    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 01-19-2016, 08:09 AM   #1666
rcus3r's Avatar
Originally Posted by ckfactory View Post
Mine either came bent or somehow bent during my first run on the car.
This has been my experience. If you have it tightened down all the way, it may appear as bent; it will wobble.
Loosen it up and see if it spins true.
The force of the spring will pull it one way. You can try to straighten it by squeezing the spring with pliers. Try to get the spring centered on the threads.
rcus3r is offline   Reply With Quote
Old 01-19-2016, 10:28 AM   #1667
BKH
Originally Posted by kman16jr View Post
Hey guys I recently built the 3.0 buggy to compare to my b5m and was just wondering what gearing I should start with,I run the d4 1s and I also run the 24k motor as well.
For the d4 1s I run 69/30 (5.59 FDR) at 55 degrees timing.
BKH is offline   Reply With Quote
Old 01-19-2016, 11:25 AM   #1668
Trader Rating: 54 (100%+)
i was building a spare diff that i had from my stock car since i installed the mip diff, noticed the diff spring while sitting on a flat surface was leaning to one side about 30 deg, is this normal or did i get a defective spring?
Speedychris22 is offline   Reply With Quote
Old 01-19-2016, 11:25 AM   #1669
Mudcat981's Avatar
Originally Posted by Dr. Gonzo View Post
Thank you. Just picked up a 3.0 and a nice 2.0 for my son
Have all electronics except a steering servo. Orion R10 and Xmod 13.5. Ordered the 1258tg be. I have a Hobbywing V3.1 and a trackstar 17.5 outlaw too. So I have my work cut out for me reading the thread. Thanks!
WORK!
That is just plain fun
Gene Hobbs - "Misplaced Texan"
TLR 22 3.0SR, TLR 22T 3.0, TLR 22 3.0 (Standard & Laydown)
TLR 22 2.0, TLR 22T 2.0, TLR 22-4 1.5
AIRTRONICS, HOBBYWING, ORION, SAVOX, TRINITY
LUNSFORD, JCONCEPTS, SCHELLE
Mudcat981 is offline   Reply With Quote
Old 01-19-2016, 11:28 AM   #1670
Mudcat981's Avatar
Originally Posted by itsjusme View Post
After using a hole punch for the cups I will never use a drill bit again. Not saying there is anything wrong with a drill bit, but the hole punch is just easier. I thought the hole punch would distort the cup, but it did not.
As I get older the easier the better for me.
That is one of the reasons i got the 22.3.0. The front end and rear hubs without the pills like the other brands out there. Less slop and knowing i have them on the right way. and it drives awesome.
The hole punch is one of the best tools in my box.
Old 01-19-2016, 02:48 PM   #1671
Trader Rating: 70 (100%+)
I have just purchased 2 kits will the wheels from my b5m fit I have lots of tires hope they will work?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 01-19-2016, 03:01 PM   #1672
Mudcat981's Avatar
no, off-set is completely wrong
Old 01-19-2016, 03:02 PM   #1673
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
^fronts from your B5m will not work. Rears will be fine.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-19-2016, 03:22 PM   #1674
Jack Bonhomme's Avatar
I finally ran my 3.0 this weekend at 2 trophy races at 2 different tracks with different dirt surfaces. Overall I like the buggy (1st time driving a mid motor car ) but I found the stock setup to push too much. At the 2nd track the lanes were much wider but I still felt it could be more responsive. I made the change to the long VLA front arm position and that seemed to do the trick. Buggy cornered much sharper on corner entry and held a tighter line. I still had a very planted rear end. My next step is to try the 1.6 and 1.7 shock pistons setup.
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 01-19-2016, 04:32 PM   #1675
RC10Nick's Avatar
I've started work on a fun new project Ijust made a test cut with some old G10 I had laying around to make sure everything was going to work out before I touched the good stuff. Stay tuned
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 01-19-2016, 05:49 PM   #1676
tony montana's Avatar
Trader Rating: 65 (100%+)
What kind of hole punch are you guys using to put the hole in the ball cups? I have a leather punch I use to make holes in my tires, would that work?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 01-19-2016, 05:50 PM   #1677
Davidka's Avatar
Trader Rating: 76 (100%+)
That's what most are using.punch from the inside, out.
Old 01-19-2016, 06:37 PM   #1678
What piston setup are most using? I see a lot of set ups are using 1.6 front and rear. Is that what most are using on here? Or staying with the kit setup of 1.5 in front and 1.6 rear?
Thank you for any replies.
Medicinal Coma is offline   Reply With Quote
Old 01-19-2016, 08:04 PM   #1679
RedBMaster's Avatar
I hope this means CF chassis will soon be on the way!
RedBMaster is offline   Reply With Quote
Old 01-19-2016, 08:57 PM   #1680
drepus's Avatar
Some folks who have tried have the Losi 22 rtr gear diff have had a little binding some have not. If yours does bind here is how i fixed mine.
Only takes a minute to accomplish.
https://www.facebook.com/groups/22em...9/?pnref=story
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
