    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 03-22-2016, 12:12 PM   #2431
Originally Posted by billdelong View Post
Honestly, if I were to do it over again, I'd go with the TLR lightened outdrives instead of the MIP Pucks, the MIP aluminum shafts tend to bend with the slipper eliminator on our uber high bite surface and short stack 17.5T motors.
I'm thinking of doing the same change but can't find any of the TLR parts in stock.
toddmanley is offline   Reply With Quote
Old 03-22-2016, 03:00 PM   #2432
ryan432greening's Avatar
Is anybody using light shorty packs like the Protek 100C 2800 mah?
First, do you like the handling with this light of a battery?
Second, are you able to get through a 10 minute main in the stock class?
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 03-22-2016, 03:29 PM   #2433
Mudcat981's Avatar
I tried a LRP 2900 LCG, its just to light not enough weight transfer. Also I'm already at 1505gm with a ORION 100C/4500 MAH Shorty so it was just to see, not legal to be that light.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 03-22-2016, 03:32 PM   #2434
Wow, that's awesome you're that light with a big pack. Thanks for the feedback!
B-Main Racing
Old 03-22-2016, 03:59 PM   #2435
Lenman73's Avatar
I am running that battery and come in around 1524 grams. I love the way it handles. No problems there but I have not done more than a 6 minute main.
I also have a small shorty from promatch that is 3500 mah and that should do it no problem and they are under $40.
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
TLR 22-4 TLR 22t 2.0
B44.1 B44.2
Lenman73 is offline   Reply With Quote
Old 03-22-2016, 08:03 PM   #2436
I have that pro match battery, havent run it yet.
Whats your setup? did u have to do change anything from the regular shorty setup?
Im running box stock setup essentially.
kki000 is offline   Reply With Quote
Old 03-23-2016, 03:09 AM   #2437
Lenman73's Avatar
I am running 1.7' s in the back with 27.5 wt and box pistons with 30wt. up front. Then just tuned for the tracks I go to.
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
B44.1 B44.2
Old 03-23-2016, 03:10 AM   #2438
Lenman73's Avatar
I am still running the kit springs also.
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
B44.1 B44.2
Old 03-23-2016, 05:12 AM   #2439
jonski's Avatar
Trader Rating: 241 (99%+)
Do you have a part number for these? Couldn't find anything listed.
First RC car was a RC10T - 1992
jonski is offline   Reply With Quote
Old 03-23-2016, 12:40 PM   #2440
That's some seriously light dampening in the rear. You don't have any bottoming out issues?
rally stylz is offline   Reply With Quote
Old 03-23-2016, 05:37 PM   #2441
Lenman73's Avatar
For my local track the features aren't overly big so no problem there. When I travel to bigger tracks then I bump it up to where it needs to be.
TeamC TC02T
Team-C TC02 evo
TLR 22 2.0 & 3.0
B44.1 B44.2
Old 03-23-2016, 05:48 PM   #2442
Woulvesbaine's Avatar
Originally Posted by lyons238 View Post
guys dont freak about the camber block. the reason it slipped out to production is most likely because the pros when testing dont crash as much so initial block was fine. by no means is it weak, they probably were just shaving weight where possible, and for the general public that was an area that should have stayed more robust.
i have the latest production kit with the updated camber block and i think that is the only change. like i said i heard people say that the rear hinge pin mounts/pill insert mounts have been updated but i dont think thats true, not sure though. awesome kit, regardless.
Running changes are a good thing. When I ran my dex410 and dex210, it was insane to see so many Durango people deny/ignore the ball cup issue, especially how easily they could have just dropped a bag of better ball cups in.
Be happy that TLR recognized it and fixed it in reasonable time.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 03-23-2016, 06:05 PM   #2443
RC10Nick's Avatar
I raced the my 210 for 3 years on the v1 ballcups and never had an issue
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 03-23-2016, 06:19 PM   #2444
Thumbs up because they fixed it.
Thumbs down because we had to pay twice as they used us as betatesters.
And I also thought that this one was not going to break...
everlaps.com - Professional Race Timing Solutions
Gusi is offline   Reply With Quote
Old 03-23-2016, 07:00 PM   #2445
ogmudbum's Avatar
Had this happen to me the other day. Nice $30 replacement
[url=https://flic.kr/p/EF9jpL]
[url=https://flic.kr/p/EFuByV]
ogmudbum is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
jamsandolina, Pistol123
