    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 05-02-2016, 06:40 AM   #2716
Flip boy's Avatar
Originally Posted by Rckid19 View Post
Hi everybody I'm picking up a 3.0 and was wondering what is good to do setup wise right out of the box for OCRC. For example I've seen the +1mm on rear axle and stuff like that I just wanted to know what stuff is a "requirement".... Thank you👍🏼
There is nothing needed out of the box this car is very adjustable and competitive, if your wanting to try someone else's setup, then you will have to look and see what they have
Flip boy is offline   Reply With Quote
Old 05-02-2016, 09:54 AM   #2717
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Try this setup, it works well for me.
http://www.tlracing.com/ProdInfo/Fil...2016-01-24.pdf
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-02-2016, 11:43 AM   #2718
Thank you frank!
Rckid19 is offline   Reply With Quote
Old 05-02-2016, 12:49 PM   #2719
thecman26's Avatar
Trader Rating: 99 (100%+)
I got home last nite from a big race in Arkansas and have to admit these looked really good! JR Mitch totally dominated in 2wd and 4wd! But seriously he could've TQ'ed with a stinkin Traxxas bandit! That guy can wheel!
As for the stock body. I found myself wanting to ask several guys what body is that, then I remembered oh yeah thats the stock 22 3.0 body lol!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-02-2016, 03:32 PM   #2720
thecman26's Avatar
I am starting my build but I am not seeing a chart for the servo spacers, Installing a Futaba BLS451 and wondering which one if any?
Old 05-02-2016, 03:34 PM   #2721
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Pull up the 22 2.0 manual....It was mistakenly not included in the 3.0 manual. Or just test fit, you want the link to be perpendicular to the chassis.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-02-2016, 03:35 PM   #2722
thecman26's Avatar
will do thanks!
2mm fyi
Old 05-03-2016, 08:41 AM   #2723
tfrahm's Avatar
Send a message via AIM to tfrahm
I may have missed it, but the automated search didn't find an answer, so...
? Where are the TLR team drivers measuring the rear ride height on the 3.0...? On the 1.0 and 2.0, the original info was to measure to the bottom of the transmission, but with the 3.0 chassis step-up, etc. I realize I may be measuring my ride height wrong...?
? Are the published "stroke" lengths for shocks the actual measurement from the bottom of the shock body to the top of the shock end...?
Thanks in advance and sorry if this is a rehash...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 05-03-2016, 09:39 AM   #2724
TLRacing
Frank Root's Avatar
Measured on the flat part of the chassis front and rear.
Yes, top of the eyelet to the bottom of the shock cartridge.
Old 05-03-2016, 06:09 PM   #2725
thecman26's Avatar
I have to say if people aren't satisfied with these shocks... Guess you can't please everybody! Just in comparison with my B5MFL and T5M I had to spend an additional $45 each (Ti-Nitride shock shafts and X-Ring rebuild kit) to get the shocks as smooth as these in stock form! TLR was very nice to include X-Rings out of the box and those shafts are nice and smooth too!
Old 05-03-2016, 06:12 PM   #2726
Assocaited guys pick on me at my track because I run Losi.
I run Losi because I wanna run something different. I get tired of hearing about the SC5m, B5m, etc.
Tebo Runs Kyosho and nobody seems to care about that either.
I think i just have a bunch of idiots that race with me is all..
Associated B6 "Dirt Version" latemodel, Team Losi Racing 22T 2.0 Bomber Truck.
Team Losi Racing 22 2.0 2wd Short Course Truck,Duratrax 835e Brushless 8th scale Buggy,
Stock Slash, B4.1 latemodel(retired), T4.2 Factory Team BOMBER CAR
Castle Creations( Since April 2016)
bmag5000 is offline   Reply With Quote
Old 05-03-2016, 06:21 PM   #2727
thecman26's Avatar
I have to admit I have run just about everything out there, mid 90's Losi (XXX-BK2 XXX-MF2, XXX-AD2, XXX-4G+, XX-4), Early 2000's Kyosho (RT5, SCR, RB5, RB5SP, RB5SP2), Mid 2000's AE (B4, T4, B4.2, B5, B5M, B5MFL), some TLR's even (a couple 22T's and a 22SCT), and even had a couple Durangos and others like JConcepts wheeler and Hot Bodies D4 thrown in for fun! That's quite a list not even including 1/8th scale or mini/micro... The last 2 or 3 years have been all AE, getting this buggy will be my testing option for the newer TLR gear but so far I am VERY impressed!
But seriously we're having fun, that's what counts right?
Old 05-03-2016, 06:30 PM   #2728
I hope so. Im just getting alot of heat right now because I think im
going to be one of the few guys running the opposite brand.
Old 05-03-2016, 06:34 PM   #2729
thecman26's Avatar
Some people just can't let other people have fun...
I'm pretty sure there's only 2 maybe 3 22 3.0's at my track... I sure don't care...
Old 05-03-2016, 09:11 PM   #2730
tfrahm's Avatar
Originally Posted by Davidka View Post
After many weeks of racing (and crashing) I managed to break a shock tower last night. That was weird.
Some are reporting breaking the rear ballstud mount, I saw my first last night.
If your car is new and your shop stocks parts, don't worry about breakage. This thing is pretty tough.
Just a personal observation: Saturday night, I also managed to break my rear shock tower... I have been racing my 3.0 since it hit the track the first week of December - that is five (5) MONTHS of racing it every Saturday night - this is the first time anything on the car has broken...
FWIW: I have a suspicion that I know WHY the rear shock tower breaks where it does (every picture of a broken rear shock tower shows the last 3/4" of the right "ear" snapped off)... If the car flips and lands upside down with the rear end hitting first, the shock tower flexes just enough for it to hit the aluminum motor mount, and it snaps at that spot...
