    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 06-11-2016, 04:14 PM   #3061
RacerX11's Avatar
I've been running the 3.0 for a while now in stock. Only changes to the kit set up i've made was going to 27.5 wt Dynamite oil and 4 degrees toe, I adjust my camber to the track. My only aftermarket parts are a hot racing front camber block which feels almost as light as the plastic one, an exotek slipper eliminator and aluminum pucks. I've had people tell me that my buggy was the fastest stock buggy they ever seen. All i run is a Trackstar V2 17.5, Speed passion Revention R, Savox SC1257 servo and use RCking(smc) 4400mah packs. Overall very happy with my buggy on the many surface types i've ran on it so far, from med high bite clay all the way to med low grip very dusty tracks where you wouldn't think 3 gear would work.
Bumps & Jumps RC Speedway | Pit Stop Hobbies
Current cars: RC10B6D, RC10B64D, Sworkz S35-2e
RacerX11 is offline   Reply With Quote
Old 06-11-2016, 08:53 PM   #3062
Originally Posted by HollywoodRC View Post
Ok, I got the Exotek all installed and decided not to modify the front kick plate and add the +3 rear hubs to move up the roll center 3mm. Now, the question is how low, with just the Exotek leydown tranny, can you make your ride height?
I understand using the TLR laydown kit the +3mm rear hubs and the front kick plate mod is needed to move the roll center up so you can run a lower ride height. So, I'm thinking that I can go down a few mms using the Exotek, but not sure. Any thoughts from you jeti masters out there?
I have been running 21 mm front and rear wit good results
fantomdude is offline   Reply With Quote
Old 06-11-2016, 11:26 PM   #3063
HollywoodRC's Avatar
Awesome, that's what I was thinking, 22mm is where I am gonna start.
So, you are not running the +3mm rear hubs? I'm gonna start with the stock hubs.
HollywoodRC is offline   Reply With Quote
Old 06-12-2016, 05:12 AM   #3064
Trader Rating: 139 (100%+)
Originally Posted by K_King View Post
It remains to be seen to know if a convertible car is the way to go as well. The biggest thing I'm noticing is how the outdrive height is being adjusted on the 3.0 to be more dirt friendly to allow higher ride heights. The industry is really new to laydown, and you can never expect something to take off until after it's released. I think you will see laydown evolve even more as guys learn how to make it better, and THEN you will see things happen. Right now you have different tranny cases for different conditions.
Plus, what about running a standard car with a HRC front and rear block? I bet that would work very well also.
I don't think it would work as well as a dedicated laydown car. I have both YZ's, picking up another 22 3.0 cause I liked it for mod on less then med-high bite tracks, but in stock and mod with high grip clay the corner speed of the YZ-2 CA/X-Ray XB2 Carpet, B5M Laydown are all seeing faster lap times across the board in the hands of the better drivers then the stand up three gear cars where I run. It's all about carrying forward momentum, and laydowns can carve turns much better on power then stand up transmission cars can, they also seem to more naturally rotate around sharp turns then stand ups, and I don't think I have ever traction rolled my YZ-2 CA.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 06-12-2016, 09:12 PM   #3065
Frank, you can package the kit with the laydown chassis drilled for (and including) both transmissions and call it the TLR 22 3.1
Callaway is offline   Reply With Quote
Old 06-13-2016, 10:09 AM   #3066
Send a message via MSN to Racecarguy Send a message via Yahoo to Racecarguy
I ordered the laydown dirt diff case. Does that setup use the alum rear hubs and HRC front mount or just regular standard 3.0 parts before putting on the lay down kit?
Racecarguy is offline   Reply With Quote
Old 06-13-2016, 11:16 AM   #3067
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Run normal everything on it. Essentially you're going to have a laydown car that runs at 23-24mm height vs the 20-21 of the normal laydown.
I'm really liking mine. Mellows it out enough due to the higher ride height but you still get good corner speed and stability.
K_King is offline   Reply With Quote
Old 06-13-2016, 12:20 PM   #3068
I tested the Exotek lay down tranny, with 22mm ride height, and the on power corner speed was awesome. Very happy with this tranny.
Old 06-13-2016, 12:39 PM   #3069
67GTA's Avatar
Can this be installed on the stock chassis or does it have to be on the chassis from the laydown kit?
67GTA is offline   Reply With Quote
Old 06-13-2016, 12:45 PM   #3070
You use the stock 22 3.0 chassis. You will have to drill two 3mm holes in the chassis. The kit comes with a template that makes real easy.
Old 06-13-2016, 12:54 PM   #3071
67GTA's Avatar
That's for the Exotek - just wondering if you can do the same thing with the TLR dirt laydown case by drilling a couple holes in the stock chassis and using shims for the waterfall.
Old 06-13-2016, 01:18 PM   #3072
Losi Chaser's Avatar
R/C Tech Charter Subscriber
yes, you can.
Losi Chaser is offline   Reply With Quote
Old 06-13-2016, 01:40 PM   #3073
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i was told to rn a standup 3.0 setup, using the laydown trans...meaning, no front hrc, and middle spindle height...etc...
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 06-14-2016, 01:02 AM   #3074
Woulvesbaine's Avatar
Someone should start to compile a list of hop up parts from all manufacturers for this car.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 06-14-2016, 04:25 AM   #3075
Default #confused
Cub86 is offline   Reply With Quote
