    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree14Likes
Old 03-05-2016, 08:45 AM   #2281
Davidka's Avatar
Trader Rating: 76 (100%+)
Originally Posted by Wheetie View Post
17/31 was a typo lol I meant 70/31. Performance is there but I'm still about a second off the fast guys lap times. Could be my driving too though I'll just have to push it a little harder next practice day see what I can do with it.
It probably is your driving (unless you're visibly underpowered). Your temps are well within a safe range so try gearing up/down a couple of teeth each way to see what it gets you.
When working on the lap time, try not to think of it as "push harder", but instead " push better". That last second is usually in line and timing. I've almost never found more time in my radio's trigger.
Old 03-05-2016, 02:29 PM   #2282
Mudcat981's Avatar
Talking Absolutely Amazing!
I ran my first race in more than 4 months, and the maiden voyage for the 3.0.
I qualified 6th, in a field of 11 cars. I got caught up in a crash leaving me last on the first lap. This car was amazing, I never once felt the car was about to lose it. Even when the car was sideways I was able just to hit the throttle and it straighten up and took off. I was able to pick lines without fear of losing control. Picked my way up to 4th and had the #2 & #3 in my sites was about to pass because I knew they couldn't make the jump and 180 turn as quick as I could. Then bad luck happened, a turn marshal jumped in front of me as I was in the air. I had no choice but to whip it and barely miss his head by inches. Unfortunately for me I crashed and it took forever before the marshal got back to me. Finished 5th, but the car was a dream to drive.
Running Dustin Evans setup.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 03-05-2016, 05:29 PM   #2283
Greg Etter's Avatar
I'm going to get my first race in with my 3.0 tomorrow. Fingers crossed.
Greg Etter is offline   Reply With Quote
Old 03-05-2016, 06:19 PM   #2284
What parts do you guys recommend having on hand as replacements for racing? I guess more specifically what parts on this car are more prone to breakage? I currently have an extra set of arms, ball cups, and a couple spur gears and slipper pads but don't know what all to stock up on as I am new to the racing world and usually just shelved my cars if I broke them until parts got here.
Wheetie is offline   Reply With Quote
Old 03-05-2016, 08:00 PM   #2285
Davidka's Avatar
After many weeks of racing (and crashing) I managed to break a shock tower last night. That was weird.
Some are reporting breaking the rear ballstud mount, I saw my first last night.
If your car is new and your shop stocks parts, don't worry about breakage. This thing is pretty tough.
Old 03-05-2016, 09:15 PM   #2286
How is everybody who is using the additional rear body fin attaching it to the main body?
mserno75 is offline   Reply With Quote
Old 03-05-2016, 09:53 PM   #2287
chevydc44's Avatar
Trader Rating: 31 (100%+)
I used double sided tape instead of a screw and nut
chevydc44 is offline   Reply With Quote
Old 03-06-2016, 09:27 PM   #2288
I used shoe goo.
xnummyx is offline   Reply With Quote
Old 03-06-2016, 10:03 PM   #2289
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
http://vbcracingusa.com/store/tuning...thin-tape-roll
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 03-07-2016, 04:34 PM   #2290
Looking for some setup advice to keep the car flatter in corners, I seem to be having an issues with traction rolling both at high and low speed
Kas10Racing is offline   Reply With Quote
Old 03-07-2016, 05:10 PM   #2291
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Try 1mm more front droop.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 03-07-2016, 05:48 PM   #2292
F N CUDA's Avatar
This comes from the guy who is killing our stock class records just for fun and also used the screws to mount his fin to the body.
Just sayin.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 03-07-2016, 06:27 PM   #2293
Removing the limiter inside the piston to accomplish this? Or unscrewing the rod a bit?
Old 03-07-2016, 10:15 PM   #2294
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default Alum servo mount
Is there aluminum servo mount made be TLR for this car.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 03-08-2016, 03:42 AM   #2295
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Yes. Scroll down.
http://www.exotekracing.com/losi-tlr/
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
