    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 05-03-2016, 09:38 PM   #2731
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bmag5000 View Post
I hope so. Im just getting alot of heat right now because I think im
going to be one of the few guys running the opposite brand.
No issues running the other brand. If you need help setting up the car there is a community here. The 3.0 is a GREAT car. Show everyone else what they are missing.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-03-2016, 10:09 PM   #2732
thecman26's Avatar
Trader Rating: 99 (100%+)
Amen to that!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-04-2016, 06:17 PM   #2733
gokarter64's Avatar
Laydown transmission is installed. Now to find some carpet to test it on
gokarter64 is offline   Reply With Quote
Old 05-05-2016, 06:47 AM   #2734
thecman26's Avatar
That has to be the weirdest spur gear I have ever seen... ^
Old 05-05-2016, 08:04 AM   #2735
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
so, i have been following the laydown trans discussion...
is this the new thing for 17.5 racing??
i race on a med to high bite dirt track...
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 05-05-2016, 08:33 AM   #2736
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Yes so buy one!
Ask Frank K. he will let you know how it works.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-05-2016, 09:41 AM   #2737
RobS's Avatar
Quick question for you guys, and probably been answered a bunch of times before.. But I've been out of the offroad scene for a few years and am planning on getting back in. I'm torn between the 22 3.0 and the B6/B6D. My questions is.. How necessary is the laydown transmission on carpet using slick tires? I have a mix of dirt and carpet tracks in my area and the nearest carpet track requires the use of slicks on carpet. I know the grip wouldn't be quite as high as it would be if we were using small pin type tires but I was thinking the regular transmission might not be as much a disadvantage over a laydown car in this situation. Any thoughts?
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 05-05-2016, 10:13 AM   #2738
MikeR's Avatar
Trader Rating: 15 (100%+)
gear cover... cough...
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-05-2016, 10:18 AM   #2739
Flip boy's Avatar
If you run carpet, do yourself a favor and give the laydown a try. Its proven to be faster on our clay track so thewriting is on the wall.
Flip boy is offline   Reply With Quote
Old 05-05-2016, 11:08 AM   #2740
Administrator
Matt M.'s Avatar
Originally Posted by Kraig View Post
Yes so buy one!
i suppose it will give me the edge to end the streak...lol
Old 05-05-2016, 11:58 AM   #2741
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I'm not sure if everyone saw or not, but we added setup sheets last week for the laydown car.
I just talked to Jake Thayer at OCRC, and he said he ran my setup to a "T", and he holds stock track record and has won the past few A-Mains with his laydown conversion.
http://www.tlracing.com/Products/Def...006#prodSetups
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-05-2016, 12:00 PM   #2742
3srcracing's Avatar
Saw laydown last night on dirt, it looked pretty lethal.
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is offline   Reply With Quote
Old 05-05-2016, 12:42 PM   #2743
Mudcat981's Avatar
Guess I'm totally screwed this year at the Stock Nats
The laydowns and locals will be at the top and us out-of-daters/towner's will fill the lower mains.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 05-05-2016, 01:11 PM   #2744
TLRacing
Frank Root's Avatar
I'm pretty sure that Theo at Pacific Coast Hobbies still has some left in stock. Might call over there to find out.
Old 05-05-2016, 01:16 PM   #2745
Mudcat981's Avatar
Not ready to fork over $$$ for the hot setup
I will just have fun as always.
