    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 05-24-2016, 11:44 AM   #2926
Team Pink's Avatar
Trader Rating: 20 (100%+)
Originally Posted by DJPod View Post
Anybody have some 22 3.0 setup tips for Outback Raceway in Chico, CA? My boys might be running in the Rookie class for the JC Summer Indoor Nats.
I am especially interested in what is a good tire choice.
Good morning! I was there two months back for the Outback Shootout and actually have a really good setup that I used to win Expert Stock and Mod at that race. If your interested in it let me know and I would be more than glad to send it to you.
As for tires when the track drys out and goes to slicks AKA Slicks, Jconcepts Smoothies, or Proline Primes all work well. For the JC Summer Nats it will more than likely be slicks. See you there!
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 05-24-2016, 06:43 PM   #2927
Woulvesbaine's Avatar
Frank, anything new coming out for this that you can talk about? Lightweight chassis?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 05-24-2016, 07:47 PM   #2928
omarwashington's Avatar
I'm needing to buy tlr2972 but I don't really need the grease and tread lock that it comes with, is there an alternative that you guys use?
RCCARS!
omarwashington is offline   Reply With Quote
Old 05-24-2016, 10:15 PM   #2929
Bikemaster00's Avatar
Default Serpent diff on clay
I know a lot of people recommend running the serpent SRX2 diff with only 2 gears and with 12k oil has anyone ran it with all 4 gears on Med-high bite clay? What diff oil did you use? I ended up messing with the diff at the track a little bit and 20k oil seemed to do well has anyone went any higher than that?
TLR SCT-E 2.0 Tekin RX8 Gen2 Pro4 4600kv, TLR 22 3.0 Tekin RSX 7.5T Redline Gen3, MST XXX-D Tekin RSX 8.5T Redline Gen3, MST XXX-R Tekin RX8 Gen1 Pro4HD 4300kv
Bikemaster00 is offline   Reply With Quote
Old 05-25-2016, 05:49 AM   #2930
thecman26's Avatar
Trader Rating: 99 (100%+)
I've actually heard the SRX4 diff is better.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-25-2016, 07:47 AM   #2931
Internally they are the same. SRX-2 has plastic outer gear, SRX-4 has aluminum. Which is better is up to you and your application. For stock I think people would tend to go plastic. I run the aluminum in mod.
Currently I'm at 15k on carpet. I believe I am running 2 gears on my buggy, 4 gears on my SCT. I have it written down at home, but I am almost positive that's how I have it.
Callaway is offline   Reply With Quote
Old 05-25-2016, 08:23 AM   #2932
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Pretty much all of the options we have in the works have already been announced, and are either shipping already or very soon.
There is a full listing here: http://www.tlracing.com/Products/Rel...s&SubCategory=
The grease and threadlock are 'throw ins'. We don't offer the parts without them as a separate offering.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-25-2016, 12:44 PM   #2933
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Personally dont see need for a LW chassis. OOB this buggy is already near minimum (mine is at 1550) with a shorty pack and shorty servo. Ti tierods and a few screws and you would be below weight.
Perfect as-is
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 05-25-2016, 03:21 PM   #2934
Mudcat981's Avatar
Perfect as-is
At the stock NATs I was at 1501.
Lunsford rods, balls, and screws.
Orion 4500 100 C Shorty.
Savox Servo SV-1270TG
HW Justock ESC
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 05-25-2016, 03:25 PM   #2935
Casper's Avatar
Trader Rating: 34 (100%+)
If anything I would look for a heavy chassis as with the ultra light weight body I would rather have the extra weight in the chassis low!
I put my car at or below with electronics, slipper eliminator and alum bones.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-25-2016, 03:50 PM   #2936
I'd like to see a brass rear pivot. I had a brass RF pivot on my old rb6 with lw chassis and it made a big difference on medium bite tracks.
Frank, any plans to release something like this?
RichD is offline   Reply With Quote
Old 05-25-2016, 03:53 PM   #2937
TLRacing
Frank Root's Avatar
On the way, should be available by August.
Old 05-25-2016, 05:41 PM   #2938
Seems like people are only running it 2 gear. To me it would seem that would wear on the diff more than having all 4 gears in it. I guess I'll just keep experimenting with it with 4 gears. Anyone else have any more input on this as far as Diff oil they are using with all 4 gears on clay?
Old 05-25-2016, 06:08 PM   #2939
Henry#40's Avatar
EXOTEK make one.
TRAXXAS - The unfair advantage
Henry#40 is offline   Reply With Quote
Old 05-25-2016, 08:33 PM   #2940
Given we're going into winter here in Oz, grip is declining. Therefore I'd be more than happy to assist with pre production testing! 😬
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
