm excited about a lot of things but mostly the unknown the brand itself is foreign to me. I'm going to run it as a mod buggy so any die hard losi guys or frank have any advice pointers on what to look for or do to the car I honestly don't have the time to read the hundreds of pages and weed out the best info so even though it may seem like a redundant ? Any help or insight would be great I'll be running a small indoor track with medium traction it's packed tight but no grooving some light dust time to time so I don't think the laud own will be anything of a improvement. Thanks so much
I'd just start with the kit setup and tune from there. It should be close to start.
Originally Posted by fantomdude View Post
Frank
On your latest setups you have started going long arm in the front why is that? What does going to long arm instead of short arm due to the handling of the car.
It smoothed out steering for me in higher speed turns. Reduced steering just a touch, but really helped the consistency. I've been running long arm since Reedy Race in January
This is the setup that Dustin and I came up with during testing at Northwest Hobbies.
http://www.tlracing.com/ProdInfo/Fil...2015-12-20.pdf
We ran the Losi Gear Diff for the 22, LOSA2954.
http://www.losi.com/Products/Feature...rodId=LOSA2954
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 06-20-2016, 11:58 AM   #3093
You can use the Serpent gear diff for SRX-2 or SRX-4. Either fit, just need to shim both sides.
Callaway is offline   Reply With Quote
Old 06-20-2016, 09:39 PM   #3094
Send a message via MSN to Racecarguy Send a message via Yahoo to Racecarguy
Where do you get the shims from?
Racecarguy is offline   Reply With Quote
Old 06-20-2016, 11:17 PM   #3095
jt409's Avatar
Thanks for all the quick responses guys is there a preference on the diffs.
Mackinaker
Old 06-21-2016, 01:15 AM   #3096
JsK
JsK's Avatar
Jamie i started with a gear diff and went back to a ball, turf is still a little squishy and a ball diff seems more consistent. I would keep a gear diff ready for when the track breaks in a bit more.
JsK is offline   Reply With Quote
Old 06-21-2016, 02:44 PM   #3097
jt409's Avatar
Thanks Jason I'll give my ball diff a go this Thursday.
Mackinaker
Old 06-22-2016, 12:57 AM   #3098
Was there a notable difference with rear shocks moved to the front?
rally stylz is offline   Reply With Quote
Old 06-22-2016, 08:31 AM   #3099
TLRacing
Frank Root's Avatar
Not much really, we just tried it per Ellis' suggestion and it wasn't worse so we didn't take it off.
Old 06-22-2016, 09:33 AM   #3100
I have question on setup for a outdoor dirt track. It is loose and loamy and we run hole shots front and gridirons on the rear. I have moved the rear hubs forward and changed the rear camber block to 0 mm, lowered the front camber to 1mm on tower and 1mm on the camber block and moved the front camber to 1-A. The question is how can I make it a little smoother and faster on switch backs. https://www.youtube.com/watch?v=na2wrghs7Kc this is how the track is and this next weekend we are running the other direction. My buggy is the one that started 1st and finished 2nd and is all white. I am running 17.5 and the guy that won is running a 7.5 so I know there is a power difference but want a little more out of it with out changing motor. My gearing is 75/32 and temps after 8 min is 160.
jdutch03 is offline   Reply With Quote
Old 06-22-2016, 09:03 PM   #3101
ProfessorX's Avatar
Trader Rating: 17 (100%+)
I got kyosho springs any calor to use with buggy. ??
ProfessorX is offline   Reply With Quote
Old 06-22-2016, 10:25 PM   #3102
Losi Chaser's Avatar
R/C Tech Charter Subscriber
gold front. Sometimes gold rear depending on track conditions.
Losi Chaser is offline   Reply With Quote
Old 06-23-2016, 02:08 AM   #3103
When you say you move your rear hubs forward do you go 3mm behind and 1mm spacer at front or all 4mm at the back to move it forward? Just having a few problems with traction on outdoor loose dirt still …Thanks
PENN01 is offline   Reply With Quote
Old 06-23-2016, 06:41 AM   #3104
rregl0612's Avatar
Trader Rating: 33 (100%+)
Default just picked one of these up
Ready to rip some 17.5 around central Pa.. awesome to see such a huge following, I'm sure I'll have some questions..
For starters what's a good place to start on spur gearing?
rregl0612 is offline   Reply With Quote
Old 06-23-2016, 07:18 AM   #3105
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
There are a lot of variables like what motor are you going to use, what timing is it set at, how big is the track, what type of traction level is it. But people will still throw out gearing suggestions not knowing this information.
I have a Motiv motor, timing between 40-50 on the can, track is 100x48ish, grip is on the high side but not damp dirt/clay, and I would start at 70 spur 28 pinion based on that information.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
