    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Like Tree12Likes
Old 12-12-2015, 07:55 PM   #976
Guch's Avatar
Originally Posted by Davidka View Post
I just found my kit had a tiny packaging issue. In the steering assembly, the .5mm Ackerman shims were switched with the 1.0mm camber shims. Didn't notice until I was about to thread in the camber ball studs with 2.5mm's if shims. It would've been easy to miss.
Thanks for the heads up. I will double check my build this week. By saying swiitched do you mean you got .5 camber shims? So in the end you just had to switch them and all parts were accounted for?
For anyone running the new HV Spektrum s6270 low profile steering servo, i mounted it with NO spacers directly to the servo mounts in my 2.0 with the bellcrank steering so I think since the 3.0 is so similar in the front, mounting the steering servo should be the same. I did use the TLR aluminum servo arm and Exotek servo moints in my 2.0. Feel free to correct me if this does not work for anyone building their 3.0 with this servo. I will find out this week for sure during my build. I did buy a shorter servo wire for this servo since they just unplug and the receiver is right next door. I know alot of guys run lighter gauge wires for stock racing for weight. Anyone have any thoughts on running three 14 awg. motor wires for a 7.5 mod. motor in this buggy. I come from an old school back ground were we ran Nicads and brushed motors so ANY resistance hurt the run time so we ran big wire and heafty connectors. I see alot of guys today run big wire to the esc but much smaller wires to the motor for weight.
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 12-12-2015, 09:02 PM   #977
Davidka's Avatar
Trader Rating: 75 (100%+)
All parts accounted for (so far, not finished yet). Just had 1.0's with the steering rack instead of .5's, which were in the bag with the 2.0's in the camber link bag.
Old 12-12-2015, 09:12 PM   #978
I got mine built and tested today. The build went smooth. No real issues. No stripped screws. I did find some parts where the plastics were very tight. The steering rack where the bell cranks attach. I had to run an m3 tap about halfway through it. And my 4 gear transmission housing about burned up my power driver getting the screws in that. And the rear arms had a tiny bit of rub on the front hinge pin brace. A few seconds with some sand paper took care of that. Very easy and quick build. Even the suggested turnbuckle lengths were right on. I can't think of how many times I built a car to the recommended length and have it so far off its funny.
Anyway early this afternoon I went to the track with the intention of showing off a newly built 3.0 chassis and practising with my 2.0. After one pack in the 2.0 I decided to rip all the electronics out and put them in the 3.0. I didn't have a soldering iron or extra wire with me so the only place the esc would fit was on top of the battery. I also quickly discovered that the body would not fit. So I took my 2.0 body, mashed it on and taped it to the car. (Who said a 2.0 body wouldn't fit?) After a few Laos I started to get the hang of it. It was very easy to drive. Felt a little pushy at first. And I'm sure my electronics placement had a lot to do with it. But I felt I could put the car anywhere I wanted. We run on real untreated dirt and it can get very slick. I'm running this car in 17.5 and my fastest lap was a 20.4 and my fastest lap with my mod B5m was a 20.0. I was really impressed with how easy the car was to drive. I'm running 100% kit setup and if anybody wants to copy my electronics setup here you go.
greener74 is offline   Reply With Quote
Old 12-12-2015, 09:42 PM   #979
I used the 2mm servo shim with that servo on my 3.0 build.
Medicinal Coma is offline   Reply With Quote
Old 12-12-2015, 09:52 PM   #980
Originally Posted by slider3 View Post
Just finished the build today which went flawless. I toke it out for the first practice run. OMG!!!! This buggy is awesome. My first love is my wife... I just found my second. I could hammer it whenever i wanted. Jumped and turned great.
For your guys running stock. The setup is straight from the manual with the execption i used 32.5 oil in the front shocks. Two upgrades; alum servo horn and carbon front shock tower.
Clay indoor track... medium to high bite
Specs.
17.5 Kill Shot
1258 savox servo
Orion 4500 shorty battery (removed the rear spacer on the battery hold down and push the battery all the way back)
Hobbywing Just Stock esc
Spektrum SR3100 reciever
Dirt Webs front and rear (clay compound)
Weight was 1540. Would like to shave a little off that.
Would like to thank Frank and the TLR team for a great product. Frank, i appreciate you being so active on this forum...thanks. For those AE boys that's coming over.... you won't go back.
What gearing did you use?
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 12-12-2015, 11:15 PM   #981
Trader Rating: 8 (90%+)
Greener74,
What was your fastest lap on your 2.0? Since you ran it back to back with your 2.0, what were the pros and cons? I'm looking for an excuse not to burn a hole in my pocket with the 3.0, the US currency is so strong at the moment. Argghhhh!!!
juicy74 is offline   Reply With Quote
Old 12-13-2015, 04:55 AM   #982
Trader Rating: 50 (100%+)
Used 70 spur and 31 pinion. Temps were around 125/130 on the motor and 105/110 on the esc.
slider3 is offline   Reply With Quote
Old 12-13-2015, 06:48 AM   #983
Trader Rating: 16 (100%+)
I finally got my first run/race in on my new car. I love it. Big thanks to Mike Sontag (AMS raceway owner) for some setup tips. Overall the car just felt a little more linear and predictable then my 2.0
Wendling00 is offline   Reply With Quote
Old 12-13-2015, 07:01 AM   #984
Originally Posted by juicy74 View Post
Greener74,
I bought a used 2.0 about a week before the 3.0 came out. And I've been tuning on it for about 3 week . I was getting mid 21`s. 21.5/21.4 we have a few very slippery sections where our dirt is different and I was able to handle those sections without any problems. And we have a quick S turn into a double. 17.5 cars usually struggle to clear it. And you have to come through the S very smooth or you don't make it. I was so fast through that section that I was actually landing about 3 feet past the landing.
Old 12-13-2015, 07:10 AM   #985
Here it is with some dirt on it.
Old 12-13-2015, 07:11 AM   #986
RC10Nick's Avatar
Does anybody know if these front wheels are the correct offset for the 3.0?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-13-2015, 07:15 AM   #987
Trader Rating: 25 (96%+)
I provided some measurements in the change in offset on the previous page where going from 2.2" to 2.4" wheels increases the track width by 0.8mm and wheel width is increased by 1.0mm for each wheel on the front wheels.
billdelong is offline   Reply With Quote
Old 12-13-2015, 08:39 AM   #988
You're not helping...
Old 12-13-2015, 09:59 AM   #989
mes
Offset should be correct, but amain's description is misleading. These are not 12 mm hexes, they are "old" 22 front wheels. Feel free to compare them with JConcepts' description. As long as no one has tried whether std 4WD front wheels (e.g. JConcepts 3368Y) are a direct fit, I'd say it is better go for TLR43012. Maybe this has been covered in the JConcepts thread?
mes is offline   Reply With Quote
Old 12-13-2015, 09:59 AM   #990
I ran my 3.0 for the first time last night traction was abnormaly high last night for my local track. But coming from associated and kyosho t the 3.0 i really liked the buggy it done lots of stuff really good but running the kit setup i had a horriable on power push. I moved the batterey all the way foward, changed to black ae front springs and changed the front inner ballstuds to 1mm and still never got it totally fixed dont really know where to go next?
Jspires688 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
