    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 03-03-2016, 08:53 PM   #2266
klowne's Avatar
Starting a fresh build and hitting the tired wall so time to stop. I have a question concerning the servo shimming. I am going to install the trackstar TS-915, does anyone know what shim is to be used or how much to shim it? I know it uses the futaba spline for servo horn. Any help would be greatly appreciated. I will check back tomorrow as the eyes are heavy lol.
klowne is offline   Reply With Quote
Old 03-03-2016, 09:21 PM   #2267
ryan432greening's Avatar
What is servo shimming and what is it for? I've never done this.
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 03-03-2016, 10:46 PM   #2268
Default Gearing questions.
Hey guys, I'm racing the 17.5 class at my local track and using 70/30 gears. I ran the 17/31 and my temps coming off the track were around 110. I went down a tooth pinion wise and it changed to around 115. How far would you recommend me change the gearing to stay under temp and still get good performance out of the car. By the way the track is med. to high bite hard packed, mostly smooth with some rough spots in and out of the main straight. Thanks in advance if any of you have any advice!
Wheetie is offline   Reply With Quote
Old 03-03-2016, 11:01 PM   #2269
Jpdanger's Avatar
You want the servo turnbuckle to be perpendicular to the chassis for maximum throw. The shims are used to move the servo forward if the turnbuckle isn't perpendicular.
Motor and timing?
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 03-03-2016, 11:15 PM   #2270
Motor is a reedy mach 3 17.5 esc hobbywing stock v3.1 timing on motor is at 40 degrees.
Old 03-04-2016, 04:08 AM   #2271
Thanks man, I'll give that a whirl on my 3.0 when it comes.
[QUOTE=Jpdanger;14419037]You want the servo turnbuckle to be perpendicular to the chassis for maximum throw. The shims are used to move the servo forward if the turnbuckle isn't perpendicular.
B-Main Racing
Old 03-04-2016, 08:03 AM   #2272
Jpdanger's Avatar
It's early in the morning and my brain isn't functioning, but what is a 17/31?
Your gearing sounds like you're close. I'm not sure what timing people are using on the Reedy M3, but if your temp is 115 after eight minutes you have nothing to worry about. Most people shoot for anywhere from 160-180 depending on manufacturer. How is the performance compared to others? Personally, I'd add a few teeth to the pinion and turn up the timing to shoot for 160 after eight minutes.
Old 03-04-2016, 10:14 AM   #2273
17/31 was a typo lol I meant 70/31. Performance is there but I'm still about a second off the fast guys lap times. Could be my driving too though I'll just have to push it a little harder next practice day see what I can do with it.
Old 03-04-2016, 11:44 AM   #2274
Mudcat981's Avatar
Get a motor checker and bump the timing closer to 50*. I run mine between 45-50.
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 03-04-2016, 01:09 PM   #2275
Car has a slight on-power push, using kit setup with 32.5 in front and pink rear springs. High grip track. What would be the top 3 things you would try changing? Tires are right.
Thanks!
MrLean is offline   Reply With Quote
Old 03-04-2016, 01:16 PM   #2276
What's your ride height? If you're running higher in the front than the rear I would try leveling it out. I run 21mm front 20mm rear but I don't feel a push. Maybe 20mm front and rear would help you
B-Main Racing
Old 03-04-2016, 02:39 PM   #2277
RedBMaster's Avatar
Thanks!
Long VLA, Lower front bulkhead ballstud 1mm, and raise rear bulkhead 1-2mm.
Frank seems to be a big fan of 1mm std ballstud ackerman setting, so I'd proly give that a shot first!
Follow, race proven, Prolix RC on facebook: https://www.facebook.com/ProlixRC/
RedBMaster is offline   Reply With Quote
Old 03-04-2016, 06:56 PM   #2278
When are the wheel companies going to get on some front wheels for this hot rod? I love the different colors that DE has for the other popular buggies
B-Main Racing
Old 03-04-2016, 11:03 PM   #2279
I didnt use any shims with my trackstar servo with my 22 2.0 with bellcrank steering which is the same as the 3.0?
Lunchie is offline   Reply With Quote
Old 03-04-2016, 11:49 PM   #2280
cracky1970's Avatar
Thanks!
Try Frank Root's setup for the Reedy Race @ OCRC. I was getting the push as well, this took a lot of that away.
cracky1970 is offline   Reply With Quote
